Question about PNY 4GB Secure Digital High Capacity Memory Card
My 4GB PNY Optima sd card will not read
I got a PNY Optima sd card. I can put it in my reader but it will not read it. I can put other sd cards in and it will read them fine.
    Brigadier General:
  • 10,406 Answers
Try the 4GB card in some other reader, or your camera, to confirm that it does work.
It's possible that your card-reader will not support anything over 2GB.
Posted on Dec 10, 2009
    New Friend:
    Problem Solver:
  • 6 Answers
SD cards are not created equally! There is so much more to know than just the capacity.
There are many things about SD cards most people are not aware of. After having numerous problems with my cards, I thought I would share what I learned, mostly from online articles, trial and error!
There are SD cards (Secure Digital)
SDHC cards (SD high capacity)
and SDXC cards (SD extra high capacity, high performance)
Speed Class: There may be a C with a number inside the C printed on the card, (or a U with a 1 in it) - if there is no C or U on your card, it is a C2 card.
C2 is for basic data and photo use and has a slower processing speed.
C4 and C6 are acceptable for up to basic video.
C8 and C10 are high performance, fast processing speeds - and cost more.
The U1 symbol indicates fastest processing speed available, and will cost the most. For large size, HD videos.
If you are trying to use a basic SD2 card (no C rating or C2 rated) for a high quality or high speed video or large RAW photo, you may have problems with your device. The card may not be able to keep up speed-wise. These are generally older, or lowest priced cards. More information and photo examples on the speed class here: https://www.sdcard.org/consumers/speed/speed_class/
Your device will read SD cards up to the capacity it is capable of. A device with SDHC capability will be able to read basic SD cards, but might not be able to read an SDXC card, so you may think you have a defective card when you actually just have a device that does not have the capability to read it.
If your computer's SD reader or peripheral card reading device has an SD card reader and it cannot read SDHC (high capacity) or SDXC (extra high performance/capacity) it will reject or not see the card and you might think you have a defective card. Put the card in your camera or other device you are going to use it for, and then using the USB cord that came with the device, plug that into your PC. The PC will be able to read the card that way, edit it, etc.
After copying all files on the SD card to your computer, you may wish to format the card before using it again. When formatting the card, IMPORTANT: Make sure you have copied all the data you want to keep onto your hard drive, and make sure it is formatted FAT32. I kept formatting a card FAT (which was the default for this card), and the recordable capacity of the card kept getting smaller...and smaller...a 2GB card was only allowing 350, 250, 125 MB of data to be stored on it! I kept hitting a brick wall trying to copy files onto it. I kept formatting the card, thinking there was some de-frag issue or corrupted portion, and the capacity of what it would store kept diminishing - until I formatted the card FAT32. ONLY THEN was the card able to store to its true capacity. I was able to do this in Windows in Explorer - right click the drive the SD card is in, select Format, verify the Capacity (card size), verify the File System (use the pulldown menu to select FAT32 if it is not selected), and then click Start and allow the computer to remain undisturbed until the format is complete. I found a web page that covers this: http://pvillecomp.com/
There is an SD website that offers a download for proper formatting of your SD card, with downloadable instructions. I was using Windows to format my SD cards, but the SD website recommends using software that specifically formats SD cards. Here is the site: www.SDcard.org. Click the Downloads section.
Some older devices can only handle smaller SD cards (2 GB or smaller), so if your device cannot read a particular SD card...check your owner's manual. There is usually a limit to the size, capacity, speed, type, etc. of the cards each device can handle.
It is also possible to partition an SD card so it can be read by more devices, or separated for organization purposes. I prefer smaller SD cards when possible to avoid a huge loss if the card becomes damaged, lost, etc., but for those who have cards that are 16+ GB in size they may want to partition them. Here is a website for that:
http://forum.xda-developers.com/showthread.php?t=267475
Hope this helps!
Posted on Jun 28, 2013
2 Suggested Answers
SOURCE:
SOURCE: PNY optima SD HC 4GB card will not read
Try putting a tiny piece of scotch tape over the lock slider. See if that works.
Posted on Jan 07, 2010
Imy computer can not read it it said it needs the drivers
download the driver at http://www.solvusoft.com/en/update/drivers/micro-sd-card-reader/pny/models/
Oct 08, 2013 | PNY Technologies Memory Card; SDHC,...
How to unlocked pny optima sd memory card 4gb
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 28, 2011 | PNY 4GB Secure Digital High Capacity...
Every time I put my camera's SD card into my HP Printer C3150, a red exclamation mark light blinks on and off, and the SD card does not appear on "My Computer," so I can't access my pictures....
I am not an expert on such matters. It is possible the printer won't read the SD card because it wasn't formatted before use or was formatted by a computer using 64 bit software instead of 32 bit.
You could try using a card reader and downloading the images to your computer and printing from there.
Aug 11, 2017 | Office Equipment & Supplies
I have a PNY optima sd 4gb memory card and it tells me on my samsung camera card locked. What does this mean? and how do i unlock it?
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 11, 2010 | PNY Optima Pro 2GB Secure Digital Memory...
Memory card compatibility. camera won't read or
The C875 works with SD and MMC cards, which max out at 2GB. It will not work with larger SDHC cards.
May 14, 2010 | Kodak EasyShare C875 Digital Camera
I have this my pny optima sdhc 4gb and it freezes my pc when I want to get the pictures off or the videos. Works fine if I use my usb cord to the camera, but I want to know why it wont work just from the...
becoz then the autoplay of the drive will be activated and it will freez your computer......recomandation is to format the drive in computer not in the cam, or you can open the SD drive frome 3rd party software (total commander), and delete the hidden autorun files.
May 07, 2010 | PNY 4GB Secure Digital High Capacity...
Dec 29, 2009 | PNY 4GB Secure Digital High Capacity...
How to transport my pix from optima sdhc to picasa
Dear Sir,
If you have a card reader connect your SD HC to the card reader.then connect it to your pc then,open picasa click on import or browse then select your card reader is a source,then click ok,it will starts to import all the pic from SD card to your picasa album.
i think it solves your problem, if you have an query post a feed back, we will glad to assist you
Have a nice day
good luck
Sep 13, 2009 | PNY 4GB Secure Digital High Capacity...
PNY Optima SD HC 8GB isnt working on laptop
Youll have to get updates for your laptop card reader or get a new one which may have to be installed. Another method you may want to try would be to put the card back into the device you used it in and then hook the device up to the computer, most likely through the USB slot....good luck
Jun 05, 2009 | PNY Optima Pro 2GB Secure Digital Memory...
Have a pny micro sdhc 4 gb disk that is not being read by my computer?
From your description, it sounds like the card is faulty, not the computer or the card reader. If you can't get the card to read or write in any device now, then it's probably dead. Is the card reader you're using an SDHC card reader or just a regular SD card reader?
May 14, 2009 | PNY 4GB Secure Digital High Capacity...
PNY 4GB Secure Digital High Capacity Memory Card Logo
2,406 people viewed this question
Top PNY Electronics - Others Experts
Marvin
Marvin
Joe Negus
Joe Negus
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
