Question about Panasonic KX-T7431 Corded Phone
I Have an KX-T7431 and phone use to have 3 lines on it but now for some reason it only has 2, is there a way i can program line 3 back in, and my ohter 3 phones still have line 3 available so know it is not the line.
  • Panasonic Master
  • 2,460 Answers
Where line 3 is supposeed to be, press PROGRAM the button and dial 0 03 STORE.
That puts line 3 back in the proper place.
Carl
Posted on Dec 10, 2009
Testimonial: "Great Thanks"
HAVE LOST LINE 1 AND LINE 2 ON THE PHONE LINE 3&4 OK LINE 1 & 2 COMES UP NOT VALID
When you press PROGRAM 99 and the buttons where line 1 & 2 appear, it should say CO-01 and CO 02. If it doesn't dial 0 01 STORE and 0 02 STORE in those buttons. In a TD system, the lines have to appear in order for you to use them. They don't have to be 1:1, but it's the easiest.
(there's a Group CO button command to save buttons)
Carl
Mar 02, 2011 | Panasonic KX-T7431 Corded Phone
Hi, I have a Panasonic KX T7431 and have just attached a headset. I have changed the programming and i can pick up lines and hear people but they cannot hear me! i have tried another headset from the same...
Headsets on the 74xx series phones come in different flavors than the universal headsets of the 76xx and 77xx phones. The old Plantronics M bases and P headsets used to have a couple of adjustment dials on the bottom of the interface box that you had to play with in order to match the microphone to the phone system. If yours has those dials, try turning them until you can hear yourself in the earpiece.
Carl
Feb 15, 2011 | Panasonic KX-T7431 Corded Phone
I currently use a Panasonic KX-T7431 at work and I wnat to either know does it have an answer machine function within the phone or can I buy one to add to it , we cusstenly do not have any faciity for...
Generally, a 7431 phone plugs into a Panasonic KX-TD phone system cabinet. The 1232 starts as an 8 line 16 phone cabinet, the 816 a 4x8, and the 308 a 3x8. To those systems, you can add a TVx Panasonic brand voice mail system, or even a plain old ansering machine. Both would need to be probrammed by someone familiar with ringing and intercept groups in system programming.
A quick call to your Panasonic installer or dealer would be the best, as it's beyond the scope of this forum to provide instructions.
Carl
Aug 17, 2010 | Panasonic KX-T7431 Corded Phone
Panasonic line 3 not ringing
Try to check the phone line in..if calls come on it and it does not ring out then check the ringer settings for that particular port of the phone.
Hope this is helpful?
Jul 14, 2010 | Panasonic KX-T7431 Corded Phone
KX-T7730 - Used to have 3 incoming/outgoing lines. Have cut this down to 2(lines 1 and 3). Outgoing calls are automatically selected by line 3, 2, 1. When calling out the second person can't get an outside...
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system.
From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook :
1. Press PROGRAM * # followed by the system password ( default is 1234).
2. Now press 400 and then SP-PHONE. Enter the line number you wish to change. ( In your case 2)
3. Press AUTO ANS / MUTE to change between Connect and Not Connect.
4. Press AUTO DIAL / STORE to save your changes.
5. Press PROGRAM to exit program mode and you are done.
Mar 17, 2010 | Panasonic KX-T7730 Corded Phone
Programming one-touch dialing
I'll try my instructions and see if those are the ones you used.
Press Program 99 the button to program, dial 2+9 or whatever you use to get an outside line, and the number STORE.
Program exits programming.
Now, just press the button and it will automatically dial or you can pick up the handset and press the button.
Carl
Mar 25, 2009 | Panasonic KX-T7431 Corded Phone
I am looking for the programming overlay for a Panasonic KX-T7431 phone. Thanks,Rob
I don't have the overlay, but if you download the user manual, under User Programming Instructions (Page 3-3 in mine) it explains where and what the programming buttons are.
Dec 06, 2008 | Panasonic KX-T7431 Corded Phone
We have a panasonic kx-t7431 phone system in our office and want to add 2 more handsets to it. How do we do it
Each phone needs it's own set of wires to the main control unit. You cannot use splitters or connect a new jack up to another jack like home phones can. Do not connect your phone directly to the phone company's phone line. It will not work and a ring signal will break your phone.
The phone you have (kx-t7431) can work on one of several different Panasonic phone systems so your first step is finding out which model control unit you have.
Some of the smaller systems you can plug phones directly into them but the larger systems need a phone jack terminated at a punch down block.
Once connected your phone should work with the default settings. If you need it to ring at special times or with special phone lines then you'll have to do some system programming.
If you want to tackle this yourself you will probably need to obtain an "installation & programming" manual for your specific system.
Dec 05, 2008 | Lands Phones
How do ichange the time on Panasonic KX-T7431??
MUST BE DONE FROM EXT.101
1.leave handset in the cradle
2.Press "Program" button
3.Dial *#1234 (star pound 1 2 3 4)
4.Press Sp-phone button 3 times
5.enter the correct hour on the dial (2 digits)
6.press the button (in the lcd window to advance to minutes)
7.enter the correct minutes
8.press auto dial/store button
9.pick up hand set/ hang up hand set.
Oct 29, 2007 | Panasonic KX-T7456 Corded Phone
Panasonic KX-T7431 Corded Phone Logo
212 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
