Question about Hannstar AH-191D Monitor
Screen menu what do you mean, when you say screen menu?
    Brigadier General:
  • 10,406 Answers
Look at the buttons on the Monitor.
Push the one on the left.
It should start displaying the "OSD" (On Screen Display)
that has a "restaurant-menu" display of things-that-you-can-change.
Posted on Dec 10, 2009
Cm6040 unlock menu
Navigate the Administration menu
From the Home screen, touch Administration to open the menu structure. You might need to scroll to
the bottom of the Home screen to see this feature.
The Administration menu has several sub-menus, which are listed on the left side of the screen. Touch
the name of a menu to expand the structure. A plus sign (+) next to a menu name means that it contains
sub-menus. Continue opening the structure until you reach the option that you want to configure. To
return to the previous level, touch Back.
To exit the Administration menu, touch the Home button in the upper-left corner of the screen.
The device has built-in Help that explains each of the features that are available through the menus.
Help is available for many menus on the right-hand side of the touchscreen. Or, to open the global Help
system, touch the Help button in the upper-right corner of the screen.
The tables in the sections that follow indicate the overall structure of each menu under the Administration
menu
Aug 13, 2014 | HP Color LaserJet CM6040f MFP Q3939A...
Tip
Sony Ericsson service menu
this will open a secret service menu for most Sony Ericsson phones which helps u test all the services of the phone like the display, speaker or even the Mic and camera for any errors.Service Menu : >*<<*<*
> means right move joystick < means left move joystick
type this on the standby screen irrespective of whatever opens just type in all this in proper order.
rate!
on Jul 19, 2010 | Cell Phones
Brand toshiba lcd model 42HL167 no image but only menu dis ok
This could mean that the tuner board is bad. By saying "no image", does that mean that there is snow on the screen (i.e. from no signal received), or simply a black background or distorted image from bad reception? If the menu is displayed than that means that the image driving circuitry is working correctly.
Jul 19, 2014 | Toshiba 42HL167 42 in. LCD Television
I can't use the SET function key On Designer 1
The set function allows modification to the machine settings and has 5 or 6 sub-menues. Do you mean that the sub-menues don't come up upon pushing the set function on the screen? Have you tried pushing slightly to the right and left of the marked area? When you touch the screen for other functions (say programing), are those menues displayed? It may be that the touch screen functions are displaced from where they should be and the screen needs to be re-indexed.
Jan 30, 2013 | Husqvarna Viking 1
How do I use the Color Accent feature on my Canon Powershot ELPH 300 HS? It will only focus on green at the moment. No info in manual.
Once you select the color accent you should see the word " menu" in the bottom left hand corner of the screen with a down arrow next to a picture of a tube of paint. This means hold down the menu button for longer than a second, then you can adjust the color to be accented in your photos. Any time you see the word menu and the down arrow on the screen it means hold the menu button for longer than a second for more options/setting adjustments.
May 05, 2011 | Canon Cameras
How to change setting picture just opposite
If opposite means that you want to rotate the image or picture for projector mount in the ceiling.
KEYS location: (keys are located back side of the projector there is 2 keys 1 for menu and second is a joystick witch have 4 arrow keys and center press is a enter key)
Press MENU button to display the menu screen.
then use joystick UP and DOWN to select the OPTION menu. Press joystick for ENTER to display the option screen. Then press joystick UP and DOWN to select INSTALLATION.
Then press joystick RIGHT and LEFT to select your required image rotation there is four type of rotations.
1. FRONT DESK
2.FRONT CEILING
3.REAR DESK (A translucent screen is required for rear projection)
4.REAR CEILING (A translucent screen is required for rear projection)
If opposite means negative to positive so there is no any setting in your projector witch is chang your picture or image positive to negative.
Jan 21, 2011 | Panasonic PT-LB60NTE LCD Projector
My touch screen quit working
If the touch screen of your phone keeps working, then it means the sensor board of the phone is bad and need to be replaced, if you can access the menu of the phone, then you need to calibrate the screen first.
To calibrate the screen, you need to go to the menu, then you select settings, then you select calibrate screen then you follow the rest of the instruction from there on.
If calibrating the screen does not help you, then it means you have to fix the sensor board of the phone, if your information from the keypad reaches the screen, then it means you simply need to replace the touch sensor board of the phone.
Hope this helped.
Take care and good luck
Jan 10, 2011 | Samsung SGH-A877 Impression Cell Phone
Upside down picture how do you invert the images projected
Go to menu and select images and click arrow left or right to invert image position.
Mar 21, 2010 | Eiki LC-XB20 Projector Multimedia...
"Recommend New C-CRT" appears on menu screen ????
I would guess at:
"Recommend new Cyan Cartridge"
Cyan is the blue one.
Please rate me if you found this helpful.  Thanks.
Mar 06, 2010 | Canon PIXMA MX310 All-In-One Printer
Screen jumps back to prior screen
If you mean to say that the computer-generated displayed image on your screen changes, it's a function of the computer, not the monitor. If you mean to say that some monitor-generated displayed image is appearing (such as a setup/configuration menu or a splash screen), please tell us more so we can diagnose further.
Sep 12, 2009 | ViewSonic VP201b 20.1" LCD Monitor
Hannstar AH-191D Monitor Logo
80 people viewed this question
Top Hannstar Computers & Internet Experts
 Russ Hill
Russ Hill
memman
memman
Level 1 Expert
Are you a Hannstar Computer and Internet Expert? Answer questions, earn points and help others
