Question about HP Photosmart C4280 All-in-One InkJet Printer
Have a HP Photosmart C4280. Does this have wireless capability?
    Brigadier General:
  • 10,406 Answers
According to the manufacturer's web-site:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00870767&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=ca&lang=en&product=3192753
this printer utilizes a USB interface, not a wireless interface.
Further, it is _not_ supported by the HP Wireless Print Server product.
Posted on Dec 10, 2009
Testimonial: "thanks for the quick response!"
  • 37 Answers
No not possible
Posted on Dec 11, 2009
4 Suggested Answers
  • 23 Answers
SOURCE: How do I install ink cartridge for hp photosmart C4280
To replace the print cartridges
1. Make sure the HP All-in-One is on.
CAUTION: If the HP All-in-One is off when you open the print cartridge door to
access the print cartridges, the HP All-in-One will not release the cartridges for
changing. You might damage the HP All-in-One if the print cartridges are not
docked safely when you try to remove them.
2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
3. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
4. Wait until the print carriage is idle and silent, and then lightly press down on a print
cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge from
the slot on the right.
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridges
5. Pull the print cartridge toward you out of its slot.
6. If you are removing the black print cartridge in order to install the photo print cartridge,store the black print cartridge in the print cartridge protector or an airtight plastic container.
7. Remove the new print cartridge from its packaging and, being careful to touch only
the black plastic, gently remove the plastic tape by using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching
these parts can result in clogs, ink failure, and bad electrical connections.
8. Slide the new print cartridge forward into the empty slot. Then gently push the upper
part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
Work with print cartridges 69
Maintain the HP All-in-One
9. Close the print cartridge door.
If you installed a new print cartridge, the HP All-in-One prints a print cartridge
alignment page.
10. When prompted, ensure plain white paper is loaded in the input tray, then press the
button next to OK.
NOTE: If you have colored paper loaded in the input tray when you align the print
cartridges, the alignment will fail. Load unused plain white paper into the input
tray, and then try the alignment again.
11. Place the page print side down on the scanner glass and then press the button next
to OK to scan the page.
When the On
Please Don't forget to rate this solution. Thanks.
Posted on Feb 17, 2009
nalin_elliot
  • 224 Answers
SOURCE: my hp photosmart c4280 doesn't print. it won't **** the paper in. does anybody know how to solve this?
Try moving the rod that holds the rollers and see if that is loose.
If it is then you need to call up hp and either get a replacement or an upgrade printer with a 50% dicount on an upgrade and if your in warranty then yuor printer will be replaced free of cost.
If it is not loose then try cleaning the rollers with a cloth dipped in water and then try to put the paper in while holding it and see if it goes in this will help detect whether there is something loose with the pick mechanism or not.
Then disconnect the power cable from the printer press and hold the cancel and colour copy buttons and reconnect the power cable and then try to print and see what happens.
If all this does not resolve the problem then call hp at 1-800-474-6836 and ask either for a replacement if your printer is in one years warranty if its not I suggest you go in for the upgrade with atleast a 50% discount
Posted on May 30, 2009
bschilz
  • 2049 Answers
SOURCE: is the hp photosmart 8050 wireless capable or do i
The HP Photosmart 8050 is capable of using wireless when you purchase the HP Wireless Printing Upgrade Kit (Q6236A) 9f0c5cc.jpg
Posted on Oct 05, 2009
Is there any way to install my hp photosmart C4280 without the disk? I recently moved and can't find it. The conncetion point on the actual printer is damaged as well, so I can't simply connect it...
hello Jessica
kindly send me 4 thumbs up
you simply go to this site , select the OS you use and download the drivers for the printer, save on your desktop. make sure the printer is disconnected from your computer . install the drivers after they are downloaded and follow instructions-- very qick and easy
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=ca&dlc=en&lang=en&lc=en&product=3192753&
Aug 15, 2011 | HP PhotoSmart C4280 Laser Printer
Is the hp photosmart 8050 wireless capable or do i need to buy a wireless adapter?
Oct 05, 2009 | HP Photosmart 8050 InkJet Printer
Paper jam in hp photosmart c4280
What have you got to loose, get in there and try!
Mar 27, 2009 | HP PhotoSmart C4280 Laser Printer
Need to replace power cord for Photosmart C4280 All in One
Sure, you can find it on amazon for best price,click here and take a look Amazon com Photosmart C4280 power cord. I hope this was helpful. Cheers
Feb 10, 2009 | HP PhotoSmart C4280 Laser Printer
HP Photosmart c4280 region change
http://www.shopping.hp.com/supmodel/product/CC210A%2523ABA?jumpid=in_r329_search//photosmart+c4280_CC210A
please visit this page and try to solve your problem
Jan 26, 2009 | HP Photosmart C4280 Aio Printer
Have Vista,
the software may need to be reinstalled.
Nov 11, 2008 | HP Photosmart C4280 All-in-One InkJet...
Hp C4280 Photosmart
show me picture for installation the cartidge
Nov 05, 2008 | HP Photosmart C4280 Aio Printer
HP Photosmart C4280 All-in-One InkJet Printer Logo
101 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
