Question about Garmin StreetPilot C330 GPS Receiver
No volume will not give voice prompt
Unit stopped giving voice directions
  • Garmin Master
  • 2,130 Answers
Make sure you don't have the sound muted. Have you tried plugging in a set of headphones into the headphone jack? If you can hear sound with the headphones, most likely, the internal speakers have failed. If you still can't hear any sound, the audio output stage on the motherboardno volume will not give voice prompt - 1.gif has failed. In either case, you will need to send the unit back for repair. Be sure to have your serial number handy. Register it online https://my.garmin.com/mygarmin/marketing/register.htm
if you haven't already done so.
Hours:
Monday - Friday
8 a.m. - 7 p.m.
Central time (closed holidays)
1-800-800-1020 (U.S.)
1-866-429-9296 (Canada) or (913) 397-8200
Good Luck,
- Jim
Posted on Jan 23, 2008
Nuvi2550 has no audible voice prompts
have you cked if it is muted? touch the speaker and when the volume control comes up you can see if it is muted
Dec 05, 2011 | Garmin GPS
Voice is faint when giving driving directions. where is volume control on the gps
Most GPS units are touch screen friendly,if your unit has an icon that looks like a speaker,touch it & it should go 2 volume control mode.
Feb 17, 2011 | GPS
Speaker works for playing of MP3 songs but does not give direction instructions when on purely satnav. Have tried increasing/decreasing volume but no sound comes out of the unit. Have also done a factory...
spoken directions are only available when the computer generated voice has been activated. If you choose any other voice, you will no longer get spoken directions
Oct 05, 2010 | Tomtom GO 730T Car GPS Receiver
Garmin Nuvi 265 wt...how to get voice command to work?
this may require two sessions but - here goes:
1- turn the unit on - select the VOICE icon on the opening screen - triple check it isn't muted and change it to 90% voice volume.
If this doesn't give you sound WHILE DRIVING - it won't give you voice unless you're moving or driving.
Then - turn the unit off - Turn it back on- - as it is starting up - and blank- place your thumb in the LOWER RIGHT CORNER of the blank Screen.
this will open this window:
SELECT - YES - it will reboot and your minor settings will be lost - like saved address and favorites - not your updated maps.
This will reset you to default NEW -
When done - sound will be as it was when new if no sound - return for repair.
May 06, 2010 | Garmin n?vi 265WT Car GPS Receiver
There is no sound when giving directions it just shows the image? how do i get the voice to speak the directions
little box at bottom of screen with cone/speaker touch and volume setting should appear, the n adjust. if that dont work faulty unit, also check "voice type " is correct
Dec 27, 2009 | Garmin nuvi 205W GPS Receiver
It just stopped talking. No voice directions, on
Hit the menu buttom, go to settings, then go to volume and see if it is muted. Sounds like the mute or volume down button got inadvertantly hit and turned down or muted. If this does not work, turn the unit over and look under the fold up antenna for a reset button. Depress this button until the unit restarts and should reset the unit back to factory default settings and get you on your way. Good luck!!! If these don't help you, call the garmin support number at :1-800-800-1020. Hope this helps!
Aug 01, 2009 | Garmin nuvi 885T GPS Receiver
Audio directions
You must ensure that your volume is not on mute. You need to tap on where the words are, not on the map, until the volume slide bar pops up. You may have to tap in different places until it does. If your volume is set normally, you need to check on which voice you have picked. It's under the options. Pick a different voice and test out the directions.
Aug 09, 2008 | Tomtom GO 910 GPS Receiver
I can't seem to enable to voice prompts
Taken from the Garmin website:
"This error is most likely caused because the voice files need to be reloaded onto the iQue. Insert the iQue setup disk and select 'Install Software'. Then select 'Change voice'. Then select the voice to be installed on the device. When the voice files are finished installing, perform a Hotsync. The voice guidance files will then be restored to the unit and the voice prompts should work correctly."
Feb 26, 2008 | Garmin iQue 3600 GPS Receiver
Voice Navigation
Check your voice prompts.  make sure you are using either Jack or Jane.  the standard voice is the same as the voice on C330 which only gives you directions.
Oct 10, 2007 | Garmin StreetPilot c340 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
100 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
