Question about Samsung SpinPoint P120 SP2514N 250 GB IDE Hard Drive
Is my hard drive broken? Cant get it recognised on other PCs
I have a Samsung SP2514N 250gb 3.5" pata internal HDD that I am trying to get recognised on a laptop I bought with Vista apps. The case enclosure I bought for this is an Akasa Integral usb 2.0 interface for 3.5" IDE device. Unfortunately, although the computer recognises the manufacturer and model no and says the software for the hdd was successfully installed, it does not seem to read the files on the disc. Consequently I have not been able to do anything with it
I'm having a similar problem with the same Akasa integral enclosure, so far I have tried 3 different hard disks and not one of them will work properly and on two different computers.. , all of the hard disks I've tried are Samsung .. but I'm sure that makes no difference. I plan to send back the enclosure to where I bought it from and get a different one from a different manufacturer.
Posted on Mar 08, 2010
I have an Acer 3002LCi laptop. I upgraded the RAM to the maximum 2GB. I also installed a WD Scorpio Blue PATA 250GB HDD. I installed Windows 7 from disk and computer shows drives C and D but drive C...
Install a partition manager program like
http://www.partition-tool.com/personal.htm
open it and you will see the entire hard disk. In there either create another partition in the unallocated space or add it to the D partition.
Mar 23, 2011 | Western Digital Scorpio Blue 250GB PATA...
I have a Samsung SP2514N (250GB/7200rpm/8M/PATA) drive that I am trying to use as a USB drive on my laptop with Vista on it. The device manager shows that there is a drive there, but that is all. It does...
If your using an external drive case, the jumper pins should be set at "single". If that doesn't work you can try moving the jumper till the drive shows up, or use no jumper at all. If it still doesn't work after trying all jumper positions or no jumper then the drive could be bad. Make sure to power off the drive before changing the jumper.
Feb 15, 2011 | Samsung SpinPoint P120 SP2514N 250 GB IDE...
My Samsung 250 GB portable HDD is not recognised now. It was working for last 2 years without any problem. Recently I found my PC infected by "WIN32" & Torjan viruses. It may be the reason. But I tried...
Try connecting it to another computer.
If it does not work, then either the disk-drive has failed,
or the USB-cable is damaged,
or the USB-to-disk-drive interface inside the case has failed.
Is the SAMSUNG still under warranty? (1 year? 2 years? 3 years?)
If so, SAMSUNG will replace it, at minimal cost to you.
Sep 25, 2010 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Can i make my 80GB hard drive to 100GB? 80GB 7200rpm SATA SAMSUNG
This is not possible, 80Gb is 80Gb and 100gb is 100gb, but I am afraid, even if you like to replace, you'll not be able to get 100gb since it's no a standard Hard disk capacity. If you are trying to upgrade, then you can find 120gb, 160gb, 250gb, 320gb etc... Good luck. Thanks for using FixYa.
Jun 06, 2010 | Samsung 80GB INTERNAL 3.5- IN SATA HDD...
I need a sp2514n hard drive
http://www.amazon.com/Samsung-SpinPoint-P120-SP2004C-internal/dp/B000BONHS2/ref=sr_1_fkmr0_1?ie=UTF8&qid=1265381348&sr=8-1-fkmr0
this link will solve your problem..
plz give vote and ratings..
Feb 05, 2010 | Samsung SpinPoint P120 SP2514N 250 GB IDE...
PS3 hard drive transfer
seagate eSATA 250gb hard drive, the PS3 uses a laptop sata drive, how you get this to work?
You have basically have 2 options you could try:
Use Linux for retrieve the data of get the original mainboard back.
The PS3 + HDD bonds together, so if you were to save stuff eg, online purchases, you need to have the same account for max of 5 downloads to 5 differenct units, BUT you cannot just swap out the HDD and expect it to work. The PS3 has a feature to backup from internal directly to an external USB hard drive but online limited to data, most purchased movies and/or MP3 will not be transferred, it sucks.
You can have as much HDD you want but only YOU can use them , cannot be shared with another PS3. I hope that helps a bit
Jun 16, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
ASUS VIA KT133
Your motherboard does NOT support SATA drives, without an added SATA controller. It does support PATA drives, such as the Samsung SP2514N and the Seagate PATA drive you listed, as well as any other PATA drive. A PATA drive may be referred to as PATA, IDE, ATA100, ATA133, or even ATA66, but not SCSI, Ultra320, U320, or SATA, SATA II, SATA100, SATA300, etc.
The Seagate drives are easy to identify, their model number ends in AS if it is a SATA drive, and just A if it is a PATA drive.
Dec 05, 2007 | ASUS VIA KT133 Chipset A7V133 Motherboard
Samsung SpinPoint P120 SP2514N 250 GB IDE Hard Drive Logo
632 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
ismael castillo
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
