Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Stove top pilot light
I have a GE XL44 and the stove top burners will not light automaticly. I have to put a external flame to the gas when turned on. It looks like there is some sort of ceramic heat module that the burner sits on that should maintain enough heat to generate the gas to ignite when knob is turned. How does the pilot stay lit if not through this ceramic knob?
  • 4 more comments
  • Anonymous Jul 07, 2008
    yes
  • Danforth262 Mar 09, 2009
    I have GE XL44
    after long absence - top burners would not light without match to burner. Can't light the pilot. ND
  • Greg Bowman
    Greg Bowman Jan 26, 2013
    The GE XL 44 series does not use "pilot lights/flames" for ignition on any of its burners. You can't light what is not there..
  • Greg Bowman
    Do year hear "snap,snap,snap" when you slowly turn the knob to the red "light" section of the dial?
  • Anonymous Mar 25, 2014
    the "burner on" light stays on even when stove top is turned off
  • Anonymous Mar 29, 2014
    Light stays on after turning off burner
I have a GE Gas Stove XL44 the stove top buners don't light by themselves without manual lighting. When I turn on the buner knob the buner doesn't click. Also I used my self- cleaning oven for the first time and stopped it before the time was up after that is when the stove top buners wouldn't light by theirselves.
Posted on Feb 08, 2008
Oven pilot light won't light. Stove burners work fine.
if you have a pilot flame oven replace your thermocouple
if you have a newer oven you will have an ignitor
please advise me on whitch type of oven you have
Feb 05, 2013 | General Electric ge JGBS04BPW wb1k5 Oven...
I have a GE Kitchen range XL44, stove top burners work fine, but oven won't light??? HELP please
Unplug the range.
Remove the oven racks.
remove the oven base pan.
remove the flame spreader pan.
remove the glow bar ignitor on the left hand side of the gas burner and replace it with a good ignitor.
Jan 25, 2010 | GE Kitchen Ranges
The oven pilot does not light. The broiler will not work. The only thing that does is the light. GE XL44 range. The burners light and the pilots stay lit.
    If you have standing pilots, make sure the pilot for the oven/broiler is lit as well.  When you turn the thermostat up to call for heat, you should see the pilot get larger. That larger pilot flame heats a hydraulic sensor and opens the main burner valve.
    Jan 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
    Where is the pilotlight on a ge xl44 gas stove I belive it is in the door under the oven well I turned the gas on and stuck a flame down there and nothen took off is there a certian place to put the flame....
    In general lets be clear. The OVEN pilot is located under the oven door at the top of the Broiler.It is a small piece of metal just before the GAS safety Valve which acts on temperature so gas won't flow unless Pilot is lit,That's the OVEN PILOT.The stove's RANGE is the top burners where you heat Pots and Pans.It has either 2 Pilot lights that connect the burners to the Flame they are under the Range Top.Newer Models use electronic ignitions no flame.Please note if you had your stove/oven disconected or Gas off when you turn it back on there will be air in the line that needs to escape before you light.This is why in NYC when Utility Co.works on steet main the MUST re-light your appliances.Be Careful with Gas.Good Luck.
    Sep 19, 2009 | Ovens
    Xl44 oven burner pulses, doesnt properly heat up.
    it seems the burner in the oven is clogged, by grease, carbon or corrosion, it may need replacing, specialy if this is an older unit
    Jul 30, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
    For the GE XL44 model, where would i find the pilot light? the stove is not working
    There is not pilot light on the stove top since the burner is activated by a spark generate by high voltage to a small ceramic disk with a wire protruding from it by the burner.
    You have the have AC Power to the stove and you should hear a clicking when you slightly turn on the burner. Once the burner is on fire then turn the burner control to the desired temperature. If the burner will not light after 4 seconds of clicking sounds turn the burner control off and make sure the round gas diffuser on top of the burner is correctly seated on the burner. It should lock in place and is removable for daily cleaning of the stove. Now try the burner control again in the light position for no more than four seconds to see if it lights.
    Do you smell gas? Do you hear clicking when slightly turning the burner knob? If yes to both the stove is working and the top of the burner is not seated correctly. If no on either or both you may have a stove, electrical or gas problem.
    Jul 11, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
    Getting to the Pilot
    Your model JGBP28DED2WH uses spark ignition on the stove top burners, and a glow bar ignitor, part number WB2X9154 for the oven and broiler. To get to the bake ignitor if oven will not light: Take the racks out of the oven. Remove oven floor by removing two screws at back of oven floor and lifting floor. Remove the square metal flame spreader to get to the burner / ignitor assembly. (note: The ignitor may still glow when you try it, but usually is still the problem)
    Feb 22, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
    Gas oven dosnt work
    the pilot light is there for 2 purposes. number 1 to light the burner and number 2 to heat up the thermocouple, thermocouple is a wire that the flame from pilot suppose to surround by fire. if the pilot is to low it will not reach the thermocouple. you can take the gas line that supplies gas to the pilot and clean it with a safety pin or a small needle. you can test the thermocouple by heating it up with a blow torch on low heat, get it red hot and then turned on the oven. if the oven works clean the pilot, if the oven do not work, replace the thermocouple if separate from safety valve. if thermocouple is part of it replace the safety valve.
    Dec 14, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
    Ge xl44 I think pilot not lit. no more snap - snap and does not light
    relace spark module if no snap snap from all burners.If one is just bad replace ignitor.
    Nov 21, 2007 | Hotpoint RGB745 Gas Kitchen Range
    GE XL44 Gas Stove
    Hi I have a GE X44 gas stove. The 4 top burners work just fine, but the oven no longer turns on. I don't see the blue flame inside the oven. Is it safe to relight the pilot light?????
    Nov 08, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
    GE Profile Spectra JGBP90 Gas Kitchen Range Logo
    2,583 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Craig Butler
    Craig Butler
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
