Try unplugging and replugging. Apparently it does a reset of something. It worked for me. I would make sure you don't have to much laundry in the machine too.
Manual for models WM2277HW & WM2077CW says: Possible Cause is "Overload in motor" Solution is "Close the water tap, unplug the power plug, call for service"
SOURCE: LE code
LE error is a locked rotor you need to have your hall sensor on the stator or better yet just have the whole stator replaced which comes with the sensor on it (P.S. the stator is part of the motor and has a 5 year warranty)
SOURCE: Error code LE on LG Wm1815cs
Error OE appears after about 10 minutes into a cycle. "OE" in the manual says filter clogged....we have checked & cleaned all of the lines/filter. Now we hear a light humming instead and the washer isn't doing anything...
SOURCE: Error code is LE. Washer fills up with water and
If water runs in when the machine is OFF but stops when the tap is turned off it means a faulty watervalve.replace water valve. Probably a double valve. Dont mix up the hoses or the wires........Nomess
Washer Not Filling:
If the appliance is not accepting input from the control panel, follow the steps below to reset the control:
