Question about GE Profile PFS22 33" Artica French Door Refrigerator w/ 22.2 Cu. Ft. Capacity, ClimateKeeper System ...
Water won't come out of the dispenser. I Checked to the door and the water works to the door, but won't come from the dispenser.
  • Mark Egan May 11, 2010
    Two things to check - 1) Water solenoid on the lower back of the refrigerator. If it fails, then when the ice maker is told to fill, water does not flow from the water supply. 2) Water filter is clean (had the same thing happen to me until I stopped getting water out of the door.).
Open the door, place a blanket over the opening to keep yopur food cold, and use a blowdryer on medium to warm up the inside of the door in the area where the water comes out. It should thaw the line.
I had the same problem yesterday, and the water was flowing normally in about 10 minutes.
if you dont have a dryer, it will thaw on it's own, but may take a little longer
Posted on Dec 10, 2009
  • GE Master
  • 1,606 Answers
Try turning the dispensor light on for several hours , so the heat , will thaw the line . Also , raise the freezer temp slightly . GE , also has a dispensor heater , pt # WR49X10173 , which comes with instructions , you can install , to keep this from happening again .
Posted on Dec 11, 2009
2 Suggested Answers
sdmc73
  • 121 Answers
SOURCE: Ice Maker works but water dispenser does not.
tank can freeze up check timp the tank is in the food compartment at the bottom in the very back
Posted on Nov 29, 2008
Water dispenser not working
!!BE CAREFUL!! High Voltage.
Try applying power to the solenoid for the water tap. Should be two of them one for the ice maker and one for the water dispenser. They will usually be mounted in the rear bottom on the other side of where the water supply line is connected. 25269512-pjjowy2zt3xf3430cawieg0f-2-0.jpg
Example ^^. If it triggers put a meter on it to see if it energizes when you press the water dispense button.
Nov 04, 2014 | Refrigerators
Water stopped coming out of door dispenser
A few videos about refrigerator water dispensers.
Might not be exactly the same as yours.
Samsung won dispense water YouTube
Oct 05, 2014 | Samsung RF4287HA
Ice switch dispenses water
If the refrigerator water dispenser is not working correctly the water supply tube in the door may be blocked. This will be difficult to track down. Look for a connection point at the bottom or top of the door, try removing the hose and blowing air through it and out the dispenser. Next it could be the water valve that sometimes has twin valves for ice and water combined, third is low pressure into the line (bad main valve) or clogged filter... you need about 20psi for function. Last is the door switch, when the freezer door is opened the freezer door switch does two things, it turns on the light in the freezer and turns off the ice and water dispenser. If the door switch fails the dispenser will not turn on or may just dispense one item. The switch can be checked for continuity with an Ohm meter. If it doesn't have continuity it should be replaced.
Apr 27, 2014 | Samsung RFG297AARS (285 cu ft) Bottom...
Have you changed the water filter? they can plug up over time. The water tube can freeze in the door. To test this there usually is a disconnect under the freezer door side of the grill you can disconnect this and hit the water dispenser lever. If the door is getting water then it is frozen in the door. If not the water valve could be your problem there are two sides to the water valve one for the water dispenser and one for the icemaker. A last possibility is there is a water tank or tubing loop in the refrigerator behind the crisper this could have frozen.
Feb 10, 2014 | Refrigerators
Changed out water valve. not getting water out of dispenser now
Check for voltage at the valve when the dispenser paddle is depressed, if you have 110 volt or higher you switch and door is functional. Disconnect the water line under the freezer door and hit the dispenser paddle again. If you have water there then the door is restricted inside the freezer door (most likely ice).
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Dec 06, 2013 | Hotpoint HSS25GFP Side by Side...
Water won't dispense
Which pump did you replace? Are there a few?
May 13, 2013 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Frigidaire water dispenser won't work with new filter
The dispenser has a dual water control valves that control ice maker water and dispenser water. To find your parts you will need your refrigerators model number most time found around the fresh food sections door. Below I have a tutorial that may help you determine what may be the problem with dispensing water. Hope this helps, Thanks Sea Breeze
Oct 05, 2012 | Frigidaire Refrigerators
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
My water dispenser in my GE refrigerator does not dispense water. The same lever that dispenses water also dispenses water. I have checked the ice and water selenoids and they are working. The cooling coil...
We have an Electrolux Wave Touch with the same problem.
1 yr later, 3 new fridges, 1 new freezer door and no solution.
Yes, the line is clearly frozen inside the door.
Disconnect waterline at bottom of freezer door and activate solenoid - then you know for sure.
Oct 05, 2009 | GE Refrigerators
Ice maker and now water dispenser does not work
Do you get water to the connector at the bottom of the freezer door ? if you do then the water pipe in the door is probably frozen - read new door ! if not then check thw electrical connector at the bottom of the freezer door as they have a habit of corroding.
Feb 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile PFS22 33" Artica French Door Refrigerator w/ 22.2 Cu. Ft. Capacity, ClimateKeeper System ... Logo
379 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
Sometime Mechanic
