Question about Dremel Tools & Hardware - Others
Is the Dremel 2600 Project Table strong enough? The legs look wobbly and likely to collapse with a bit of downward, lateral pressure. Dremel U.S.A. test marketed the Project Table in 2008 with Ace Hardware, one of their largest retailers. It was not well-received by customers and Dremel U.S.A. has chosen not to carry or support it in 2009. I think that Americans saw it as being for light hobby use and, therefore, not a real tool to own. The Project Table remains available in just about every other country.
    Top Expert:
  • Dremel Master
  • 29,438 Answers
The Dremel by default, is for hobby use only.
Posted on May 06, 2017
SOURCE:
rowdy45176
  • 2176 Answers
SOURCE: Dremel scroll saw 1672 16'' two speed scroll saw slow motor
Go to Dremel.com or call toll free1-800-437-3635 and tech service might be able to get you a schematic and wiring diagram. It does sound as though the switch is either wired incorrectly or put in upside down. If I have helped you on this would you please take the time to rate me accordingly and Thank you
Posted on Apr 22, 2009
buffalonyman
  • 1865 Answers
SOURCE: My Delta 10 inch table saw stopped working in mid-saw
you have to use a meter and check the voltage at the switch and to the motor.
Posted on Oct 09, 2009
  • 7353 Answers
SOURCE: Compress FRONT Caliper on 2008 Town Country
No special tools needed. If the piston wont go back it, you may need a caliper. Some cars use a Phenolic Piston and they can stick.
Posted on Dec 17, 2009
  • 19466 Answers
SOURCE: want to replace under powered saw motor on sears 10"table saw
u can put a 2 and above if u want just need to have the correct rpms
Posted on Jan 26, 2010
  • 9 Answers
SOURCE: Table saw capacitor heats up and explodes.
The wrong capacitor for one thing. There are starting caps and running caps. The starting cap is in the circuit for only long enough for the motor to get up to speed. If you have a Leeson motor that has a start and run cap then the run cap may not be the correct on. If you have a start cap blowing out I suggest you check the centriifugal switch in the end of the motor. It may have welded the contacts shut. In any case, I would take it to a motor shop .
Posted on Apr 04, 2010
Once the bit is tighten, the motor is to tight to run. It runs for half a second then freezes up
It sounds as though you have a motor problem, The bit, tight or loose shouldn't matter.
Sep 30, 2014 | Tools & Hardware - Others
Exctly what fits what
Go to Amazon and do a search for "dremel drill chucks". There are a variety of models that will close down to '0' to allow use of bits as small as #80. Make sure and look at the low end capacity and make sure it will go small enough for the size bit you want to use. I have used to #4486 to use micro drill bits but it is not rated to go that small and can cause wobble and break the bit if not very careful. They are pretty cheap so you can try a couple different models even.
Aug 10, 2014 | Dremel 3000-2/28 2 Attachments/28...
Cannot release tool from Dremel 300
I had a similar problem with a router, the best way to do it is to get a clamp, a strong metal c clamp, not too big but big enough to fit chuck into, line one side of clamp up with button and the other on the chuck. tighten the clamp as tight as you possibly can so it presses and holds the button in, and does not slip. Then use a wrench or whatever tool you use to undo the chuck. if this does not work, try spraying some WD40 on and leave to work for a few minutes.
Feb 21, 2014 | Dremel Tools & Hardware - Others
I would like to know where I could find a manual to explain and show which dremel bit works for different techniques of glass etching.
Search UTube "glass etching with dremel tool" for videos.
http://www.youtube.com/results?search_query=glass+etching+with+dremel+tool&aq=f
Whenever I get new product, I search UTube for GE water heater, table saw, Cad drawing, etc.
Feb 12, 2011 | Dremel Garden
How to remove old hard grout from walls
There is no easy method that I have found over the years. The best thing that I have found is a speciality bit made for a dremel rotary tool. I believe it is made of titaninum and it is made to cut ceramic tile. They are not cheap or fast but they will get the job done.If you are dealing with a grout that is not portland cement base then dremel also makes several carbide tip cutters that will work.
This is a time consumining project and if you try to grind it out I would strongly recommend you use a good qualility dust mask. I hope this helps you and good luck. Thank you.
Feb 10, 2011 | Home
How do i take the bit off of a dremel multipro model395 type 5
unscrew the collet nut, and then if it's still stuck, tap the end of the bit on the table or something solid. It'll come loose then.
Mar 16, 2010 | Dremel Variable - Speed Multipro Rotary...
My wife's kitchenaid classic 250 watt mixer wobbles on the base
It sounds like your mixer likes to take a beating, ive never dropped one and for good reason, they weigh quite a bit. first check to see if all the rubber legs on the bottom are still there. if they are the only possible solution to fix it after being bent or warped is to either re-shape the part using a tool strong enough to do the job, or to replace the parts needed. the hinge pin part number is 16910. is the base is bent the part number is 240151-1. If the lower portion of the mixer itself is bent or warped this is a serious problem and will require you to dissassemble the entire unit. part number for the lower gearcase is 240350-4 Please not that all the parts list are white in colour. hope this helps.
Thanks
Oct 11, 2009 | KitchenAid K45SS Classic Stand Mixer
How do you collapse the little tykes picnic table?
Flip over the picnic table and have a screw driver ready. There are 4 "braces" screwed into place to ensure the picnic table does not collapse on your children.
Once the braces are removed, you should be able to apply just a bit of pressure and fold the picnic table down flat.
Sep 29, 2009 | Little Tikes Fold and Store Picnic Table
Washer must be out of balance
The legs on the washer are adjustable, the rear legs are often ( not always ) self adjusting, make sure the legs are not stuck and that they can move freely. But the front legs can screw in and out to move the washer depending on the floor the washer is sitting on. Make sure the washer is as low to the floor as possible. When the legs are screwed out too far the washer becomes wobbly. Often on the metal style legs there are lock nuts that can be tightened to secure the legs so they don't move on you. washers where really meant to sit on a cement floor, if your washer is on a wooden floor look carefully at the strength of the floor. If the floor is moving up and down when the washer is running, the floor may not be strong enough to support the washers weight. Most main floor laundry rooms floors are nailed down, the sub-floor is more secure if the sub-floor has been screwed down. Sometimes extra support may have to be added under the flooring to add some strength
Jan 08, 2009 | Admiral AW22 Top Load Washer
Drum wobbles too much
sounds like you have got either a collapsed suspension leg or your bearings gone
Jul 21, 2007 | Maytag PAV2300 Top Load Washer
Tools & Hardware - Others Logo
778 people viewed this question
Top Dremel Tools & Hardware - Others Experts
cluffermon
Level 1 Expert
Mike
Sheldon Dedek
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
