Question about LG LSC27931S Side by Side Refrigerator
Lg side by side refridgerator ice maker
My icemaker is producing ice really, really slow, how can I fix this this problem?
    Scholar:
  • 49 Answers
You can adjust the control for the freezer side to a colder setting think of the freezer control as a door warmer setting door open farther colder setting door farther closed the fridge control is electric that runs the compresser can turn fridge down to creat more cooling freezer or set freezer to colder setting it is a balancing
act have actually closed freezer control to coldest setting and had items freeze in the fridge side where air from freezer first enters fridge a lower temp in freezer should help ice production
Posted on Dec 10, 2009
How to trouble shoot GE ice maker that is not producing ice
Here is some information for you to study
  • GE Refrigerator - Ice Maker Not Making Ice - Easy Fix and ... www.youtube.com/watch?v=fPeZ29XdX5U
    • BY DIGITALPIMPLE
    • 4 MIN
    • 295K VIEWS
    • ADDED 2013-05-15
    Video embedded · How to fix your GE Refrigerator if it stops making ice. Easy quick Ice Maker fix if your ice tray suddenly stops filling. Check for this issue before going ...
  • How To Fix Refrigerator That's Not Making Ice ' Fridge Repair www.partselect.com/Repair/Refrigerator/Not-Making-Ice Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common ... can cause a refrigerator's ice maker to not ... GE Parts ...
  • Icemaker Not Producing Ice - products.geappliances.com products.geappliances.com/appliance/gea-support-search-content?... Icemaker Not Producing Ice. To minimize the possibility of electric shock, unplug this appliance from the power supply or turn the house circuit breaker/fuse to the ...
  • New Icemaker Not Producing Ice - GE Appliances products.geappliances.com/appliance/gea-support-search-content?... New Icemaker Not Producing Ice. If the refrigerator icemaker has just been installed, there are a few things that must happen before it can produce ice:
  • Jan 02, 2016 | GE Refrigerators
    The Ice maker in my mother in laws Hotpoint CTX21 refridgerator is no longer producing ice. I have water pressure in the water line going into the "valve" at the bottom rear of the fridge. And...
    Replace the icemaker. It sounds to me as though the harvesting thermostat has gone bad and it would cost more to have a serviceman fix it than to just buy a new icemaker. This is a common problem that I've seen so many times !
    Sep 29, 2017 | Hotpoint 21.7 cu. ft. Side-by-Side...
    The icemaker is not producing ice. Water is not going into the icemaker to produce the ice.
    Here is a tip that I wrote about the reasons why ice makers do not work.
    Ice Maker Problems and Ice Maker Troubleshooting
    heatman101
    Oct 30, 2010 | LG LSC26905 Side by Side Refrigerator
    LG icemaker not making ice since new filter installed
    Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
    Mar 27, 2010 | LG LSC26905TT Side by Side Refrigerator
    Ice maker in refridgerator freezer won't make ice. It seems as if the water is going up into the freezer but no Ice is being produced. The ice tray has frozen ice in it, but it will not dump it in the ice...
    Sometimes icemakers get all frozen up, such that the motor cannot turn to eject the ice. Also, in some cases the water supply line freezes up, although that does not sound like your problem.
    Try leaving the freezer open to defrost it manually and see if it starts working by itself. Also, the icemaker motors can and do fail. In some cases you smell an acrid burning smell when the motor fails.
    Oct 16, 2009 | Kenmore 50522 / 50524 Side by Side...
    Maytag fridge no water to icemaker any suggestions
    Pour about 2/3 cup of water into ice maker . If it freezes and dumps , replace the water valve . If it does not dump , replace the icemaker . Also make sure the coils are clean beneath refrig , and the clear fill tube , which fills the icemaker , is clear of ice (not frozen up ).
    Sep 12, 2009 | Maytag MSD2756G Side by Side Refrigerator
    Ice maker not making ice
    either the thermostat is bad or the heater isnt working. You could take the icemaker out and connect leads to the heater to see if it warms up or use an ohm meter to test the heater and thermostat. Also take the cover off and see if the cog wheel on the motor is broken.
    Apr 29, 2009 | Kenmore Freezers
    Ice Maker
    well ur refrigretor is;nt producing enough gas to produce ice make sure u hire some expert who can examin and solve it.
    Mar 18, 2009 | Amana ARSE66MB Side by Side Refrigerator
    Whirlpool side by side refridgerator model GS6SHE*N*O, icemaker won't produce ice. Watter line is okay. This is only 6 months old.
    make sure your ice maker is turned on and if it is a new install than it will take about 24 hours for the first bin of ice witch you will need o throw away because it is like the first snow the first ice that comes out will have the dirt and things that are in the line.filter and ice maker.
    Aug 22, 2008 | Whirlpool Refrigerators
    Kenmore Side By Side Refrigrator ICe Make Not working
    Is the icemaker producing ice and it's just not coming through the door? Or is the icemaker not even producing ice???
    Mar 01, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
    LG LSC27931S Side by Side Refrigerator Logo
    412 people viewed this question
    Top LG Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Mike
    Mike
    Are you a LG Refrigerator Expert? Answer questions, earn points and help others
