Question about JVC RX-ES1SL Receiver
Home theater reciever
The display portion doesnt turn on ....the red standby light is on but when I turn the power on it goes off instead of turning green and the display comes on...then it automatically shutss off by itself can somebody please help me?
Check the internal fuses havn't burnt out. Remove the main cover. There are 4 glass fuses.
Posted on Jul 07, 2008
Only red standby light comes on,Hit power button on remote, light goes out,unit turns off and have to replug into wall to get red light on.
There would be some problem in the output amplifier stage. Thats why its going to protection mode.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 18, 2016 | Audio Players & Recorders
No power output or display.green standby light flashes.
Sounds like either a blown mainpower fuse or the thermal fuse for the power transformer. If the protect circuit was kicking in, the display would light up, but then turn off with a red blinking light. the green light with no display means the transformer is not getting power.
Dec 31, 2013 | Denon Avr-1610: 5.1 Ch A/V Home Theater...
I have SC-PT750 Wireless system with SH-FX65T and SE-FX65, the wireless does not work and the screen flashes W1 to W2 and the SE-FX65 red light stays on
1 Turn on SE-FX65 2 While pressing [>>/>>'] ] press the numbered button [3] on the remote control until "P" lights in the home theater unit's display The indicator on SE-FX65 turns green. 3 While "P" is displayed, press [I/D SET] 4While pressing [>>/>>'} press the numbered button [3] on the remote control.
This worked for me. I moved and lost the FX65A, and Had to buy a replacement off ebay,
Used this manual http://www.specsserver.com/CACHE/FRQUJVMNXTYS.PDF but I have to give mosyzlak props, cause he gave me the idea to look for it.
Nov 28, 2010 | Panasonic Home Theater System System
I have a HTS3410D Home Theater system. I cannot
a blinking or pulsing power light usualy means a problem with the power supply. Check for burned resistors or swallen capacitors on the power board it will be the one with the one with the main power running to it.
Nov 17, 2009 | Philips HTS3410D/37 700W DVD Home Theater...
My (Techwood 400 Watt Home Theater Receiver PLR85) won't turn on
I have had the same problem.
You have a faulty cooling fan.
The system senses the fan isn't working, and knows that without it, it will over-heat. So it goes into a "self-protect" mode - hence the green light.
You need to replace whatever part of your fan has gone bad.
Ryan
Franklin, IN.
MusicManRyan@hotmail.com
Jun 06, 2009 | Audio Players & Recorders
Wii standby light
To be precise, you can turn this option off from the Wii System settings -> Wii Connect 24 -> standby connection -> off
When this setting is swiched to off, your console shuts down entirely and there is a RED light on the power button. There will be no need to turn off the console pressing the power button.
Jun 10, 2008 | Nintendo Wii Console
Won't Turn On
Try reseting the system. Instructions below.
DVD reset procedure for TH-A10
1. Make sure there is no Disc in the tray.
2. Disconnect the power cord.
3. While Pressing "Stop" and "Open/Close" buttons together reconnect the power cord
4. Front display will show "TEST0".
5. Then the display will change to : "TEST1 JC2".
6. Press "Enter" button on the remote, display will show "EEPROM"
7. Press "Power" to shut unit off.
8. Reset is finished
Jun 01, 2008 | JVC TH-A10 System
Akai LCD TV wont turn on
Hello davidshu,
The issue seems to be a power supply problem. The television has a switching power supply. This might be the problem. I would suggest getting it repaired at a television repair shop due to the possible complexity of the work that needs to be done.
Apr 16, 2008 | Akai LCT3201AD 32 in. LCD Television
Unit won't allow me to change modes
If you're NOT still under warrantee you should at least open the reciever and look for a blown fuse near where the power cable enters the set. If it is blown, it will be obvious and make sure that the set is unplugged before replacing it. If it blows again, or if it is not blown, your problem is probably in the 'X' volt regulator and you will need professional help with the repairs. You can also check the board where the components are mounted and resoled any that look bad. Brief power outages may cause the receiver to turn off on its own. If you are using a surge protector, try connecting the set directly to the wall outlet. In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint at the horizontal drive transformer. All can be replaced at a local electronic or hardware store and they're easy to replace If this does not correct the problem, you may need to have your reciever serviced.
Jan 17, 2006 | RCA RT2380 Home Theater System System
JVC RX-ES1SL Receiver Logo
479 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
