Question about Uniden Cordless Phone
Charging problem I bought a cordlessphone yesterday (X475-3) It has 3 handsets, only one will charge. It will charge on the main base and the 2 remote bases. The other two handsets will not charge anywhere. The charging contacts are clean. Can you help me out ?
  • 3 Answers
The fact that one charges on all 3 base units rules out any problem on the base units. Sounds like the batteries on the 2 faulty handsets need to be replaced. I suggest you return it to the store, and get yuh money back, or replacement
Posted on Dec 10, 2009
Handset 1 not charging on either base unit
Check to see if there is any build up on the contacts that voltage flows through and clean it with DEoxit
Feb 24, 2016 | Idect Solo Vintage Styled DECT Cordless...
I have no ringtone and the phone is flashing base. All okay yesterday. I have tried it on the other base and it is the same, so I assume it is the handset.
check radio base where one of the bases plugs into phone line. Check power and check phone line plugged in properly.
All other bases are just charging phones. !
Nov 12, 2015 | Siemens C300A2 C300A-2 C300A 2 Gigaset 2...
Phone not registered
Hi Chris,
This is usually an issue that is solved by placing the handset of the charging base. That way, it is "registered" with that base. This helps prevent someone with the same phone from accessing your telephone line to make calls, etc. The thinking is that if the phone can contact the base, it must be "ok" to use. Try placing the handset in the main base - those remote bases - that provide "charging only" may fail to register the handset.
If you still have problems - please provide the manufacturer's name and model for the base and the handset(s).
Mar 01, 2013 | Lands Phones
How to conect the phone to the base?
Enter the model of your VTech phone into the search box here to download a copy of the manual.
Jan 10, 2013 | Lands Phones
Base Unit of DECT2000 Uniden Phone system (5 Handsets) went dead
You may have a defective battery, 90 day warranty.
Mar 18, 2009 | Lands Phones
Adding a new handset
You need to register the new handset with the base.
In Global settings De-register the new handset then place it on the main base unit connected. It should then register.
Jun 30, 2008 | Uniden TRU8885 Cordless Phone
Panasonic KX-TGA101S base not charging.
Here are a couple things you can try.
Clean the charging contacts, this can be done two ways. The manufacture's recommend using a pencil eraser. I recomend using a q-tip and some rubbing alchol. Just rub the alchol soaked q-tip on all the metal contacts on the bases and the bottom of the handset.
Gooo luck.
Hope this helps
Mar 12, 2008 | Panasonic KX-TG5632 Phone
Uniden DSS7955 Cordless phone problems
I had the same problem!
What you need to do is hold the "end" and "#" key for 5 sec, which will deregister the headset then all you would have to do is place it back in the base for it to registered again.
Nov 25, 2007 | Uniden Lands Phones
Expandable handsets lose activation:
USer manual requires,
full charge 16 hours for expandable handsets, then place in cradle ~20 seconds until 'ready' is displayed on the screen.
If power is lost the handset may have to be re-registered.
if the units are not fully charged when you register them the registration may be lost, can only suggest reversing the order, by fully charging the device then registering to see if the registration holds
Nov 12, 2006 | GE 25931EE1 Phone
Uniden Cordless Phone Logo
174 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
