Question about HP DesignJet 350c InkJet Printer
How to remove the housing on a hp designjet 350c
How to remove the housing at the controls side of a hp designjet 350c
    Scholar:
  • HP Expert
  • 123 Answers
See the cover removal procedure in the manual. Download at: www.lpscomputer.com/ec/manuals.htm
Posted on Apr 15, 2010
SOURCE:
I need to replace the fuse in an HP Designjet 350C. How?
there are a few fuses that are component based I.E. soldered to the circuit rather than a glass shaped fuse, I would recommend that if you have tried a second mains lead that you put a call into a hp representative or HP trained technician to see if its safe to just replace the fuse or if anything more has happened to cause the fuse to trip.
wildly replacing fuses may cause more harm than good.
the right choice is to have a trained tech called out.
Apr 16, 2013 | HP DesignJet Office Equipment & Supplies
When the switch is pushed the indicator lights go on for an instant then turn off.
This is a powre supply problem and could be fatal. They used to be available as a spare but are no longer. The power supply is the same as on the 430/450 and 750 so you may get lucky.
Mar 28, 2011 | HP DesignJet 350c InkJet Printer
I need to reset the memory of a HP Designjet 500ps. Can someone help me ?
The memory is located on the formatter assembly, which is in the rear of the plotter, LH side by the JetDirect Card. (behind a removeable cover beside the paper roll)
Feb 23, 2011 | HP DesignJet 500ps (42 in.) InkJet Printer
When I print, it slowly shifts so the whole print is skewed. The print head seems to not return quite where it needs to be. What part would I need to replace?
Clean the printer
Clean the drive rollers with alcohol
Check the belt for wear
Clean the rail that the heads ride on
After cleaning, make sure that you calibrate the printer
Jan 04, 2011 | HP DesignJet 350c InkJet Printer
Cannot find driver for my 750c for windows 7 how can l install my 750c to windows 7
There are free software you can download for this designjet 750c by finding at websearch like yahoo.com or msn.com. Just type the driver name for this printer and you can download it for free. Most of the printer driver now can be downloaded online with free cd key. Just let it try. or Maybe the printer you are installing is not compatible with windows 7. try to read you printer's user manual.
Nov 11, 2010 | HP DesignJet 750c plus InkJet Printer
Driver problem
http://www.driverstock.com/HP-Designjet-430-driver-download/10-26-1541/index.html
Also HP makes alot of "universal drivers" that work for tons of printers then you dont have to worry about specific model printers because the universal probably controls it.
Jun 23, 2009 | HP DesignJet 430 InkJet Printer
Hp desinejet ploter belt
Follow the procedure for replacing the carriage in the service manual.
he manual can be downloaded here: www.lpscomputer.com/ec/manuals.htm
The repair parts and repair kits can be purchased here: http://www.lpscomputer.com/c-637-designjet-250c-330-350c.aspx
Jun 04, 2009 | HP DesignJet 350c InkJet Printer
HP DesignJet 350c InkJet Printer Logo
91 people viewed this question
Clive
Clive
Thomas F. Schneider
