Question about Lexmark Wheelwriter 10 Series II Typewriter
The carriage is jammed up to the left margin and the wheel just spins. Plus, what are the batteries for?
  • Lexmark Master
  • 3,594 Answers
Turn the T/W off and see if the carrier moves freely back and forth, put some WD40 on the silver shaft that it slides on, check for debris in the area under the carrier, be sure the printwheel is properly installed and there is no debris in the P/W area.
The batteries hold up margins tabs and other settings when turned
off.
DickyO
Posted on Dec 10, 2009
How do you reset the margin on SC-XE6000 when right margin is stuck mid-page width?
Press and hold margin release key while sliding carriage to the left using the carriage release on the end of the carriage, behind the platen (roller) knob, there is one at each end. Put the carriage where you want it and press margin set to reset margin position.
Nov 20, 2014 | Office Equipment & Supplies
How do I increase the area where I can type?
Press margin release key, move carriage using backspace to where you want the left margin to be and press left margin set key. Repeat for the right margin, use space bar to advance the carriage and press the right margin set key instead.
Sep 10, 2014 | Olympia Startype 3 Typewriter
Typewriter carriage
The typewriter needs the escapement adjusted, or you have a bind in the escapement, and it probably needs a good cleaning and oiling. This usually done by a pro.
Oct 07, 2013 | Office Equipment & Supplies
Occasionally, I still have to use a typewriter for some forms. I inherited a Xerox 6015 Memorywriter but I have no manual. Is there one online that I can download? Specifically, I'm trying to figure...
hit the carriage return key to put carriage at left margin. then hit your margin release key, then backspace key to put your carriage where you want it. then hit left margin key and that should set new left margin. good luck.
razors
Jun 06, 2011 | Office Equipment & Supplies
My HP 5610 is printing margins & line spacing incorrectly. Left margin is off about every 3" (indents to right) & words cut in 'half' with upper part of word off to left & lower part of word...
You need to clean the encoder strip, it's the clear strip that runs across behind the carriage assembly. Use a Q-tip damp with alcohol and don't press too hard. With a light you'll see ink or grease spots that cause the carriage to lose it's place while moving across the page.
Feb 01, 2010 | HP Officejet 5610 All-In-One InkJet...
IBM selectric II carriage stuck in right margin
There is a thin metal ribbon in the back that has come off the wheel. It is a devel of a thing to get back on.
Remove the cover and watch ... you will see what I am talking about.
It may have come un-attached ... equally difficult to fix without the little thingie the typewirter mechanic uses.
good luck
Oct 14, 2009 | Office Equipment & Supplies
How do I get the left hand margine to release on my Royal typewri
Generally yoy can set the left margin all the way to the left by holding down the left margin key and pushing the carriage return button
Mar 23, 2009 | Office Equipment & Supplies
Resetting the margins on a manual typewriter.
I can't be for sure if these are auto set margins, but it sounds like they might be. If they are, first move the carriage as far to the right as you can. Hold the Left Margin Set (not Margin Release) lever as you move the carriage all the way to the left. Release the Margin Set Button or Lever. Now hold the Right Margin Set Button or Lever (not the Margin Release), and move the carriage all the way to the right while holding the Margin Set. Once the carriage is all the way to the right, release the Margin Set. Move the carriage to the place you want to set your left margin. Hit the Left Margin Set and then release. Move the carriage to where you want to set the right margin. Hit the Right Margin Set and release it. It gets confusing, but Margin Release does not set margins. Its sole purpose is only to bypass the margins. Hope this helps.
Feb 19, 2009 | Royal MS 25 Typewriter
Dell 946 -carriage jam/stalled
the ink carriage is in far left position and jammed. it appears that the black cartridge far left was not seated correctly. how do i resolve this?
Nov 19, 2008 | Dell 946 All-In-One InkJet Printer
Carriage return problem
Try pressing the margin release key then backspace and reset the left margin.
Jan 14, 2008 | Brother EM-530 Typewriter
Lexmark Wheelwriter 10 Series II Typewriter Logo
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
