Question about Frigidaire Affinity ATF7000E Front Load Washer
I get a DR code when I hit the start button?
DR code when you hit start?
  • steve_chesne Dec 10, 2009
    I'm sorry Ron..but I failed to say that it is on my dryer
  • 112 Answers
Something is caught in your drain pump.
Posted on Dec 10, 2009
I'm getting a door error "dr" on my ATF6700SF0 washer. How can I determine whether to replace the door lock assembly or the control board?
Hi Curt, this is AP
I understand you are having trouble with an error code on your Frigidaire front load washer. On your particular model, ATF6700FS, the error code "DR" indicates that the door is open or there is a problem with the door. If you know the door is not open you should check the door switch and wiring. If you need assistance with replacing the door switch I would recommend contacting an authorized technician in your area. I hope this information proves helpful to you, thank you for the post.
Thanks,
Mar 29, 2014 | Frigidaire ATF6700FS Front Load Washer
Tip
Disable Dr. Watson Watson is a debugging tool in windows , which...
Disable Dr. Watson
Watson is a debugging tool in windows , which sometimes becomes quite irritating when ever it pops up suddenly .
Here is a method to disable it , if it bugs you :
Dr. Watson can be disabled using the registry editor:
  1. Start the registry editor (Start >> Run >> type "regedit.exe" >> Hit enter )
  2. Navigate to HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows NT \ CurrentVersion \ AeDebug
  3. Click on AeDebug and click Del
Alternativly just set HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows NT \ CurrentVersion \ AeDebug \ AUTO to 0
To re-enable Dr. Watson type "drwtsn32 -i" in run window.
on Jan 26, 2010 | Computers & Internet
DR-05 How to delete files
When not in Pre Record o Record mode, you can hit the quick button and the delete option will come up. Then click it and your good.
Jan 12, 2013 | Tascam DR-05 Portable Digital Recorder
When i hit start it beeps repeatedly and says dr on the screen
in the service manual it says if you have a dr error code either the door is not closed or you need to replace the door lock assembly. If you have any further questions message me back and please remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to help others in similar situations in the future. Thanks again for using fixya
Rick
Jun 04, 2011 | Frigidaire ATF6000ES Front Load Washer
Ge Washer GSLP1100D0WW keep getting a dr code near the end of the cycle it stops at 28 mins and then when i hit start it counts at 30 gets down to 28 again and does the same dr code again
Your problem lies in the PCB assembly, or pump motor, most likely the PCB assembly.
1. open lid
2. remove control panel screw covers & screws
3.lift control panel
4. remove screws connecting PCB assembly to control panel
5. Remove PCB from control panel by pushing PCB from right to left.
6. Disconnect wire harness connectors from PCB.
Hope this helps!
Jan 04, 2011 | GE Spacemaker WSLP1100D Top Load Washer
Washer will not start. Getting "dr" message . Door lock light is not lit. Tried cancel and restart tried unplug and restart still getting dr message
The 'dr' error code stands for 'door switch is not closed'. If the door is closed properly, then you will have to replace the door switch assebly.
Hope this helps!
Jun 25, 2010 | Washing Machines
Error Code "dr"
Dr means door problem, either some clothes is keeping it from shutting or the door switch is bad 1ff09a4.png
Mar 05, 2010 | Frigidaire Affinity ATF7000ES Front Load...
Dr 2 message
I just sorted this on my own dvd player. push HDD and DVD buttons on the front of the player together for 3+ secs. Menu will display DR-OFF. Do the same again menu will disolay DR-2. On the remote push mode and "2" together and ths will put the remote into DR-2 mode. All should now be well.
Aug 30, 2009 | Toshiba D-R2 DVD Recorder
Washer has dr when trying to start
Either the door is not closed or the door switch is bad.
May 19, 2009 | Frigidaire Affinity ATF6000F Front Load...
Frigidaire Affinity ATF7000E Front Load Washer Logo
175 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
