Question about Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range
Gas top works-- all electrical is gone-- no ovens, no display panel
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 97 Answers
Try to find your circuit breaker box and see if any of the circuit breakers are tripped. If one is, push it to OFF then back to ON. If none are tripped and you know which double circuit breaker controls the oven, turn it OFF then back ON. If you know how to use a multimeter, check that you have 240 volts to the range outlet.
Posted on Mar 06, 2010
SOURCE:
Creda Solarplus (48906) top oven and grill not working
Electric stoves do not have pilot lights or igniters it could be the power control board has failed .
Mar 12, 2016 | Creda Ovens
F2 shows on display on whirlpool gas stove
Keyboard Failure
Error Code: F 2
Component:
To localize the fault - disconnect the switches from the display unit. If the fault is gone - replace the switches.
Touch buttons - replace control panel assy
Tactile switches - replace control panel assy
Dado
May 14, 2014 | Whirlpool RBS305PDS Electric Single Oven
Kenmore 790 oven won't maintain temperature
anyone know where to buy the battery for hand phone model mini i9500 ? manufacturer is
z.doxio
Nov 12, 2013 | Kenmore Kitchen Ranges
My oven will noit heat up. All the displays still
If it is an electrically heated fan oven, and the fan is working o/k, then chances are it is the oven element that is faulty.
This is usually located at the rear of the oven compartment behind a removeable cover.
Feb 03, 2010 | Ovens
My Jenn Air Electric Wall Oven Control panel lights have gone out
You will need to replace the display assbly.
It is a very common problem with maytag/Jenn Air
Feb 19, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Dual fuel kitchenaid; burners work, oven does not
I had a similar problem. There's a thermostat before the control panel. You need to remove the knobs and the front panel to get to it. You'll also need to remove a couple of trim pieces to keep from bending the panel. The part number is Whirlpool W10017820, sells for about $40.
Nov 29, 2008 | KitchenAid KDRP467KSS Dual Fuel (Electric...
Frigidaire stove
I believe the oven it has a power surge protector within the appliance. Try to unplug it and plug it back in. It should solve the problem.
Sep 17, 2008 | Frigidaire FGFB75D Gas Kitchen Range
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work
my frigidaire oven will not light. The broiler works and the oven ingiter lights up, but the oven will not ingite. The electronic display does work.
Aug 25, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Gas stove works, but oven does not
you most likely have a bad oven ignitor...if you see an orange glow under the oven panel that is your ignitor trying to come on....but if it is weak it will not open the gas valve.....acess the ignitor and replace it
Jul 30, 2008 | Frigidaire FGB24S5A Gas Single Oven
Kenmore Elite Electric Convection Oven Not Working
Check the voltage at the wall Sounds like you have lost one 120 voltage side Red to white should read 110-120 black to white should read 110-120 red to black should red 220-240 check at range and at the wall hope this helps
Aug 25, 2007 | Rangemaster Classic 110 (Dual Fuel) Dual...
Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range Logo
245 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Thomas F. Schneider
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
