Question about Vacuums
Brush does not turn on my vaccum
The vaccum is a sears Kenmore canister type, and it has a motor that turns the brush and a light for nigth vision. neither the motor or the light work.
  • fanatic Jan 21, 2008
    Thanks for your help.
    I did take the cover off where the braker and the motor are, I manually checked the braker and it looks o.k. There was nothing jaming the brush. I have not cheked the hose, but I was trying to take it apart but had no luck,
  • fanatic Jan 22, 2008
    Thank you very much for your help.. I will follow up on your edvize and will let you know what i found.
  • 126 Answers
When you attach the hose to the wands, there is a connection made between the hose electrical receptacle and the cord from the powerhead. On the Kenmore, it is common for the receptacle on the hose to break away from it's seat and slide back into the handle. When this happens, the receptacle is not positioned far enough forward to make the plug-in connection. Look at the end of the hose and check the receptacle and see if it is sitting flush with the plastic opening that it sits in. If it is pushed back, that's your problem. Also check the re-set breaker on the powerhead. If you got something caught in the brush roll, the breaker will have kicked out to protect the motor.
Posted on Jan 20, 2008
  • Anonymous Jan 21, 2008
    You shouldn't have to take the hose apart to inspect the receptacle. It is visible from the end, just underneath the metal pipe that slides into the top of the wand. The receptacle should be flush with the opening it sits in. There is a plastic guard that extends further, but the receptacle itself is even with the opening it is housed in. If it is sitting further back into the hose, it will not make contact with the powerhead cord that is held in the top of the wand. If the receptacle is pushed in, you will have to replace the tube inside the handle that the receptacle snaps into. To take the handle apart, you remove several screws and gently pry the two halves apart. At the back of the handle, where the hose body is connected, there are a couple of snap-type clips on the inside that hold it togeather. You can coax these apart with a small screwdriver or pen knife, but be careful not to poke yourself. This is a case where it would be handy to have an ohm meter handy to check for power flow through the various connections.
6ya staff
SOURCE:
Air driven turbo brush
Is this the Lightning model? How old is it? You may have to just replace the belt.
Also, the front brush motor will not engage until the power is turned on and the handle is in the down position. In the upright position the brush motor wont engage. Typical faults will be the belt is broken and needs replacing or the fornt brush motor needs replacing.
Nov 27, 2011 | Fantom Vacums Vacuums
We have a kenmore canister vacuum and it runs but when turn on the rug clener brush the brush will not run we then put on small brush head and that will work
If the power head motor runs, but the brush doesn't turn, then the belt is broken. Replace the belt and it should work.
Nov 29, 2010 | Kenmore Vacuums
I have a Bissell lift-off revolution. The power won't turn on at all. Tried different outlets. It doesn't work whether the lift-off canister is out of the frame or in the frame. The manual refers to a...
I have the same issue too. Brush motor is working and brush is turning on but the vaccum motor is not working. If I take the canister out of the frame then it wont turn on at all. Any help?
Jul 15, 2010 | Bissell Lift-Off(R) Revolution(R) Turbo...
Brush not moving, suction working
This machine is made for Sears by Panasonic. The power head, depending on model has a "gear" / cog belt or a standard flat rubber belt. First turn the power head over and see if the brush roller turns easily, if so you do need a new belt. To access the belt you will have to remove the hood from the power head. There are 4 screws, one at each of the corners to take out. Once the hood is off you will see where the belt goes and find "teeth" in the motor shaft for the motor / brush roller if you need a gear belt. If both of these are flat you need a rubber belt.
You can go to sears.com and find the belt you need with the vacuums model number.
Apr 27, 2010 | Kenmore 22812 Bagged Canister Vacuum
Miele Vacuum Cleaner - burning smell / motor won't stay on
check brush the belt may have popped off and is binding or brush is binding clean brush of any debris thread/hair wrapped binding brush and check and or replace belt
Mar 24, 2010 | Miele S318 Bagged Canister Vacuum
Wish to remove bottom ofpowerhead-Kenmore Progressive 11629912990
I have a whispertone vacuum, different model #, but maybe instructions will be the same. Turns out I didn't need a new belt, just clean out the crud and reset overload protector. The instructions in the manual tell you to remove the light cover and bulb first. To do this, press in and lift both sides. Push in and turn bulb counterclockwise to remove. (you need to do this because the next step involves turning the unit over). This takes you to
Step 2. Unscrew the cover screws ( on either side of bulb).
Step 3. Turn unit over. To remove cover, insert screwdriver at cover tabs on both sides and twist to release tabs.
Step. 4 Turn unit right side up. Press handle release pedal and lower the swivel. Tilt cover forward from back until front snaps free.
Step 5. Carefully insert and twist screwdriver at each brush support to free brush from base.
Step 6. Remove worn belt.
Step 7. Slide brush supports off to check and clean brush support areas.
To replace belt: slide washers and brush supports onto brush assembly.
Install new belt over motor drive, then over brush sprocket.
Snap brush supports into place on base. Be sure brush supports are not upside down.
Line up front of cover and base. Rest cover on front edge of base. Tilt cover to back. Press cover firmly until side tabs snap into place. Replace cover screws, light bulb and light cover.
Mar 11, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
If there is no suction when you disconnect the beater bar assembly near the hand hold where you grab the vacuum, then there may be either a restriction in the vacuum line between there and the vacuum section (that rolls around behind you), or the vacuum line from the handle point to the rollaround section is not properly connected. This all assumes the vacuum motor in the rollaround is running.
The beater bar section does nothing but cause dirt particles to be sucked into the vacuum system. The vacuum or suction is created in the rollaround unit.
Jan 22, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Carpet setting not working, no brush turn, no light, etc.
if the motor is running, its the belt, if not there is a break in your wire likely in the stub going from the wand to the head
Oct 18, 2008 | Kenmore 25614 / 25615 Progressive Bagged...
Brush won't turn
Remove the drive belt and check the rod coming out the motor for operation when the unit is in the on position. If the motor is turning the motor is not at fault but good. Turn off unit! Next, try to turn the brush by hand. If it is hard to turn check both sides
(the ends) for hair build up. It could possibly be loaded with hair or some other type of string like material that has accumulated over the years and is restricting the movement of the brush. Also check the bearings on the ends too.
Good Luck
May 26, 2008 | Kenmore 23513 Progressive Bagged Canister...
Kenmore progressive canister
belt could be melted to the motor that spins the brush, try free spinning the brush with your hand to see if the brush spins freely, if it does not the brush bearings could be frozen, or just need a simple new belt...hope this helps
Jan 20, 2008 | Vacuums
Vacuums Logo
221 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
