Question about HP Computers & Internet
My cd/dvd drive has stopped working it says- Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)- what can i do to fix it please?
    Brigadier General:
  • 10,406 Answers
Click Start
Click Control Panel
Click System
Click Hardware
Click Device Manager
Expand the CD/DVD branch of the tree.
Right-mouse click on the CD-ROM, and choose "uninstall" or "remove".
Restart your computer, and Windows should "find new hardware", and should load the correct device-drivers for your CD-ROM.
Posted on Dec 10, 2009
Suddenly the internal Hitachi dvd drive, model no HL-DT-ST RD-RS BH30N, has stopped working. I get this under Device Status: "Windows cannot start this hardware device because its configuration inform
If you are a non-technical user then don't edit registry keys manually the best solution is to use the best registry cleaner that will also fix other registry errors. Use Intel Software Partner Reginout.
Dec 02, 2012 | Computers & Internet
Not working my cd drive.
If you are running Windows 7 you can use C Cleaner or Windows 7 Manager to clean up your registry if you don't have them you can download Regcure or Registry First Aid to clean up the reg error then you can restart your computer and see if windows can reinstall your hardware.
Oct 20, 2012 | OEM Systems Acer Aspire 5742g Dvr-td11rs...
My cd driver isnt working and device manager says: Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19) have an hp probook...
Most cd/dvd's don;t use a driver they rely on a atapi common driver. Usually when you get problems it means the drive itself is the issue. For now what I would try is simply to go under /control panel hardware manager and delete the drive then reboot. Windows will detect the drive and should re-install the device information and correct the registry.
Sep 12, 2011 | HEWLETT-PACKARD ProBook 4520s
Drive will not work. Device Manager tells me Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)
simply restore your system within latest checkpoint created by windows or manually
if still it shows error then press restart button and press F2 to launch BIOS detect your cd drive dvd and press F10 to save changes
Aug 19, 2011 | Acer Computers & Internet
I have Optiarc AD-7530B 8x DVD RW DL Notebook Drive Burner, the device status is Windows cannot start this hardware device because its configuration information (in the registry) is damaged or incomplete....
You need to delete the upper and lower filters on the said registry entry.
{4D36E965-E325-11CE-BFC1-08002BE10318}1 You can read the instructions complete with screenshots from the link I added. Cheers!
Fix Windows 10 DVD CD ROM Error Windows cannot start this hardware device...
Feb 20, 2018 | Computers & Internet
My dvd/cd rom is not working on my eMachine. When I open My Computer, it does not show an e drive.
Jul 17, 2010 | E-Machines emachines (emachinees) CD-ROM...
try to uninstall the cd rom.... then restart your computer
Jun 29, 2009 | Sony DDU1642/C1 Internal DVD Drive
CD Rom and DVD Rom won't work
you need to delete lower and upper filters from registry to fix the problem instructions CLICK HERE
Dec 28, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Code 19 and SD R2102 CD-RW/DVD-ROM Burner
Code 19 Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged.
This can occur when more than one service is defined for a device, if there is a failure opening the service subkey, or if the driver name cannot be obtained from the service subkey.
Recommended Solution :
Many third-party programs that control CD or DVD burning (as well as some player applications) install CD- or DVD-ROM filter device drivers into Windows. These filter drivers are meant to allow for low-level hooks into the hardware, to allow for functions such as packet writing (where a CD-R/W or DVD-/+RW can be written incrementally, like a hard disk).
These filter drivers sometimes have problems that can cause the CD or DVD drive to stop working correctly. The device entry for the CD or DVD drive in the Device Manager may show up with an error descriptor that reads "The device could not start." Additionally, there may be an error message that reads "One of the filter drivers for this device is invalid." The devices themselves do not show up in Explorer. Error codes for the device include code 31, code 32, code 19 or code 39, and sometimes the even more ominous warning "Your registry might be corrupted" appears.
Fixing the problem simply involves deleting the filter entries for the third-party device drivers. These entries can sometimes become damaged (which is what produces the "corrupt registry" warning).
To delete the offending keys, open the Registry and navigate to HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlCl ***\{4D36E965-E325-11CE-BFC1-08002BE10318}. . Delete the keys named UpperFilters and LowerFilters and reboot.
Several of the products made by Roxio are infamous for causing this problem, although in fairness to the company the most recent versions of their Roxio CD/DVD writing software (6.2 and higher) do not have these problems. Users of 5.0 or 6.0 editions of the Easy CD & DVD Creator product, which has been bundled with many new PCs in the past, should upgrade to 6.2 or better. Other programs can also cause this problem, with the same solution.
Note that after you do this, you may lose functionality in the program that uses the filter drivers, which may need to be reinstalled.
It will be highly appreciated if you could take a minute and provide us your feedback..
May 14, 2008 | Toshiba SD R2102 CD-RW/DVD-ROM Burner
Computers & Internet Logo
262 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
