Question about Apple iPhone Smartphone
Log in to stx.rr.com mail is very slow. - Apple iPhone Smartphone
How to Blocking and allowing messages on Time Warner cable email login?
Hello
Follow steps:
•Open email settings from the inbox of your RR email login.
•Go to 'Allow and Block messages' option from the mail option.
•Select 'Advanced' block senders.
•Enter the email address along with the domain name of a person in the next section whom you want to block from www RR com login mail account. You can select multiple addresses at the same time.
•You will now be prompted to confirm your action. Click on 'ok' to either forward the messages or block them permanently.
•Click 'Finish'.
RR Com TWC Email Login Help Toll-Free Call 800 414 2180
Apr 05, 2018 | The Computers & Internet
Tip
Complete instructions for Setting up Road Runner Mail on an iPhone. Email...
Complete instructions for Setting up Road Runner Mail on an iPhone.<br /><br />Email Settings for the iPhone & iPad<br /><br /> * Select "Settings"<br /> * Select "Mail, Contacts, Calendars"<br /> * Select "Add Account" (or select existing Road Runner email address if it has already been set up)<br /> * Select "Other"<br /> * Select "Add Mail Account"<br /> o Name: Your Name<br /> o Address: yourname@nyc.rr.com (this is division specific for the customer, for example yourname@socal.rr.com or yourname@roadrunner.com)<br /> o Password: your password<br /> o Description: Road Runner Mail (Name that displays in your Account list on the iPhone)<br /> o Select "Next"<br /> * Select "POP"<br /> o Incoming Mail Server:<br /> o Host: pop-server.nyc.rr.com (this is division specific, such as pop-server.socal.rr.com, or pop-server.roadrunner.com)<br /> o User Name: yourname@nyc.rr.com (You must enter your complete email address. This is also division specific for the customer, for example yourname@socal.rr.com or yourname@roadrunner.com)<br /> o Password: your password<br /> o If needed, enter port 110 and set Secure Server to off<br /><br /> o Outgoing Mail Server:<br /> o Host: mobile-smtp.roadrunner.com (note: mobile-smtp.roadrunner.com is not division specific, mobile-smtp.roadrunner.com is the Outgoing Mail Server Host for all Road Runner email domains, roadrunner.com, nyc.rr.com, socal.rr.com etc.)<br /> o User Name: yourname@nyc.rr.com (You must enter your complete email address. This is also division specific for the customer, for example yourname@socal.rr.com or yourname@roadrunner.com)<br /> o Password: your password<br /> o If needed, enter port 25 and set Secure Server to off<br /><br /> * Select "Save"
on May 13, 2011 | Cell Phones
I want to confirm my facebook account
Good Day!
You have to go to your email account and log in.You can find the confirmation link from your inbox.
If your email account is Yahoo, try to log in here: https://login.yahoo.com/config/login_verify2?.intl=us&.src=ym
If your email account is Gmail, try to log in here: http://www.gmail.google.com
If your account is Hotmail.com, try to log in here: https://login.live.com/login.srf?......
Take a look here for your guidance
Dec 27, 2011 | Facebook Social Network
I would like to use a sunpak 622 super with a sync connect to the hot shoe. Is the voltage too high for my nikon D 70 DSLR My e -mail is ml1089h@stx.rr.com
According to the list at http://www.botzilla.com/photo/strobeVolts.html , it's your call. The flash's trigger voltage is right on the border. Depending on the individual camera and flash, it may or may not be safe. Personally, I wouldn't risk it without something like the Wein Safe-Sync in between to buffer the current.
Mar 03, 2011 | Sunpak 622 Super Pro TTL Flash
I have a new Ipod touch and I can receive emails on RR but cannot send or forward emails on RR. I would appreciate a step-by-step guide to set-up RR for sending email or forwarding emails....
Try this...
1) On your Ipod Touch select "Settings." 2) Select "Mail, Contacts, Calendars." 3) Under Accounts select your "Lwilson22@satx.rr.com" account. 4) Under the "Outgoing Mail Server" heading select "SMTP." 5) Under "Primary Server" it should indicate ""RR SMTP Sever" (or something to that effect)  - If so, make sure that the "Server" is switched to the "On" position.  (If it was originally switched off then switching it on should do the trick.
 - If not, continue to Step 6. 6) On the "SMTP" page select "Add Server..." 7) Fill out the fields accordingly.  If you are unsure of the information check with you service provider (in this case Road Runner).  - In most cases it would likely be "smtp.rr.com," plus you own "User Name" and "Password." 8) Select "Save"
Mar 03, 2009 | Apple iPod touch
Error #0x800CCC0D can't contact pop-server-hawaii.rr.com
search for proper mail server adderss on the net. then try creating account.
Sep 27, 2008 | Computers & Internet
Slow slow slows down my computer!!
Normal 0 There are a number of things that can cause the computer or the camera to freeze up or slow down.
First I’d check to see how much memory is installed in the computer. It takes additional memory to operate the camera.
Hope this helps. Bud
May 19, 2008 | Logitech QuickCam Communicate STX Personal...
IPhone Road Runner Issues
Setting Outgoing Server on iPhone
1. From the Home screen, tap Settings.
2. On the Settings screen, tap Mail, Contacts, Calendars.
3. On the Mail screen, under Accounts, tap your Roadrunner account.
4. Tap Outgoing Mail Server (SMTP).
5. Tap Primary Server (might say, smtp-server.roadrunner.com or some other rr server)
Host Name
Change Host Name to cwmx.com
User Name
Leave blank
Password
Leave blank
SSL
Make sure SSL is off
Authentication
Should say Password
Server Port
Should say 25, if not change to 25
As an alternate if the above does not work: After tapping Outgoing Mail Server (SMTP), look for AT&T SMTP Server, tap it, then turn Server to ON
Good Luck!
Jan 05, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
896 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
David
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
