Question about DISH Network 135899 Remote Control
Will only work tc intermititley--just here and ther and not very often
    Scholar:
  • 66 Answers
I can not say I am an expert on remote controls, but if you havent verified that the batteries are good in the remote Id replace them, Ive had the same experience with remote controls in the past and the batteries have always been the problem.
Posted on Dec 10, 2009
Procom heater will not stayon
check the milivolt reading with a tester or replace the powerpile/pilot assembly
Sep 30, 2016 | Procom Heating & Cooling
Wall heater will not stay on.
Clean out pilot sounds like it is too small to heat tc
My Quickstat has stopped working completely. not a gfi reset issue, but zero display. there is still power to unit. Im guessing that I need to replace unit.
Raychem QuickStat-TC Installation & Operation Manual
www.manualslib.com > Brands > Raychem Manuals > Thermostat
View and Download Raychem QuickStat-TC installation & operation manual online.QuickStat-TC Thermostat. QuickStat-TC Thermostat pdf manual download.
Raychem - QUICKSTAT-TC, Programmable, Thermostats ...
www.platt.com > ... > Floor Warming > Thermostats > Programmable
$144.29 - ‎In stock
Raychem QUICKSTAT-TC Programmable Thermostat Programmable Thermostat, 120/240V, 16A, GFCI, 4 Programmable Events per Day.Missing: tyco ‎working
Raychem Quickstat Floor Heating Thermostat Installation ...
Dec 26, 2015 | Raychem by Tyco QuickStat-TC Thermostat
How do you clean the carburetors on a 2005 Victory TC?
w a bike that age u need to diasemble the carb then put it in a solvent it delicate work theyr very complex and easy to hurt a part getta clymer manual for the details the stuf sold in stores mite work for minor issues. but thers alotta gimics
Jul 03, 2014 | 2005 Victory Touring Cruiser
Picture does not fill screen
Hello
Go to its user manual page [20]. Set the formats. How to set the format is described ther, which I can't copy and paste to you by this window.
Feb 06, 2012 | Panasonic TC-P50C1 Plasma TV
Brand new heater installed according to manual yet unit shuts off randomly after running - some times in less than a minute, sometimes after a day and a half of running fine. How do you test the...
I doubt if the ThermoCouple (TC) should have failed this soon!
However-- Here is a page I wrote to help others trouble-shoot and replace the TC
One possibility is that the Thermo Couple is beginning to fail'
What is a Thermo Couple? (TC)
The Thermo Couple (TC) is a small Rod-shaped device with a couple wires coming out the bottom.
The TC actually generates a small electrical current from the heat of the Pilot.
This electrical current is sensed by the control board, or the Main Gas Valve.
As long as there is a pilot, it is safe for the Main gas valve to open, and admit the large amount of gas into the heating burner.
Now-- What helps this TC work the best?
It needs to be just at the edge of the pilot flame--- Not too much in the flame, or the resulting poor combustion of the pilot flame, results in soot forming on the TC-- which insulated the TC from sufficient heat.
Obviously the TC has to be clean (of soot) in order to receive enough heat, to generate the needed voltage to tell the valve that it is safe to open.
And age does deteriorate the TC-- some last a few years, but that is about the end of life for most.
Replacing requires getting down where the TC is, and with a screw driver (usually)-- loosening the bracket that holds the TC. Pay attention to where the wires are routed, and any polarity indicated on the old wires, and duplicate on the new one. Duplicate routing, and polarity, and position the new TC at the edge of the pilot flame.
Pilot flame is maintained by pushing some over ride button-- for a minute or two, until when you begin to release the button, you can feel that the voltage generated by the TC is now holding the pilot valve open, instead of your pressure on the 'start' button.
Any further Questions, let us know..
Mack B
Jan 26, 2011 | Heating & Cooling
My heater, modle # cbn30t when I turn the pilot light on and ignite the fire it works for about 30 seconds and then stops, is this common and does anyone know how to fix it?
One possibility is that theThermo Couple is beginning to fail'
The Thermo Couple (TC) is a small Rod-shaped device with a couplewires coming out the bottom.
The TC actually generates a small electrical current from the heat ofthe Pilot.
This electrical current is sensed by the controlboard, or the Main Gas Valve.
As long as there is a pilot, it is safefor the Main gas valve to open, and admit the large amount of gas into theheating burner.
It needs to be just at the edge of the pilot flame--- Not too muchin the flame, or the resulting poor combustion of the pilot flame, results insoot forming on the TC-- which insulated the TC from sufficient heat.
Obviously the TC has to be clean (of soot) in order to receive enoughheat, to generate the needed voltage to tell the valve that it is safe to open.
And age does deteriorate the TC-- some last a few years, but thatis about the end of life for most.
Replacing requires getting down where the TC is, and with a screwdriver (usually)-- loosening the bracket that holds the TC. Payattention to where the wires are routed, and any polarity indicated on the oldwires, and duplicate on the new one. Duplicate routing, and polarity, andposition the new TC at the edge of the pilot flame.
Pilot flame is maintained by pushing some over ride button-- for aminute or two, until when you begin to release the button, you can feel thatthe voltage generated by the TC is now holding the pilot valve open, instead ofyour pressure on the 'start' button.
Mack B
Jan 20, 2011 | Desa International CBN30T Central Heating...
I have a 37 inc LG LCD TV. While watching it the TV made a loud pop noise and the screen went black. We lost both the screen and sound. Tried it again this morning and after 2 minutes the same thing...
you have blown an internal fuse you might be suprized to learn that ther is someone veryclose to you who might be able to fix it a lot of people who fix tv's work from home bassically you just neeed ot repalce a small circut board inside it
just google and try to find them
take tc back it should sill be under warenty if they refuse you can say t othem this is not fit for its purpose and force them to fix or replace it
Sep 19, 2009 | LG 37LC7D 37 in. LCD HDTV
Tc not work in my pc
Hi Shashi,
please make sure the TC files are extracted in following folders after installation
c:\tc\bin --> all executable files
c:\\tc\include --> all header files with .h extension
c:\tc\lib --> all library files
c:\tc\obj --> all .obj files copy them to c:\tc\bin too
now goto my computer --> c:\tc\bin
copy tc.exe file and right click on desktop and select copy short cut and press enter
Now you can start TC simply doubleclicking this shortcut icon
Please call if having any problem
Zulfikar Ali
ali_zulfikar@yahoo.com
09899780221
Mar 14, 2009 | Microsoft Windows XP Professional With...
Nikon TC-17E II with Nikon 70-200mm f/2.8
You may have a dirty contact on the tc cpu pins. Try cleaning the pins with a clean pencil eraser or some methanol. You could also have a loose connection between the tc and the lens or body. Try applying a rotational force in both directions...see if you notice any change in behavior. If you have a local shop, see if you can try another copy on your lens.
The 17e may have slow-ish performance in low light, but it should still be usable. If neither of these issues is apparent then it may need to be exchanged or serviced.
Jan 10, 2008 | Nikon TC-17E II for AF-S, AF-I 1.7x Lens...
DISH Network 135899 Remote Control Logo
44 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
