Question about SanDisk Sansa e250 MP3 Player
I just recieved it and plugged it in the computer for the first time -it lights up says low battery and the computer doesn't acknowledge i plugged it in
  • 1,511 Answers
Hello Ma'am; Allow the mp3 player to be connected with the computer for some time (AN HOUR OR SO). This will charge the device and then will make it on (turn it to on Manually if this not happens automatically).
If the battery is almost totally drained then you need a travel charger to charge the player:
(like this:)
http://shopbestsale.com/MP3-Players/img/Discount-Travel-Charger-for-Sandisk-Sansa-E250---E260---E270---E280.jpg
Rate my solution, if I am Helpful, Regards, Waqar.
Posted on Dec 10, 2009
Computer doesn't turn on. Tried just using AC plug in with no battery but doesn't turn on. When the AC Adapter is plug in there is a orange light on when battery is in and a white light with
If you are still having trouble I would take it to a local pc technician. I have had good luck an UniComputers on 23rd st but its not cheap...
Sep 30, 2012 | HP Pavilion g4-1117dx Notebook
Canon PowerShot SX20 IS Digital Camera freezes when importing pictures
Try downloading the current software for you model from the Canon site. You could try inserting the memory card into the card reader on your computer and if you get the same result then it would appear to be a software problem that you use to download. Sometime conflicts appear.
Nov 01, 2017 | Canon PowerShot SX20 IS Digital Camera
The low battery alarm is sounding for both the console, AND the remote - which I do not have. The ADT people can't come out for another week. How do I silence the beeping? I turned off the status beeps...
The Simon 3 supervises the panel battery and when it's bad or the a/c has been out for a long time..will likely have to charge the battery. A problem arises where the keypad unit will not acknowledge that the battery has been recharged/replaced without you doing a basic power cycle.
Whenever this panel battery is replaced in a Simon 3 (worn out or depleted from no A/C (power-outage)) you should disconnect the A/C adapter, install the new or recharged battery properly and hear the panel tell you it's ok..."..simon ???? is OK.." and THEN plug in the A/c adapter. Assuming the panel is not damaged..it will talk when a suitable battery is installed with the A/c out. If it doesn't talk..check the battery with a test meter. Voltage over 6 volts(approx) is required to make it talk.
Of course, after a total power cycle you will have to set the clock.
Remotes(key fobs) aren't usually supervised (as they are carried away from the site) so it's unlikely it's referring to a key fob low battery. Might you be talking about a remote keypad or device in another part of the house or garage that may have low batteries..finding it and checking the batteries will clear the second part of your beeping.
Aug 23, 2011 | GE Security Simon 3 Wireless Home Security...
In my home, it was a fault in ilumination and the UPS isn't ringing but is always with the red light on What can I do? PS: Sorry my english but I am portuguese
The red light means that it is being discharged or is low on battery power/it's not recieving power from the wall plug. Maybe the UPS needs to be charged. While the power is on at the wall plug, switch off the power to the UPS then you should get an orange light showing that it is being charged. Switch off your computer for a while, aftyer about 12 hours it should be fully charged.
Your rating of this solution is much appreciated.
Thanks.
Nov 01, 2010 | Mustek PowerMust 800 (POWERMUST800USB) UPS...
I have a Microsoft Wireless Desktop Receiver 3.1 unit which works both my keyboard and Wireless Laser Mouse 5000. My mouse is not working and I've changed the batteries 3 times. Can I buy a replacement...
I have the same system. Mouse can be ordered, but not easily. Make sure mouse is not working.... i almost made tour same mistake. In my case, the mouse plug (from computer to wireless receiver) had become unhooked. All i could see is that mouse was communicating with wireless receiver but appeared to be frozen. If you can reset receiving channel, and see that receiver acknowledges presence of mouse, you may have my same problem. Also, if you can see that the laser light is working, mouse is probably ok, and batteries are good.
Feb 15, 2010 | Microsoft Wireless Optical Mouse USB...
Inspiron runs on ac power but not battery
Sounds like you have a faulty ac adapter or jack on the laptop and its not charging the battery fully. More like a trickle charge. I would recommend leaving the laptop on default power settings or the best power settings and see if their is a differance in life or either shutdown the laptop and let it charge until the light shows fully charged.
Jul 20, 2009 | Dell Inspiron 1501 Notebook
Won't charge after the battery runs low.
that means your battery is flat so first boost the battery using universal charger or in other way charge you battery directly
Apr 08, 2017 | Sony Ericsson XPERIA X1 Smartphone
Microsoft wireless notebook optical mouse 3000 Doesnt seem to work?
Okay, a coworker had this problem and it was a fairly easy fix, first, plug the USB reciever into a direct USB port, then pess the connect button on the underside of the mouse, when the red light starts blinking let go and then press it and hold, and at the SAME TIME press and hold the connect button on the receiver until both the receiver light and the mouse light turn on steadily, and voila!
Aug 04, 2008 | Microsoft Wireless Notebook Optical Mouse...
Bluetooth 2.0 EDR Undetected by Computer
Hold the red button in while inserting the dongle will give you bluetooth.
Mar 10, 2008 | Logitech Cordless Desktop MX 5000 Laser
SanDisk Sansa e250 MP3 Player Logo
12 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
