Question about Lowrance GPS
My Lowrance LMS 520C units keeps shutting down? Sometimes it will restart and stay on for a while ( several minutes) other times it just flashes when I hit power-on and won't light up.
  • 6 Answers
SOURCE: Magellan GPS Roadmate 760
Try a new cradle many people are telling me the cradle is faulty. You will note the amount of online seller out of stock.
Posted on Sep 29, 2007
hydetech
  • 113 Answers
SOURCE: I have a Lowrance LMS
Are saying you can't read the screen at night, or is it hard to read the screen anytime?
If you tap the power key, you should here a beep and the screen should get brighter. If you hear the beep and there is no light, then the internal light has failed.
If you can't read the screen in normal light conditions try viewing it under a bright light at various angles. You may notice that the screen is just barely visible. If this is the case you may be able to fix the problem by adjusting the contrast. Try tapping bthe power key and then tap the right or left side of the track pad. It may take several taps to see the results. If left or right doesn't work, try up or down.
Posted on Jul 21, 2008
hydetech
  • 113 Answers
SOURCE: My Lowrance LMS-337c df keeps going crazy.
Normal 0 false false false MicrosoftInternetExplorer4 st1:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}This could be caused by glitch in the operating systemsoftware or by low voltage due to a short in the unit or somewhere in the boatswiring. To troubleshoot the problem Iwould recommend the following steps.
  1. Try a soft reset
  2. If the problem resurfaces, try a hard reset
  3. Update the the operating system software
Soft Reset (Does not delete GPSData)
1. Turn unit OFF 2. Press and holdthe PAGES key
3. Press and hold the PWR key
4. Release both buttons when the USA map
Appears
Hard Reset (Deletes stored GPS Data
such as Waypoints and trails)
1. Back up any waypoints, routes,and trails that you want to save on a blank MMC card
2. Turn unit OFF
3. Press and hold the ZIN&ZOUTKeys at
the same time
4. Pressand hold the PWR key
5. Release both buttons when the USAmap
appears
To update the operating system software, check out this link:
Lowrance337c df update
If you don't have a card reader I can program an update card for you.
Posted on Dec 16, 2008
SOURCE: Cannot access main menu or pages screen
I think I can help with your issue. I have an LMS 334c and have had a few issues in the past. Called the factory (this answer is not listed any where in your manual) and they instructed me to "Soft Re Boot" my unit and it would put everything back to factory settings. Try this anytime it does not respond for whatever reason.
Turn the unit off.
At the same time press the Pages and Power button. Hold both down until you see the square box come up in the screen. You should have your factory settings again. May need to try a few times.
Lowrance said it works just like a computer, ever now and then it just tries to disect to much information at one time and hangs up.
Good luck. James Cantwell
Posted on May 04, 2009
the q guy
  • 393 Answers
SOURCE: Unit powers itself down
does it do this when on battery mode?
or when its plugged in?
i found they do tend to drain quicker the older it gets and that just because of a week internal battery.. i just leave mine plugged in to the cig lighter in my car and i dont have that problem but if you have to use battery power it will drain fast no real fix unless you get a new internal battery and its much easier to just leave it plugged in.
Posted on May 22, 2009
Lowrance X135 blows in-line fuse and won't power up? How to troubleshoot
First, follow the wire from the fuse to the unit. It may be pinched or cut somewhere between those two points. Seems simple, but this happens often. If the wires look ok, You could also try a fuse one size bigger. If it blows that fuse, then the problem is in the unit, and you will have to sent it out for repair.
Apr 10, 2014 | Lowrance Lms 520c 5" Screen Color External...
LMS 520c back light not working
the light switch is in the power up button...turn the unit on let it boot up then push power button to set light as you want it do not hold down power button that will just turn unit off.. push the power button just one time if you want light brighter push till you get the back light you want
Jan 21, 2014 | Lowrance Lms 520c 5" Screen Color External...
Flashing screen
two things can be taking place 1 you have a bad key pad 2 you have a bad transducer(short in wire )
Oct 22, 2013 | Lowrance Lms 520c 5" Screen Color External...
I have a lowrance LMS 520c and I never pick up any fish. it does show the bottom
read the book that came with it you got to understand how it works and know how to set your unit before you can understand how it works and what you need to do to make it work and to get to what settings you want ..a fish finder is like a computer you got to program it to your likings .. I have a hd 10 structure scan on mine .. .now that's a nightmare to set but the book tells you everything you need to do and how to do it and how to get what your looking for and how to get to it
Jul 28, 2013 | Lowrance Lms 520c 5" Screen Color External...
Lms 520c 5" Screen Color External Gps And 200 Khz Sonar System: I have a Lowrance LMS 520C on my boat. The GPS wi...
I have the same problem on my 520C.
I have no solution but I hope you have find some?
Best regards
Dan
May 07, 2010 | Lowrance Lms 520c 5" Screen Color External...
I purchase a lowrance LMS-520C about 18 months ago. The depth gauge cuts in and out. It works for a while then defaults to 3.3 feet while trolling. Can you point me in the right direction to find the...
Quite often those transducers go out. Not 100% sure but would bet money on it. Call Lowrance customer support and see if the offer any more advised but more importantly see if they can replace your current one as a replacement instead of you having to pay full retail price. I purchased a new gps module through customer support and saved $150 off the normal retail price. Best time to call customer service is at 8:15am central time when the lines are turned on!
Feb 28, 2010 | Lowrance Lms 520c 5" Screen Color External...
Won't power up
Make sure the power is good, and the power connections are clean. Check fuses and connections. You can even get a volt meter, unplug the power cable and test for 12VDC across the two bigger female contacts on the power cable connecter. If you are getting 12VDC, then the LMS-520 is bad. If you are not getting 12VDC, then you have a bad power supply, connection, or cable.
Jul 10, 2009 | Lowrance Lms 520c 5" Screen Color External...
Is online training available for the LMS-520c?
Haven't found any. But the manual covers about everything
http://www.lowrance.com/upload/Lowrance/Documents/Manuals/LMS525CDF-520C_0151-461_120706.pdf
252 pages, you should be able to find answers to any problem you might have with the unit from there.
Sep 14, 2008 | Lowrance GPS
GPS Logo
186 people viewed this question
Top Lowrance GPS Experts
Marvin
Marvin
Harrie
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
