Question about Montgomery Ward (223600UP) Heater
I have a Montgomery Ward Snow Thrower Model 495A. A rope got caught in the auger. Now the motor runs but the auger will not turn. Any idea what was broken and where I can get parts to fix it?
I have an older Montgomery Ward Snow Thrower model No. TM0-35286A and I'm having a hard time finding parts for it. The tiller just stopped working so I'm thinking the worm-gear is shot, but I can't even find the part on-line...Can you help?
Posted on Feb 11, 2010
    Problem Solver:
  • 7 Answers
Well..., with the rope, it could be shear pins, but the most likely thing is a burned-out belt
with the worm gear, you gotta crack it open and look, but you could probably use a worm gear from something else, provided that it's of similar size.
you can also try MTD, they've inherited Montgomery Ward
Posted on Feb 18, 2010
  • joek0617 Feb 18, 2010
    it could also be a sheared pulley key
  • joek0617 Mar 03, 2010
    actually, you need to call Toro/Lawnboy since Lawnboy bought up gilson, and montgomery ward contracted Gilson
Hoe to replace belts
Posted on Feb 27, 2010
I have a Toro two stage snow thrower that has an auger issue..left just spins as it want the right moves snow....how do I fix...the machine is 13 years old can't find any answers....help please.
The shaft has shier pins that break when an object gets caught in the auger. This prevents further damage. You will need to replace that pin. Make sure you stop the blower, unplug the spark plug before working on it. The pin holds the auger to the shaft. Turn the auger until you see the hole through the shaft and insert a new shier pin.
Dec 12, 2016 | Garden
Snow blower runs and auger/ blade rotates but the wheels Anne not rotating. 2- stage Aries 5520. Not sure if the thrower piece is rotating. Any answers for getting wheel moving/ working
Most self propelled units have 2 belts. One for the auger, and one to power the wheels. Check the belts, and then check the drive assembly under the motor to see if it is engaging.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Dec 03, 2016 | Garden
I JUST PURCHASED A SINGLE STAGE SNOW THROWER FROM LOWES. WHAT IS THE DIFFERENCE BETWEEN A SINGLE STAGE VS A DUAL OR MULTI STAGE SNOW THROWER THANKS DON DMH8@AOL.COM
a single is just that a single auger that scoops snow and shoots it out chute their a smaller unit --a dual front auger scoops snow into another auger which shoots the snow through the chute the duals are bigger and they move more and heavier snow
Nov 26, 2016 | Garden
My MTD 10hp auger will not turn. I adjusted the auger cable by tightening the bolt on the handle. I disconnected the spark plug and checked the shear pins on both sides of the auger. They are both still...
Yes there are 2 belts one for the drive and one for the auger. If you remove the cover on top that is located between the engine and the auger housing you can check the belts. The auger belt has come off the pulley or is broken. Hope this helps you out. Best regards and good luck.
Jan 08, 2011 | Mtd Genuine 9460897 Snow Blower Auger...
Snow thrower is self propelled. was working fine then stalled
check the bearings in the auger sounds like the froze up and now they need to be replaced (the smoking you saw was from the belts slipping on the pullies)..good luck
Feb 26, 2010 | Craftsman 16" High Garden Tractor Snow and...
Snow thrower won't throw snow
the problem could be the snow is to heavy for the motor to keep up, if thats the case you may need to upgrade to a more powerful model or try not to overload it. take it a little slower so the motor can keep up. but try tightening the belt. with your pointer finger push down on the belt it should have about a half inch give, if it moves more than that its too loose and probably slipping under load
Dec 13, 2008 | Toro Blowers Rake and Vac - Electric...
Montgomery Ward (223600UP) Heater Logo
812 people viewed this question
Top Montgomery Ward Heating & Cooling Experts
Paul Carew
Paul
Paul
Mack Baxter
Are you a Montgomery Ward Heating and Cooling Expert? Answer questions, earn points and help others
