Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
DD603 LCD on top drawer does not light up anymore. What
LCD on top drawer does not light up anymore. What part is faulty and what is the cost of this part?
  • duffett640 Dec 17, 2009
    Is there different part numbers for different color lcd displays? Mine is like a blue/green color. I have heard there is also a orange one.
    Thanks
  • Fisher and P... Master
  • 3,247 Answers
The LCD going blank could mean a couple of things.
If the dishwasher is still working then most likely it is the LCD panel that is faulty. But if the dishwasher is not working, that is, on pressing the start button you get no response, then the controller may be faulty or if you are lucky - the power fuse is blown.
The part number for LCD for your model is
526203P DISP LCD MERCURY 525 P3. Can't say what the cost is specific to your locality but should be around the us$100 mark.
Not sure if you want to replace this yourself. If you are not familiar with this sort of thing then best to get a technician. You will have to be careful with the connector pin locations when reinstalling the LCD panel. Also remember to turn the power off when working on the unit.
Posted on Dec 12, 2009
Testimonial: "Thanks"
How do i repair fisher paykel dd603 problem top drawer stuck on fast cycle, bottom drawe stuck on normal cycle
you will need to replace both draws control boards, with the dd603 control boards they have a small touch button panel on the top of the board which they didn't put a protective layer or plastic over and basically what happens is steam gets on the copper tracking and corrodes it hence the fact it doesn't work anymore, all new control boards even the replacement for yours comes with a plastic strip over the board. hope this helped
Oct 06, 2014 | Fisher and Paykel Dishwashers
Top half of my dish washer beeps when i push the power button
you will find this diagnostic service document useful.
http://applianceassistant.com/ServiceManuals/dishwasher-fisher-paykel-dish-drawer-dd603-ds603-service.pdf#zoom=100#scrollbar=1
The likely reason for top drawer not starting wash program when you press start button is the drawer home sensor is either faulty or the drawer is misaligned. This means controller thinks the drawer is open and does not start the cycle.
Apr 28, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
The top dishwasher of my Fisher&paykel Paykel DDd603 &DS603 model ontinuallly beeps. I tried unplugging the power for several hours and it still beeps. Any recommendations ??
Assuming the bottom dishdrawer is working ok, it is likely the controller on the top drawer is either faulty or sensing some incorrect signal. If pressing any of the panel buttons makes no difference, then most likely the controller is faulty.
By the way I am unclear why you mention two models in your problem description. DD603 is a double drawer dishwasher and DS603 is a single drawer unit.
Apr 10, 2013 | Fisher and Paykel Dishwashers
DD603 model & top drawer totally dead, no lights but bottom drawer 100% Your thoughts plse.
possible causes
  • top drawer controller has lost power - replace power filter plate located at the base of dishwasher under bottom drawer controller
  • itself is faulty if you are getting some lights on the panel
  • thermal relay has tripped. It is located inside the heater element at the base of the drawer. The whole heater needs to be replaced.
Make sure the dishwasher is disconnected from the mains power supply when working on it
Jul 26, 2012 | Fisher and Paykel Dishwashers
F&P dishwasher (DD603i) has no power to top drawer
No power to the top drawer needs to be verified.
Are you saying the lights are blank and when you press the start buttion nothing happens?
One reason the controller can shut the power is that the heater overload protection thermal resistor has opened. Unfortunately the only way to fix this is to replace the entire heater plate at the bottom of the drawer.
To confirm if the controller is operational or not, press Keylock and Start/ Pause button together for 5 sec (press Keylock first) and see if the Lights light up. If nothing happens then either the power has shutoff as mentioned above or controller is faulty.
Depending on your familiarity with such equipment you could try to replace and fix. I am not quite sure what the new model you mention is. I believe all DD603 models have power to the 2 drawers coming from the base board.
Feb 06, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
No power to top drawer so I cant even run a
If the controller is faulty then you will not see any life in the drawer unit. The controller is mounted on the front of the unit behind the door panel.
Oct 19, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
F&P double drawer (DD603) won't empty
Ok you need to remove the motor rotor it's under the spray arm and comes out like a light bulb from the top draw and check for anyting stuck under it or any damage done to it. Try swapping it with the one out of the bottome drawer and see if that works. When you first start the washer does it drain all the water?? if still no luck try swapping the motor contoller modules (computer board) from the top drawer to the bottom drawer and retry both drawers ,if the fault moves drawers with the part, then that part is faulty cheers
Mar 18, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher paykel DD603 top drawer starts cycle then stops and beeps and doesn't go thru cycle
When it stops and beeps can you tell me all lights that are on when you open the drawer cheers. also check to see if the water in the tub is hot if not you have a heating issue. either a faulty element or Mtr Controller module. try swapping the Mtr Controller module (computer board) from the top drawer to the bottom drawer and see if that moves the fault. cheers
Mar 07, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher Paykel DD603
The top drawer on our DD603 top lid doesn't seal allowing water to spray out and down the sides.
Aug 10, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
369 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
