Question about Whirlpool Duet GHW9150P Front Load Washer
How do I remove front lower panel to check pump cleanout, cap
  • 15,935 Answers
If you experience a problem where the washer does not drain and the drain pump does not run at all, here’s the information you need to replace the drain pump:
Symptom: PUMP IS NOT RUNNING, NOT DRAINING AT ALL.
1. Unplug the washer while servicing inside the unit.
2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
4. There is an access removal cover on the pump that can be removed to clean out the trap. Sometimes objects get caught in the pump impeller and stop it from running. We’re going to assume that you have already done this and that the pump no longer runs. It is strongly recommended that you remove all residual water from the wash tub & drain line at this point or you will have about a gallon or so inside your washer and on the floor to clean up.
5. HINT: Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
6. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
7. Locate the electrical connection to the pump and disconnect.
8. Now locate the two drain lines and remove them. The hose clamps can be released by squeezing with a pair of pliers. NOTE: I would not recommend removing the hose from the bottom of the wash tub unless you really have to. This one can be difficult at times to get back on.
9. Remove the torx type screw at the front center of the pump and it should slide right out of the mounting grooves on the bottom of the washer case.
10. Your new pump comes with several adapters to place on the feet of the pump in order for it to properly fit your washer. These are rubber bushings that help get rid of vibration and noise. If you become confused, there should be installation instructions that come with your new pump. You can also look at the pump you just removed to see how the bushings are mounted.
11. Reinstall the drain lines to the pump. HINT: It is much easier to do this with the pump still OUT, rather than installing it. When you squeeze the clamps to open them up, make sure you slide the clamp completely over the hose AND the inlet/outlet tubes on the pump housing in order to get a good seal.
12. Reinstall pump by sliding the feet of the pump into the mounting grooves on the bottom of the washer case. Tighten the center screw and reattach the electrical connection.
13. With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
14. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
15. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump is supposed to energize and begin to drain.
16. If the pump works normal and there are no leaks detected, reinstall panel and tighten screws.
CAUTION: Use care when reaching inside the washer case not to damage the small wire harness that runs along the front of the machine.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
NOTE: My initial symptoms describe a drain pump that is NOT running. It is actually possible for the drain pump to be running and STILL not drain. If the pump impeller becomes damaged, or if the motor shaft is stripped, the pump will run, but will not drain properly.
Tip Courtesy JSRock
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Dec 10, 2009
Not draining?
Check the pump cleanout. You have to either remove the lower front panel or some have a little door you remove from the front bottom right. There is a @ 2'' plug to unscrew. Put a low pan under it to catch water, unscrew it and clean it out. Should drain after that.
Jul 18, 2014 | GE Energy Star WCVH6260F Front Load Washer
GE front loading washing machine model # 4 wbvh6240fww It won't drain. Don't know where the pump filter is, that everyone is recommending to check and clean. Where is the access panel for the...
The filter is hidden below the lower front panel (3 screws hold this in place) Turn the pump cleanout knob counterclockwise about 2 turns and be ready to mop up any water that leaks out as you remove it. To avoid spillage, you can pull the machine out and tip it backwards 45 degrees.
Jul 12, 2011 | GE WBVH6240F Front Load Washer
Washer isn't draining and gives off flashing light beeps help!
Remove the lower front panel to access the drain pump.
Remove the drain pump and cleanout the lint.
Mar 02, 2011 | Kenmore 3.5 cu. ft. Front Load Electric...
Not spinning, not draining, water stuck inside
the pump in the lower area below the drum is plugged with coins,hairpins,etc.,and you need to remove the lower panel in front and open up a round circular cleanout trap that is located by the pump
Dec 27, 2010 | Whirlpool AWM6140 Front Load Washer
My washer will not drain or spin
Machine will not spin unless it drains first.Remove lower front panel youll see pump cleanout cap,unscrew youll probably find coins etc.drain water by hand have wet vac ready.Hope this helps .Please rate my response :)
Dec 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer will not spin. pump drains well. low humming noise.
"low humming noise??" soundslike the pump trying to pump, did you try removing the lower acess panel and physically cleanout the drain pump filter?? sondsas if its still trying to empty water
Mar 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Need directions to unclog my Whirlpool duet washer which is giving me a f21 code.
Empty the washer and get some towels...
  1. Unplug the washer.
  2. Remove the kick panel 4-8 screws along the bottom with a Torx 15 screwdriver.
  3. Directly in front of you will be the pump and the cleanout (large twist-cap).
  4. Pack towels under and around the cleanout.
  5. Turn the cap counter-clockwise and pull out.
  6. Remove any debris.
  7. If you have an additional cylindrical pre-filter, remove and clean it.
  8. Re-assemble.
  9. Plug in the washer
  • Note: If you see bubbles or foam in the cleanout, you're using too much soap.
Dec 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Frontloading duet HT retaining water in the tub
THE ONLY THING BETWEEN THE TUB AND THE DRAIN IS A
PUMP/MOTOR AND CONNECTING HOSES. THERE IS ALSO A CLEANOUT BEHIND THE FRONT LOWER PANEL. REMOVE THE PANEL BY REMOVING THE THREE SCREWS ALONG THE BOTTOM EDGE. PULL DOWN ON THE PANEL TO REMOVE IT. A LARGE CAP ON THE FRONT OF THE CLEANOUT CAN BE UNSCREWED TO REMOVE A FILTER.
CLEAN IT OUT AND INSPECT THE ENTRANCE INTO THE PUMP HOUSING. MAKE SURE IT IS CLEAR. REASSEMBLE AND CHECK OPERATIONS OF THE WASHER.
Aug 01, 2008 | Whirlpool Washing Machines
The dishwasher is not emptying out the water. It needs to reset and finsh the last cycle. Hotpoint DWF 33
pump under bottom front panel might be clogged remove hose clap from pump,cleanout,also can use shop vac.,also remove lower spray arm then remove filter clean and replace,also check under sink make sure drain hose is not kinked,thanks-mike
May 27, 2008 | Dishwashers
Whirlpool Duet GHW9150P Front Load Washer Logo
278 people viewed this question
Dan Webster
Dan Webster
Sal De
