Question about Wacom (EP130EPE) Digital Pen
The pen is active but the clic doesn't work, the mouse is ok but the pen do not clic
  • 2,237 Answers
There is a switch inside, but since it's on the same board, you'll still need to replace it.
Posted on Dec 11, 2009
SOURCE:
My pc doesn't show sandisk cruzer blade 4 gb pen drive whereas it shows others
Sometimes, windwos OS, give same drive letter to different devices, and when you connect both, one is not showing. So, you need to go in to Disk Manage (right clic on "My PC", clic on Manage") and verify if you can assign a different driver letter to your pen drive.
Oct 01, 2012 | SanDisk SDCZ50-004G-P95 4GB Cruzer Blade...
I have an old version of Family Bible Collection Deluxe Edition from Encore Software (CD's) that I want to run on my 64-bit Windows 7 laptop. I cannot get the program to run. Is there a way to make...
If you are using Windows 7, try the compatibility mode Right Clic (use the right button of your mouse )on the execyute file EX: setup.exe or Install.EXE or witch ever the file that start your program first and chose "Property" In that box clic on the compatibility tab tic the box execute this program.... to activate the scroling menu drop it down and chose the compatibility that your program required (Windows XP or VISTA, clic at the botton "Privilege" "Exécute this program as an Administrator Clic apply and clic ok try to install again
Aug 03, 2011 | Encore Family Bible Collection Full...
When I'm using Photoshop CS4 with my Wacom Bamboo Fun tablet, the screen tracking for the tablet only works for half the tablet. This happens with everything else as well, not just Photoshop...
Go to Control Panel, and open bamboo properties. There you select the "pen" tab. In the pen tab you will see tracking. Select pen mode and details. You can map the pad there. After mapping pen mode try it in mouse mode as well. Best of luck!
May 28, 2011 | Wacom Bamboo Fun USB Tablet with Cordless...
Netbook Touchpad not working.
Apenas solucione este problema hace unos minutos,localiza en la esquina inferior derecha el icono que dice Dispositivo Señalador de Synaptics, clic derecho y seleccionas "Toque Rapido para Hacer Clic" y listo!!! si no te aparece el icono tienes que ir a Panel de Control, vas a Mouse, en la pestaña Configuracion de Dispositivo, seleccionas Icono de Bandeja Animado en la Barra de Tareas, ya con el icono en la barra de tareas haces clic derecho sobre este y seleccionas "Toque Rapido para Hacer Clic"
Espero haberte ayudado, bye
Jan 14, 2010 | ASUS Eee PC 1000H Laptop
How do you put the pen in "Mouse mode" on a Genius?
Please follow those steps:
  • Select "Preferences" under the "Options" menu .
  • Under the Digitizer Input section select for input "Digitizer only" and click OK
  • Now configure the menu and screen area and save configuration
  • Select "Preferences" under the "Options" menu and set in the digitizer input section input back to "Digitizer/Mouse"
Jul 24, 2009 | Wacom Bamboo Fun 8.5" x 5.3" USB Tablet...
Point pen fails after falls
I'm guessing something inside the pen was jarred. A basic solution would be to get a replacement.
Also try taking the tip out of the pen and leaving it OUT of the pen for 24hrs.
~Mitchell
Apr 20, 2009 | Wacom Bamboo Fun 5.8" x 3.7" USB Tablet...
My laptop mouse wont work
do you mean the mouse integrated in the laptop or an external USB mouse?
If it is the integrated mouse, try to get an USB mouse, plug it and wait until your laptop recognize it, assuming you are working in Windows XP right clic on My Computer, clic on Properties --> Hardware --> Device Manager , double clic on Mice and other pointing devices, once here, look for the mouse of your laptop (do not mis identify it with the external mouse that you just plugged) right clic on it and clic on uninstall.
Restart your laptop, once in windows again it will recognize the mouse as a new device and will install the drivers again.
Feb 24, 2009 | Acer Aspire 5920-6727 Notebook
Pen doesn't work
ok i had the same problem BUT i opened the mouse pen control panel and under info i unchecked the "support tablet PC feature" and to my amazement it worked. hope it works for you :)
Jan 04, 2008 | Genius MousePen 8x6 (MOUSEPEN8X6)
Acer Aspire 3102WLMi Sempron3200+ no keyboard or mouse activity
from ur update..it seems lik that it's not any soft based errors...it's hardware error..so it's better to hand over that to authorised service expert!!!!dont let anyone repair that!!!it will make ur problem much more bigger!!!!friend!!
Nov 01, 2007 | Acer Aspire 3000 Notebook
Wacom Tablet...PEN not WORKING!!!!
To make the 1st solution even easier, disconnect the tablet from the usb port, lay the pen flat on the tablet surface and plug the tablet back in. Worked like a charm for me.
Feb 23, 2007 | Wacom Intuos2 4 x 5 USB (INTOUS)
Wacom (EP130EPE) Digital Pen Logo
318 people viewed this question
Top Wacom Computers & Internet Experts
Marvin
Marvin
Peter Dragonetti
Alun Cox
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
