Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
Coffee pot turns stops brewing in the middle of the cycle
My Cuisinart Grind and Brew coffee pot is only 1 year old and it is starting to stop brewing in the middle of a cycle. I've tried cleaning all parts that I can, thinking that I've gotten grounds clogged somewhere. Still doing the same thing. I don't have the receipt or box anymore of course and reallllly want it too work! Any solutions to try would be great!
Thank you,
Kim
  • 12 more comments
  • knarfy Jan 21, 2008
    there are three dashes _ _ _ where the time use to be. Does not work anymore, was unplugging and then it would reset, not anymore...Help!
  • judyd Feb 01, 2008
    My Grind and Brew does not complete a brew cycle. I bought it only 2 months ago. I have to push the on/off button about 4 times to get it to brew a whole pot. Very frustrating.
  • Anonymous Feb 06, 2008
    I have the same problem. This coffee maker is a piece of ...junk.
    I tried cleaning etc...nothing works. I'm gonna junk it.
  • Cryela Feb 06, 2008
    I am too experiencing this same problem after only 6 months! How frustrating!!!!! I have tried just about everything I can think of. As of today, I can get no more than 3 cups brewed before the machine becomes possessed and will not stop beeping until unplugged! :( Glad I spent extra on this one.......
  • jeffbrew Feb 10, 2008
    I have a similar problem; the water heater turns off after brewing 3 cups. To get the rest of the water through the coffee I turn off the grind cycle and hit the Power button. This gets another 3 cups brewed. After 3 cycles I have a full pot. I doubt cleaning is the issue. It seems that there is a timing circuit either in the computer or in the heater that is malfunctioning. I suspect that it will require a new part to fix it something that is not user serviceable.
  • Anonymous Feb 17, 2008
    Same problem, my Grind and Brew only brews 3 or 4 cups. Sent it in and 4 months later, my second machine is doing the same thing. I did get a new machine for free, after paying $10 shipping and handling for the new machine and paying to have the old machine shipped back. Not sure what to do now that the new one is also not working! They have a real problem. DO NOT throw away your machine, save it for a class action or company return announcement.
  • Anonymous Apr 13, 2008
    this machine is junk! I've tried everything and it still only brews 2 cups at a time.
  • ironpot May 07, 2008
    We recently started having this problem. We first removed the charcoal filter and then put in two cups of straight vinegar in the water well and let is sit for about an hour, then we ran just the vinegar through. After running it through twice, we put in 10 cups of water and repeated with fresh water 3 times. it went through the cycle each time... it seems to be fixed. I have ordered new charcoal filters and I am keeping my fingers crossed that this has resolved the problem...I also plan to clean this machine more often.
  • Siner May 11, 2008
    We have the same problem. My machine is only 7 months old.
    I changed the filter and that didn't change anything. I next took out the filter and ran two cups of vinegar through the system. Then I ran water through it 3 times. I took someone else's advice and pushed the "1-4 cups" button and it ran through all 10 cups. Go figure. There after it was back to normal.
    I think they need to recall these machines and replace them with the new Grind and Brew Plus. Maybe they fixed this problem with the new machine.
    Hope springs eternal.
  • Anonymous May 13, 2008
    My coffee pot is 7 months old and I was in love with it until 2 months ago when it stopped brewing in the middle of the cycle. What a pain! Just now I put the coffee on and went online to see if I could find a solution. When I read that some people had luck with pressing the 1-4 cup button, I thought I'd try it, because the machine had beeped and of course only 2 cups had brewed! Ugh. Well I pressed the 1-4 button and PRESTO! it worked!!!!! I cannot say how happy I am. Thank You!!!
  • dparent Jun 03, 2008
    Yep Im having the same problem and have had it for about 6 months. I like the thermal pot and the look of the thing so I don't want to go back to a Mr Coffee, but this is getting old. I figured out the 1-4 cup thing and that worked for a while, but now it isnt working either. Replacing the charcoal filter didn't help. I haven't tried cleaning it, so I will give it a shot, but my hunch is it is a computer glitch.
  • Anonymous Sep 25, 2008
    I have the same problem with a Cuisinart, but not the Grind and Brew - just a straight 12 cup auto coffee maker. Cleaning with vinegar and water was no help.
  • Anonymous Mar 24, 2009
    Same as everyone elses. its not kewl
  • Anonymous Mar 26, 2009
    Turns off in middle of brewing cycle and must be restarted several times in order to get 6 sups brewed.
Yup thats the Ticket - EASY FIX -
you have to clean the insides too people... lol.. The best way to do it is to buy citric acid crystals available from your local pharmacy. who knew huh? a couple of tablespoons in distilled water. Brew half the pot and let it sit for 30 min the brew the rest of the pot. Notice the color of your water after your done brewing. probably green from copper.. I could go into much more detail but thats the short answer... brew another pot or two of just plane ole water and bang your good go.. You should do this every month with any coffee pot for better tasting coffee..
Posted on Jul 16, 2008
    New Friend:
I now use a clothes pin to keep the "on" button pushed in. I wedge it in place with my heavy ceramic coffee bean jar. Low tech, annoying, but it works. I'll try de-scaling again but it didn't help before.
Posted on Feb 15, 2013
This is what I finally figured out about this stupid coffee maker. If I push the button to make 1-4 cups THEN it will brew a whole pot of coffee. How stupid is that? For a month or two it would finish a brew cycle on its own but now the circuits inside of are screwed up and we have to program in to brew 1-4 cups to brew a whole pot. It's like a gremlin got inside of it and switched the wires.
Try that with yours to see if that will work.
Posted on Feb 24, 2008
    New Friend:
Citric acid seems to be a lot better than vinegar (dilute acetic acid) for descaling. I was unable to descale an espresso machine with vinegar. However, the strong solution of citric acid worked very, very well. Citric acid also doesn't have the strong vinegar smell or taste.
Posted on Mar 08, 2014
We've had the same problem every three or four months.  I believe the cause is hard water deposits clogging things up.  I clean the coffee maker out, change the water filter, and run several rounds of vinegar water through the coffeemaker (this gets rid of calcium deposits), and the maker is good to go for several months.
Posted on Feb 23, 2008
How am I suppose to clean it if it won't stop beeping/ doesn't run?
Posted on Jul 16, 2010
  • 2,039 Answers
I know you said you clean it but did you use a decaler calcium kill those machine pour 1solution 1part water put it on rince very good the decaler is nasty stuff hope it work cheers
Posted on Jan 20, 2008
2 Suggested Answers
SOURCE: Coffee pot turns stops brewing in the middle of the cycle
If this is not an electrical problem, try the following:
Try running a cup of WHITE vinegar (of course without the coffee), this will clear out anything on the path.
Once you do this, run 5 cups of plain water (again without coffee) twice to clear out any vinegar flavor from the path.
Posted on Feb 01, 2008
Feb 01, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Doesn't complete a full brew cycle before alarm sounds to indicate end of brew cycle. Have to re-start up to 4 times to get a full pot of coffee.... what can be done to solve this issue?
sorry I don't have a solution but actually have the same problem. This is driving me crazy! (not really) I have tried taking the filter out and cleaning the unit with vinegar. nothing helps.
Aug 22, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee Maker only brews 1 cup at a time
Hello. I just talked to Cuisinart and they recomended running a solution of 1 part vinegar and 3 parts water through the brew cycle,then a full pot of plain water to rinse, to remove hard water deposits. The phone # to Cuisinart is 1-800-726-0190. I hope all works out for you.
builderdale
Jan 12, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
My Cuisinart 10 cup Grind & Brew does not finish the brew cycle. After brewing 2 cups of coffee, it beeps 5 times as if the brew cycle has ended. Then it continues to drip very very slowly. It's only...
you need to run a few pots of straight white vinegar through the machine to clean out the lime build up in the tubes. the first time you do it, after it starts to pump the water, shut it off for a few hours and let the vinegar sit in the tubes. after doing this run a few pots of cold water through before making coffee.
Nov 07, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
I Have a Cuisinart Automatic Grind & Brew Thermal that when you start brews a small amount of coffee and then shuts off. I shut off grind and start. After I do that it brews a full pot. We have cleaned...
I do love our Cuisinart pot...but find they only last 2-3 years...so my suggestions is: if the pot is still in warranty, call Cuisinart for a new one...they are great about it. If you don't know if it is still in warranty, call them, give them the number and they will tell you.
jlo
May 30, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart grind and brew
This happens when the machine needs cleaned. Fill coffee maker with white vineger instead of water. Turn grind off, make sure empty pot is in place. Brew a pot of hot vineger. Repeat. Brew a pot of hot water. Repeat. This process removes mineral buildups inside machine. If you have access to filtered water, start using that to brew your coffee. I do and probably do this process 1 per 6 weeks.
Oct 07, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
I have a cuisinart model dgb-600bc coffee grind & brew, didn't have a manual with it when purchased, plugged in it & hit the on button, lights up when pushing in on it, but let it go & it stops, but doesn't brew nothing. HELP -
Aug 26, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Keeps flashing 12:00
I just kept plugging and unplugging the coffee pot. Eventually, the clock stopped blinking, the buttons worked, and all was well.
Jul 19, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Leaking cuisinart grind and brew
Our Cuisinart grind and brew was leaving a puddle under it after making a pot of coffee. I called Cuisinart this week and it turns out the handle of the carafe has to be lined up in the middle of the opening for the carafe. It will be under the word Cuisinart, in the middle.
We have now made several pots with NO residual puddle of water or coffee. It also seems to be making the pots quicker.
Before trying this I had run 2 pots of water with 1/2 cup white vinegar in it also. But it still puddled until we lined up the carafe as noted above.
Nov 30, 2007 | Cuisinart Coffeemakers
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
11,911 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Marvin
Marvin
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
