Question about Philips Magnavox MWR10D6 DVD Recorder
Time resets We have 2 of these in 2 different rooms and record daily. We're starting to miss programs due to the date and times mysteriously resetting. We'll go to change the disc only to find it empty and the unit's time saying that it is yesterday, or 3 days ago, or 12 hours ago. We'll reset day and time and then, blam, find it happened again. It's happening more frequently now. And no, it's not power outages, nothing else is affected.
  • Leo Four Feb 04, 2008
    I purchased a DVD recorder Sept. 2007. In November it started missing set times to start and stop. Finally, I have been repeatedly trying to get the unit repaired onder 90 day time perion. Funai -is difficult to work with. I have faxed them information 3 times . They said they never received it. The unit will not keep time. Philips/Magavox needs to have another company handlw customer service. I am turned off by the treatment of their reps. I will not be looking for another Magnavox product. LF.
  • Anonymous Apr 05, 2008
    Just can't set the time on the Magnavox after using it for only a couple of months. At first the timing worked and then it just quit.
    Don't have the slightest idea why!
    Problem Solver:
  • 9 Answers
MAGNAVOX DVD RECORDER MODEL # MWR10D6: Is a piece of junk. Yet another worthless waste material and rescources. In other words they or someone else could have taken the materials and energy used to assymble this thing and used it for some other appliance or device that would actually work. This thing is so worthless that it was environmentally irresponsible for the manufactures to even make it. Now all it's good for is filling landfills.
My suggestion is to do as I am right now and go onto any and every forum, or message board you know about and warn as many people as you can away from this piece of junk and the SCAM that is being perpatrated by Magnavox and whoever else helped them cook up this scam.
I've even made space for a photo of it and description of how sorry it works on both my and pages.
Posted on Feb 23, 2008
Have Panasonic omnivision VHS PV-D4743S-k 4 head Hi Fi stereo and am having problems setting the timer. Could you help please?
To set the time do the following:
Press PROG*
to display Program.
To set record DATE,
to select:
1~31= one time, or
WEEKLY= same time
each week and
press SET.
To set remaining items,
to select and
press SET
to set START/ STOP times,
CH (channel) or LINE
input (p. 35), and tape
speed (SP, LP, SLP).
Press PROG
to end programming.
To Enter More Programs,
to select and
press SET
to set an unused program
number, and then repeat
step 2.
Press PROG
to exit.
The “Timer” Indicator lights up on DECK.
• You can do Timer Recording with the power on or off.
• “TIMER REC WILL START SOON” appears on-screen for 2 minutes
before Timer Recording starts. If DECK is in DVD mode, no message
appears, but the VCR REC Indicator, the VCR mode indicator and
“REC” will flash on Multi function Display.
Hope this helps!
Brad Nelson
Mar 17, 2008 | Televison & Video
Logik recorder - error message - cannot schedule recording, there is already a timer at the same time on this channel. turned the box off at the wall & retuned. Any suggestions? Thank you. x
check programmed recordings you will have a clash possibly in time and date on another channel. If the dvd records two channels at once normally check if it has two channels already set up at the same time to record i the scheduled recordings.
you may have two different channel positions that are the same tv station and have set up two different channels to record the same show. and then you may be trying to record another different channel at the same time. check and delete extra channel schedule.
Another way to have this is as an example say programmed record at channel nine f0r show 1 at 7:30 to 8.35 day xyz and then you set up show 2 to record at channel nine say from 8:30 to xyz this will use two time frames during the overlap from 8:30 to 8:35 on day xyz and if you decide to record a third show you can't between the overlap time frame
Jun 25, 2016 | Televison & Video
I have a Panasonic NV-FJ630B VCR. After several years of successful use, in the last 2 days, it has started failing to initiate recordings at the due time. It accepts programme references in Video Plus+...
Check that the PDC is not on, as this can cause the program to be missed. As the signals can go missing to tell it to record the event. In otherwords it's waiting for a signal that never comes!
Apr 04, 2011 | Panasonic Televison & Video
VHS recording
While setting up your timed recording, scroll through the date, daily or weekly should appear, make your choice then enter the rest of the info.
Jul 22, 2009 | LG RC897T DVD Recorder/VCR Combo
RCA model DRC8335 Loosing the date and time
That will be a problem from the text side of the broadcast, the clock is set from the text transmission, ( in other words a problem from the transmitter ) possibly due to digital switchover or work on the transmitters. One possible solution would be to turn off auto clock setting, and/or auto summer time adjustment.
May 16, 2009 | RCA DRC8295 DVD Recorder/VCR Combo
Toshiba d-r400 recording
I don't see anywhere in the program menu to input a channel number to be recorded, only date and time.
May 03, 2009 | Toshiba D-R400
I try to reset my computer to a restore date in order to locate email addresses that disappeared luck after going through the motions the response is that the system has not been reset...
yes it does that when the date you choose is unable to be restored...this might be because files are missing or corrupted ...try again a few times and choose an earlier date ...but will not find any missing or deleted data ...only the settings are restored and the programs...
Apr 08, 2009 | Dell Inspiron 2200 Notebook
Timer Recording
To schedule a weekly or Mon-Fri program on the DVD scroll back in the "date" box (instead of forward to a future date. You will have options for once a week or Mon-Fri.
Jul 27, 2008 | Panasonic DMR-E75V DVD Player/VCR
Weekly timer recording not working
Have you tried setting the clock to manual mode: Page 18 in the manual I think.
Jun 30, 2007 | LG DBRH197H DVD Player/HDD Recorder
Philips Magnavox MWR10D6 DVD Recorder Logo
87 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
