Question about RCA F32TF720 32" TV
Yet another hissing/buzzing noise from back of TV
As soon as the power cable is plugged in the noise begins.
With the back off it is clear that the noise is coming from the main board at the bottom and not from the board that attaches to the tube.
Absolutely nothing works, will not turn on, power button does nothing, no lights on anywhere.
Remote is missing, is there some sort of reset on the unit itself?
Any help is appreciated
Thanks!!!
  • 129 Answers
Good day.
Check for the horizontal output transistor, flyback and filter capacitors.
Any of these being shorted can cause the problem.
chris
Posted on Mar 14, 2008
NS-LDVD32Q-10A buzzing noise
Try another input and another source such as a DVD player. If you still get the buzzing sound, you could have a faulty power supply output or a fault in the audio circuit of the main board.
Jan 27, 2013 | Insignia NS-LDVD32Q-10A LCD TV
Sanyo 25" 10yr old model
is the sound like hissing or like a spark something like?hissing can caused by leaking of high voltage that is dangerous and sould be fix right away
Jul 13, 2011 | Sanyo DS25390 TV
I have bought an optical fibre cable to connect from my jamo a305 to my new sony nx810 tv and im getting a buzzing sound, there are 2 optical fibre outputs on the back of the amp, which one do i connect it...
Have you looked at the manuals?
http://www.retrevo.com/search?q=sony+nx810
A TV won't run external speakers directly. Besides, the TV-related audio should originate at, say, the cable Box, and go straight to your (presumed) AV receiver for the best possible decoding and reproduction.
Buzzing is an analog phenomenon and is NOT carried by optical cable in any case.
Buzzing is usally AC line noise leaking into an un-shielded cable somewhere or a floating ground. If the AC plug is reversible, try that. Sometimes the buzz is from an attached device. Make sure all audio cables are plugged in tightly at each end and routed away from or at right angles to any power cords and away from other sources of strong magnetic fields like TV's. I've also seen variable track lights induce noise but it's usually minor.
Try rotating the power cord in the wall outlet.
If it still buzzes with no cables or anything external attached there's an internal problem.
Disconnect the input(s) and see if it hums in the absence of an audio source. A bad audio cable shield or unwisely-routed audio cables will allow entrance of unwanted signals from external power sources, magnetic fields, even dimmer-controlled track lights. Sometimes, simply reversing the orientation of the ac power plug can eliminate humming.
Reverse the cables Left to Right to see if it stays with the cable or the input channel. Follow it back to the source, isolating in the same manner. Eventually you will find the entrance point of the hum. Frequently a cable's ground will oxidize over time and simply removing and reattaching the cable with a twisting motion will re-establish the shield.
May 02, 2011 | Jamo A 305 Main / Stereo Speaker
TV Just Started Making a Humming/Buzzing sound
Replacing a flyback is not something I would suggest for anyone with no electronics experience. Second, lets see where the noise is coming from first. Take off the back and listen to the noise. The flyback will be at one end of the large red wires that go to the tubes. Sometimes the connection at the tube is not 100% and the noise comes from there. BE CAREFUL - there are high voltages going through this red wire that can be dangerous even with the set UNPLUGGED!! IF the noise is coming from the connection at the tube, with the set unplugged, carefully turn the rubber cap back and forth touching only the rubber part with one hand. Put the other hand in you pocket while doing this.
If the noise comes from the flyback side, if you can solder, again with the set unplugged, try resoldering the pins on the transformers. That may resolve the problem.
Keep me posted.
Dan
Feb 13, 2009 | Samsung HCL5515W 55" Rear Projection...
Noise coming from power supply
When we turn our TV the humming and buzzing begins! We cn mute it and it goes away and then it when we turn the sound back on the sound is back! How can we fix this?
Sep 18, 2008 | Polaroid FLM-323B Television
Annoying buzz!!!
be certain its not your cable providing the noise by being ungrounded .or interference from some other device connected or around tv.
disconnect everything except the cable.
turn off all dimmer lighting around tv. try now.
are you using a cable box, if so bypass ,plug cable directly into tv.
try sound again.
then remove cable and plug in dvd or vcr. and try audio now.
if it continues no matter,
its a warranty repair or just use external speakers ,cable boxes can control the audio to ext speakers.
Mar 26, 2008 | Televison & Video
The Back plug of my 60 GB
Have you tried updating to version 2.2? It came out last night. Furthermore, can you try this on a different TV so that you can eliminate that as a variable?
Mar 19, 2008 | Sony Playstation 3 (PS3) Console
Distortion/noise and buzz in front left speaker
Try to see if the reciever will make the buzzing/noise without anything connected to it except power, and speakers. Tune into a local radio station and see if the noise continues. If the noise has stopped, then you know there is an issue with the player or cable.
Dec 28, 2007 | Onkyo TX-SR503 Receiver
WHEN EQUALIZER IS ON LOW GRADE BUZZING/HISSING HEARD.
Have you isolated the problem to the equalizer only? By that, I mean remove it from the signal chain and bypass it completely. That's the first thing.Does the system make noise without it in? If dead quiet when removed then you go to step two.
If the noise returns when the EQ is reconnected, you should eliminate crappy or broken cables, connectors etc. Replace with a known good working set. Still there? Buzzing infers either a ground issue or some kind of power supply problem, only if the previous stuff is eliminated. Do this first, then ask again.
Nov 08, 2007 | AudioSource EQ-200 Home Equalizer
Buzzing noises + white lines
hey there. i have the same problem. it is the cable box though. i got rid of it by plugging some cables from the box to the surround system. seems it diverted some of the extra power and the buzzing stopped on my pani px70e. might help u, might not :)
Oct 31, 2007 | Televison & Video
RCA F32TF720 32" TV Logo
128 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
