Question about Nokia E71 Smartphone
I have a nokia e71 and am trying to remove the case to replace the screen but with no luck. is there any where that i can find insructions on how to remove case thanks
  • 311 Answers
Http://thenokiablog.com/2009/04/26/how-to-disassemble-nokia-e71-replace-faceplate/
Posted on Dec 21, 2009
Trying to access the Nokia E71 unlock code, currently locked to Vodafone. pls help
Hello, it's possible to unlock Nokia E71 via USB or via network codes (in case it's locked to Vodafone Australia or Spain) on Fastgsm.com. I hope it helps.
Apr 17, 2013 | Cell Phones
Local mode e71
Hi first of all insert another and try, if the problem persist follow this link E71 local mode solution and remove the indicated component.However, problem still remains the same contact mobile repairing shop.You need to change /reball the battery IC.Good luck.Thanks for visiting fixya
Jul 12, 2012 | Nokia E71 Smartphone
Nokia e71 blank screen
If the phone is working good without showing any display on the screen , the first step is change another LCD and if the problem still persist contact mobile repairing shop to change the display IC or check it out all the display related components.Good luck
Feb 01, 2012 | Nokia E71 Smartphone
My nokia E71 cannot be unlocked. the keypad wont function. After several periods of turning on anf off, the displays is " continue using phone in offline mode? hoe can i select the answer between yes or...
had the same problem... remove the battery for an extended period of time and try again. unfortunately for me the phones screen now refuses to turn on, the keyboard woks now but the screen is completely black- best of luck with yours
Aug 22, 2010 | Nokia E71 Smartphone
My nokia e71's display frequently goes off and fails to return even after switching it off and replacing the battery. it however still receives calls but am not able to tell who is calling.i wonder whats...
Hi
The problem you are experiencing on your phone has to do with the screen of your phone.
Since the phone comes on and receives calls then all you need to do is to carefully open your phone with a phone screwdriver and check if there is something like an ink substance on the screen.if you see the substance on your screen then your screen could be damaged and you need to replac your screen so that your mobile phone could work perfectly.
BEST OF LUCK
Jun 17, 2010 | Nokia E71 Smartphone
Unlock E71 nokia phone to use new sim card
if you can still access the Old sim card try this link http://www.unlocking.com/Nokia-E71-Unlocking.html Good luck..
Apr 30, 2010 | Nokia E71 Smartphone
How to change casing for NokiaE71
Hello
You can follow the link below, how to disassemble Nokia E71 and replace facelet.
http://thenokiablog.com/2009/04/26/how-to-disassemble-nokia-e71-replace-faceplate/
Feb 08, 2010 | Nokia E71 Smartphone
Its hard to open the battery cover, please help me
Want to change how your Nokia E71 looks? Why not try a different colored keypad or faceplate? Here are photos and instructions which show you how you can do it yourself. Even though it’s simple, I have to warn you to only try this if you are prepared to risk ending up with a broken phone.
For the extra faceplates and spare parts, many people seem to like CNN.CN. They include the Nokia E71’s faceplate, bottom cover and even a whole body replacement. The instructions below will show you how to remove just the faceplate and bottom cover.
I purposely omit the instructions that will enable you disassemble the phone further because the photos just look plain scary.
Release battery cover.
Remove battery cover.
Unscrew four T4+ screws.
Open the two clips.
Do the same on the other side.
Lift the bottom of top cover NOT the bottom cover!
Remove the top cover as shown.
Press out the qwerty keypad.
Remove bottom cover.
Result That’s it! Here’s a sample result from HoFo member rapidstar who replaced the keypad on his Grey Nokia E71 to white.
Dec 17, 2009 | Nokia E71 Smartphone
How do i pull apart my nokie E71 to clean the screen?
Here is a website with a pictured tutorial on how to disassemble your E71.
Be warned that doing so would void your warranty. So unless you don't have a warranty I wouldn't take the E71 apart to clean the screen.
How to Disassemble Nokia E71 Housing
Apr 15, 2009 | Nokia E71 Smartphone
Nokia E71 Smartphone Logo
148 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
Laxman Bisht
Laxman Bisht
