Question about RCA Televison & Video
We have a universal rca remote RCU703SP and a Toshiba tv. TV doesn't have a menu button. How do I get the menu button to work on the remote?
  • 520 Answers
It sounds like the code that is entered now is close but not the true one for that TV. There are usually more than one code with each device that the remote controls. Try the other codes first. If that does not do it then you will need to do what is called a code search. This is done with the remote control. Look in your manual to find how to run this search. Be patient though. This process is tedious. Once the correct code is programed you can retrieve the number from the remote and wright it down. Just in case. Hope this helps. Good luck.
Posted on Dec 10, 2009
SOURCE:
What are codes for a Toshiba TV and a Samsung DVD player?
The Toshiba TV could be 105, 162, 160, 161, 049, 072, 109, or 118.
You can use the CODE SEARCH feature of your RCA universal remote to find a code that will work with the Samsung DVD player.
Dec 28, 2015 | RCA 3-Device Universal Remote with...
I have a ge universal remote and have a toshiba tv dont know codes and how to programe it could you please help?
Which GE universal remote do you have? Does the remote use a 3-digit or a 4-digit code? To program most GE remotes for a TV, turn on the TV. Then press and hold the Code Search or Setup button until the indicator light comes on. Then press and release the TV button. Enter the first code available for your device. The indicator light should go off then check if the remote controls the functions of the TV. Repeat the above steps if the code doesn't work or doesn't control all the features of your TV.
The manuals and code lists for GE remotes are here: http://www.jascoproducts.com/support/universal-remote-codes.asp .
Toshiba 4-digit TV codes are: 0159 0178 0109 0120 0181
.............0105 0049 0095 0170 0260 0358
.............0394 0924 0012 0095 0117 0141
The 3-digit codes are 170, 181 or 641 for Toshiba HDTVs.
Please note that the remote probably only has codes for devices that were released 6 months or more before the remote was programmed. If your TV is newer than your GE universal remote, you may need a newer remote.
I hope this helps.
Jul 06, 2011 | RCA Televison & Video
I need the Magnavox TV codes for a RCA remote control model RCU703SP.
You can get the codes on the link below if the magnavox codes do not work try the philips codes Philips and magnavox are made by the same people.
http://remotefinder.rca.com/default.aspx?site=rca
Good Luck
Nov 28, 2010 | RCA Universal Remote Control
How do i program my remote control rcu703sp and my
Programming a Device using Code Search:
1.
2.Manually turn ON your device (TV, VCR, Cable Box)
3.Press and "HOLD" CODE SEARCH
4.Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type
of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
5.Release CODE SEARCH.
6.Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
7.Once the device turns off, press and release ENTER.
8.With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
1.
2.Find codes for each device and brand below.
3.Press and "HOLD" CODE SEARCH.
4.Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable).
When the selected device button flashes proceed to the next step.
5.Enter the three digit code from the TV, VCR or Cable Box code lists.
6.Release CODE SEARCH.
7.With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using
another code number from the lists.
Mar 16, 2009 | RCA Universal Remote Control
Which button on my rca univeral remote is the code search
i need code list of universal rca remote control to tv, toshiba
Dec 28, 2008 | RCA 3-Device Universal Remote with...
RCA universal remote RCU703SP wont program Magnavox TV
cheap universals dont hold as many codes, the best universal remote is the all for one range with the best being the comeleon
Jul 23, 2008 | Philips Magnavox Learning Universal Remote
Programming rca universal remote for my toshiba tv
I can't exactly help you, but can you tell me how you programmed the remote to your TV, because I cannot get mine to work...
Apr 03, 2008 | Toshiba 42H81 42" Rear Projection...
Televison & Video Logo
13 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
