Question about NetGear WGR614 Wireless Router
How do I hook up the router ?I bought a compaq laptop from a friend, it came with a router (netgear)
  • bar_kokah Dec 11, 2009
    how do i get free smtp to send mails to customers
  • 2,276 Answers
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Posted on Dec 13, 2009
SOURCE:
I bought a netgear from someone to hook to my hughes net modem & hav no idea how to begin to get it hooked up
I rcommend you RESET your Netgear router first.
To RESET the Netgear, power up the Netgear then press andhold the RESET button at the back of the router until all the LEDs flash. Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password You can now change the admin password and configure thewireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jun 12, 2011 | Computers & Internet
I just bought a laptop computer and I already had a desktop. My internet provider is Hugesnet Satelite. I bought a Netgear N600 wireless dual band router thinking I could just hook it up to my desktop...
The HN9000 should have an ethernet port. You will require two ethernet cables to connect the desktop to the router.
1. Connect the ethernet cable from the Modem to the Ethernet Input port on the Router (It is generally placed away from the other ports on the back of the router.) 2. Connect another ethernet cord from one of the output ports on the router to the desktop computer. 3. On the laptop, turn on your wireless card. The process for this differs from computer to computer. If you were to provide the model of laptop, I could provide you specific instructions. 4. The network setup should be complete.
If you need more help, let me know by replying to this solution. Thank you for using FixYa!
Apr 01, 2011 | NetGear Computers & Internet
I am trying to setup a desktop (connected to
i have netgear fs 605 vs/fs608 v2 how to get connected with internet ?
Jan 28, 2010 | NetGear WGR614 Wireless Router
A friend gave me his router to instal to my
You should do a factory reset using the reset button on the back using a paperclip.
Then you should insert the cd that your friend should also have given you (he didnt Hmm) if not you open an internet explorer page while hooked up (by wire) to the router and type into the address bar 192.168.1.1 on most netgear
The username is admin
and the password is 1234
From there you can use the setting your ISP gives you and also set wireless up.
If this information was useful please click
Aug 16, 2009 | NetGear WGR614 Wireless Router
PC laptop will connect to the internet MacBook Pro Won't
Check your router's IP address from the Compaq machine. Get a command prompt and type ipconfig .all
Then wright down the IP settings.
Check the IP settings of the Macbook Pro. Adjust settings. You can give a Static IP also. If needed. But you have to set the default gateway -Enter previouse IP settings for those.
Check ur Wi-Fi settings also.
If this is helpful to u please rate
Thanks
Wish U Luck
Jun 16, 2009 | NetGear RangeMax WPN824 Router
Connecting laptop to a friend's netgear
You can have your friend log into the router with their laptop and check the setting in the router. Of course, your friend will need to remember what his password is for the router as well. If he doesnt remember that, then the only solution is to reset the router to the default.
Feb 16, 2009 | NetGear DG834G Router
Connection with netgear to laptop
Helen, you should be able to connect from your laptop to your router wirelessly. From what I understood your router is hooked up to your PC directly. If that's the case from your PC connect to your router and enable wireless. Go to Netgear support web page to find out how to do it. Once enabled, you should see your router's name in the list of available wireless networks on your laptop
Feb 07, 2009 | NetGear DG834 Router
Laptop with broadband internet and router. how to connect PS3?
This is what you have to do:
First, disconnected the router form the PS3.
Connect the router to the incoming cable and setup from the laptop using the setup wizard.
Once you have connected to the IPS then disconnect the router, connected the PS3, then the router.
You should be able to connect to the Internet.
If you have any question related to this router, please consult your router hand book, or repost your question or e-mail me at frcs68@hotmail.com,
since this router has several feature, need to configure in order to secured the net work.
Nov 10, 2008 | Sony Playstation 3 (PS3) Console
Wireless routers
Just plug the cable modem ethernet into the input to your router and you will be fine. Just remember, if you decide you want to make any changes to your router settings through your browser, make sure you hook up an ethernet line from your laptop to the router before making any changes. The reason for this is if you make a change in security settings on your router while wireless, the router will reboot and if your laptop did have the settings changed in it, you can be locked out.
Not that you can't get back in, but it is a pain to have to do.
Jan 14, 2008 | Arris SURFboard SB4200 Modem
NetGear WGR614 Wireless Router Logo
46 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
