Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Picture only at top
I have a 52" samsung that only has a picture at the top of the screen. It goes all the way across the screen. I think it has something to do with horizontal.The picture is too small to tell if it will be a good picture or not if it was big. Any suggestions?
  • 82virago920 Jan 23, 2008
    They asked me to rate you. I couldn't rate you because I need to give you more info before you can help.
    Sergeant:
  • 395 Answers
What is the model # on the back of the set. sometime there is a sticker with the model # on the side as well. this is information I need to help you.
Posted on Jan 20, 2008
  • Robert Johnson Jan 23, 2008
    what model # ? I have access to samsung info that I can give you. there may be some easy fix. I'm not a mind reader so based on the info you give me helps me help you. in this case less is not more. you can always re-rate it later. only you can change the rating.
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
Tv screen resolution
Check your menus. There should be one menu that allows you to resize the picture to the screen size. (Most likely a submenu in the video menu).
Jun 14, 2017 | Samsung LNT5265FX 52 in. LCD Television
Tv picture too big
You can probably change the picture in picture setting with your tv and that should help
Jan 01, 2012 | Samsung CLS55 Televison & Video
Right half of LCD screen goes dark. Like the brightness and colour are bleeding away. The image is still slightly visible beneath the dark. Some horizontal lines also appear across the entire screen, about...
I have the exact think happening on my Samsung LN46A530 and it has just been 2 years since I bought it. There better be a cheap fix for this because a $2,000 product has to last a lot longer than 2 years.
Aug 21, 2010 | Samsung LN46A530 46 in. LCD HDTV
52" samsung
the problem of your tv is the backlight...a backlight is a set of cold cathode bulb that is inplace at the top and bottom of your monitor..this light illuminate the screen once this light is busted your screen will go black.this lamp is replasable...you can replace them once they are busted...
hope this could help you..good luck!
your rate is important to this help..pls
May 21, 2010 | Samsung 52 in. Flat-Panel LCD HDTV
PICTURE WONT FIT ALL CHANNELS
Look for the button labeled format , zoom, aspect or picture size and press it until picture is the size you want.
Mar 25, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
52" Samsung that the top half of screen goes black.
the HDTV has a heat-related problem check your fans. Do they remove heat? the vertical chips paint the screen from top to middle and, middle to bottom so; your top to middle vertical chip is overheating as is your video chip; that is why you have "glitter" in the back ground. get rid of the heat or, bye,bye TV.
May 20, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
Missing bottom 1/4" of screen
It is possible that you have zoomed in your picture inadvertantly. Try going to picture settings and making sure that you are zoomed out all the way.
Hope that helps!
Dec 30, 2007 | Samsung HL-P5063W 50" Rear Projection HDTV
RCA 52" HDTV Rear Projection TV MM52110JX1
Replace FL231 400ma fuse. this will fix your problem.
Oct 26, 2007 | RCA D52W19 52" Rear Projection Television
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
23 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
