Question about Texas Instruments TI-84 Plus Calculator
How do you enter seconds (") on the calculator?
  • Texas Instru... Master
  • 8,080 Answers
You have two ways to enter the (") on the calculator.
  1. Press [ALPHA] [+] (") [ENTER]
  2. Use the catalog [2nd][ 0]. The list of commands opens. Scroll up to reach the end of the lis, and continue to scroll until you reach it. It is the 4th from the bottom.
Hope it helps.
Thank you for using FixYa and for rating the solution.
Posted on Dec 10, 2009
Testimonial: "Thank you, very helpful."
  • k24674 Dec 11, 2009
    Et tu Brutus, gratiae.
Enter degree minutes seconds
Enter the degrees, a decimal point, then two digits for the minutes followed by two digits for the seconds (then followed by any fractional seconds). You can then convert to decimal degrees with the HMS-> function.
For example, to enter 1 degree 36 minutes 24 seconds, press 1 . 3 6 2 4 ALPHA ALPHA "H" "M" "S" right-shift "0" ENTER
Jun 30, 2013 | HP 50g Graphic Calculator
How can i convert degrees,minutes and seconds to decimal degrees in a casio fx-82MS
Use the DMS key marked degree, apostrophe, double quotation mark.
Lets us call it [DMS]
To enter an angle in degree minutes seconds or hour, minutes, seconds, type in the number of degrees, press the [DMS] key, enter the number of seconds, press the [DMS] key, enter the number of seconds then the [DMS] key. Press = the calculator displays the value in DMS units. If you press the DMS key again the number displayed is converted to decimal degrees.
Example:enter 12 degrees, 15 minutes, and 25 seconds
12 [DMS]15[DMS]25[DMS] =
Calculator displays 12 deg 15'25"
Press the DMS key again and you see 12.2569444
Feb 19, 2013 | Casio FX-82MS Scientific Calculator
How do you enter Degrees Minutes Seconds on acasio fx-9750 Calculator
To access the DMS function, turn calculator ON, go to the RUN screen. Press OPTN F6>, F5:ANGL You will see a csreen as on the capture.
To enter an ganle value in DMS, enter the degrees, press F1, enter the minutes, press F1, enter the seconds and press EXE. the value may be displayed in DD Decimal degrees. To conver press F4. To convert back press F5 (notice the backArrow on the TAB).
Oct 30, 2011 | Casio FX-9750GPlus Calculator
I know how to convert between decimal degress and degrees, minutes, seconds, but how do you enter degrees, minutes, and seconds directly?
Enter it as DD.MMSS and then press 2nd [DMS-DD] to convert it to decimal for further calculations.
For example, to enter 21 degrees 34 minutes 45 seconds, enter 21.3445 then press 2nd [DMS-DD].
May 12, 2011 | Texas Instruments TI-30XA Calculator
When I try to use arithmetic operations in RPN mode; the calculator computes the (g) function. Example: 2(enter) 5(enter) (x) will result in 25 (5^2) as opposed to 10 (5 x 2) =s
Your key sequence is calculating 5*5, which is 25. If you press * again, you will get 50, which is 2*5*5. The second ENTER lifts the 5 into Y, leaving two copies of 5 on the stack, which get multiplied together.
To calculate 2*5, press 2 ENTER 5 * . Note only one ENTER, used to separate numbers.
Mar 22, 2011 | HP 12c Calculator
How do i enter 46degrees 15minutes into my ti-36x calculator?
Enter DMS (Degrees/Minutes/Seconds) values as D.MMSSs, using 0s as necessary:
  • D degrees (0-7 digits)
  • . decimal-point separator
  • MM minutes (must be 2 digits)
  • SS seconds (must be 2 digits)
  • s fractional part of a second
For example, enter
  • 46° 15' as 46.15.
  • 179° 9' 2.54" as 179.090254, note the 0s in front of the 9 and 2.
Before using a DMS value in a calculation, you must convert it to decimal with [2nd] [>DD].
Jan 13, 2011 | Texas Instruments TI-36 X Solar Calculator
When trying to find the determinant of a matrix when i press OPTN and then F2 the MAT option doesn't come up, as well as F3 with the Det option.
When you press the OPTN key you see Tabs at the bottom of the screen. The second one from the left should be the submenu for matrix operations.. When you press F2:MAT, the new tabs are Mat, M>L (Matrix to List), Det (command to calculate the determinant etc.
Here is a detailed account of how to calculate the determinant of a square matrix.
I assume you know how to define your matrix, but I will repeat it here for others who might not know. You can skip to Calculation
1.Turn Calculator ON. If there are no icons, press [MENU].
Data Entry
2.Use arrows to highlight [MAT] icon. Press [ENTER]
3.Highlight the first line where it says Mat A. Use the right arrow to enter the dimensions of Matrix A. Enter 3 and press [EXE]. The cursor moves to the second dimension. Press 3 and press [ENTER].
4. The matrix entry screen appears.
5. Enter first matrix coefficient a_11 and press [ENTER]
6. Enter a_12 and [ENTER]
Key in last coefficient a_33 and press [ENTER]
Calculation
Press [MENU] and [RUN]
Press [OPTN][F2:MAT][F3:Det] Command echoes on screen as det
Press [F1:Mat] echoes on screen as Mat; screen shows det Mat
Press [ALPHA] A The screen displays det Mat A
Press [ENTER] to calculate the determinant.
If the matrix is not square, you cannot calculate its determinant.
Dec 13, 2010 | Casio FX-9750GPlus Calculator
When i click the F2 and F3 it doesn't show MAT or Det...?
When you press the OPTN key you see Tabs at the bottom of the screen. The second one from the left should be the submenu for matrix operations.. When you press F2:MAT, the new tabs are Mat, M>L (Matrix to List), det (command to calculate the determinant etc.
Data Entry
Calculation
How do I find degrees minutes and seconds on my ti 84 plus?
On this family of calculators, you do as follows
  1. Enter the first number (degrees), ex:15
  2. Press [2nd][APPS] (ANGLE) to access the Angle functions
  3. Select [1: degree symbol] [ENTER]
  4. Main screen shows 15 deg
  5. Enter the minutes, ex 25
  6. Press [2nd] [APPS](ANGLE) to access Angle functions
  7. Select [2:' apostrophe] [ENTER]
  8. Screen echoes 15 deg 25'
  9. Enter the seconds number, ex 32
  10. Press [ALPHA][+] (") to access the double quotation mark.
  11. Screen echoes 15 deg 25' 32"
  12. Press [ENTER]
  13. Calculator converts this in decimal degrees 15.42555556
To convert this back to DMS, press [ANGLE][|=>DMS][ENTER] and the calculator displays the original value 15 deg 25' 32"
Jan 11, 2010 | Texas Instruments TI-84 Plus Calculator
TI 86
Press "2ND" "MATH" "F3" to invoke the Angle menu.
Enter the number of degrees, press "F3", enter the number of minutes, press "F3", enter the number of seconds, press "F3", then press "ENTER".
Feb 15, 2008 | Texas Instruments TI-86 Calculator
Texas Instruments TI-84 Plus Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Steve Allison
Steve Allison
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
