Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
Blue shadow across my screen
I own the JVC AV-48WP30 and I dont know what to do. Is there a bulb that needs to be replaced? Can I fix this probem myself? A bluelight/shadow glares across the top 3/4 of the screen and goes all the way from left to right.
Any ideas???
  • Teddy R Mar 08, 2008
    1. I have the same issue with my JVC AV-56Wp74 rear projection. It was new in 2003. Just a month ago the picture had this blue wave from the left to right side at the top. The words get double imposed also. I have talked to a tv repair shop and they are giving me a price of $250-325. I was hoping I could buy the parts/board and do it my self. What is your thoughts.
Go into the convergence function from the menu and see if it works. If it does not then the convergence board has a problem. JVC still sells the part.
Posted on Feb 26, 2008
6ya staff
SOURCE:
Blue & yellow in the picture across the screen
It sounds like your alignment is off, there should be a switch in the front panel that turns on a crosshair looking display, then use the dials to move red and green onto the blue lines. this should fix the problem
Aug 26, 2011 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP30 Convergence Problem
If you know how to solder, I would suggest to just replace the STK ICs and some of the low value resistors. If you do not how to solder replacing the entire board is the way to to get the TV fix. You might still need to adjust the convergence after the board replacement.
Let me know if you need further assistance.
Jul 22, 2008 | JVC AV-48WP30 48" Rear Projection...
My jvc model # av-48wp30 tv has a blue shadow
Convergence needs repair. The AV48WP30 convergence repair kit from www.tvrepairworld.com has the parts and the CD with step by step repair instructions.
Aug 08, 2010 | JVC AV-48WP30 48" Rear Projection...
Blue and Yellow Shadows
Ur convergence are dead.Must know how to solders?Have solder iron,solders,solder wicks?Must replace 2 STK convergence IC,and some or all it resistors.Tries websites to buy a convergence kit at Tv repair Wolrd.com,Tvrepairkits.com to repair it ur sself.The shop will cost $300 for parts and labors.
Mar 29, 2010 | JVC AV-48WP30 48" Rear Projection...
On our JVC AV-48WP30 48in, red shadows
some how the convergence ckt went bad,common problem to pj televisions.
Mar 19, 2010 | JVC AV-48WP30 48" Rear Projection...
Looks like 3D Picture
You probly have a convergence cicuit failure. Replacing the convergencr IC's will probly fix it.
I recommend a professional repairman to
do it though. Particularly if it needs further adjustments after the IC's are replaced.
Jun 16, 2009 | JVC AV-48WP30 48" Rear Projection...
Convergence problems?
If you know how to solder on printed circuit boards Sure, easy repair.
Jun 02, 2008 | JVC AV-48WP30 48" Rear Projection...
Red and Blue shadowing (Where are my 3d glasses)
There are two convergence IC's that are bad and need to be replaced, as this happens to almost every rear projectionj set ever made. They are stand up IC's , on a heatsink and they start with STK. They are soldered into place and this set has no user replaceable parts inside of it. If you have no solid state repair experience, you really should call out a trained tech to assist you in this repair. A TV set is no place to be diggin and experimenting inside of.
Sep 24, 2006 | JVC AV-48WP30 48" Rear Projection...
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
197 people viewed this question
Top JVC Televison & Video Experts
Todd Hill
Todd Hill
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
