Question about Fujitsu Siemens AMILO Pro V2000 Notebook
I have recently purchased a 3.5 mm jack cable linked to an rca out, will i still need a sound card to record?
  • 332 Answers
If you can hear sound from your laptop then the will be no need for a sound card to record. But if you can't hear sound then you will definitely need a sound card.
Best regards
Posted on Dec 11, 2009
I have a yamaha speaker yst-m7 but with no hookups I need all the wire
Amplifier Output 5W/Channel x 2 Frequency Response 90 Hz - 20 kHz + or - 3dB Speaker Unit 6.5 Cone, Full Range Magnetic Shielding Yes Diminsions (wxhxd) 3-3/8"x 8-1/2" x 5-3/4" Weight R: 1lb. 9 oz.; L: 1lb. 5 oz. Included Accessories AC Adapter, stereo mini plug cable, RCA pin plug cable Colors Black, Platinum Amplifier Output 5W/Channel x 2 Frequency Response 90 Hz - 20 kHz + or - 3dB Speaker Unit 6.5 Cone, Full Range Magnetic Shielding Yes Diminsions (wxhxd) 3-3/8"x 8-1/2" x 5-3/4" Weight R: 1lb. 9 oz.; L: 1lb. 5 oz. Included Accessories AC Adapter, stereo mini plug cable, RCA pin plug cable Colors Black, Platinum Amplifier Output 5W/Channel x 2 Frequency Response 90 Hz - 20 kHz + or - 3dB Speaker Unit 6.5 Cone, Full Range Magnetic Shielding Yes Diminsions (wxhxd) 3-3/8"x 8-1/2" x 5-3/4" Weight R: 1lb. 9 oz.; L: 1lb. 5 oz. Included Accessories AC Adapter, stereo mini plug cable, RCA pin plug cable Colors Black, Platinum Amplifier Output 5W/Channel x 2 Frequency Response 90 Hz - 20 kHz + or - 3dB Speaker Unit 6.5 Cone, Full Range Magnetic Shielding Yes Diminsions (wxhxd) 3-3/8"x 8-1/2" x 5-3/4" Weight R: 1lb. 9 oz.; L: 1lb. 5 oz. Included Accessories AC Adapter, stereo mini plug cable, RCA pin plug cable Colors Black, Platinum 3.5 mm. stereo mini jack x 2.
3.5 Stereo mini plug cable.
RCA Pin plug cable.
3.5mm stereo mini jack x 2.
3.5 stereo mini plug cable
RCA Pin plug cable
You might get these on Ebay im not sure which country you are in this might guide you to one
you could get this on Ebay if you dont have an account you will need to create one
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
when you get to the paypal login page at the bottom you will see new to paypal sign up tab
paypal to create an account
paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress
be very specific when you type in the search
always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described
you will even see the pictures of your item so you cant make a mistake and get them home delivered
hope this helps
May 20, 2011 | Yamaha YST-M7 Computer Speakers
Tip
How to computer capture a sound card
<p>Record and recording the sounds through the computer sound is a relatively simple procedure that only a free space on the hard disk, suitable software and a short profile of TRS cable is required. Windows computers usually come with an audio recording program, from the entertainment equipment a program is found in the Start menu. <br /> <p><br /> <p>1. Turning off the computer speaker's audio jack of your computer's sound card. <br /> <p><br /> <p>2. Attach the small RCA cable into the sound card speaker output. <br /> <p><br /> <p>3. Connect the other end of the RCA small correction to the microphone port on your sound card. <br /> <p><br /> <p>4. Start the Sound Recorder program from the Start menu. Click the Record button. Tell your computer to the sound you want music or video progress bar to take to indicate when the movie is ready to play. Click the Record button, which will continue to record. <br /> <p><br /> <p>5. Click the File menu in the Sound Recorder program and select "Save As". Enter a filename and click Save. <br />
on Jun 22, 2011 | Computers & Internet
Model ELCHW402 40" LCD
The TV has two audio out options: a digital audio out (coaxial) and a 3.5 mm headphone jack. Both of these are just above the antenna in connector. The headphone jack is the top one.
For a sound system that uses RCA stereo plugs, get a 3.5 mm (M) to 2 red/white RCA F adapter at the headphone jack and use an RCA audio cable from the adapter to the sound system. Alternatively, you can use a 3.5 mm audio patch cable from the headphone jack and the 3.5 mm (F) to 2 RCA (M) adapter at the sound system. The TV speakers will probably be turned off automatically with this connection.
If your sound system has digital audio, get the digital audio cable. You will need to enter the menus to make this audio output active. See the Audio menu > SPDIF Type (PCM, Dolby or Auto).
I hope this helps.
Dec 24, 2010 | Element Televison & Video
Wiring diagram for a Samsung Jet S800 Video Out cable
to connect it to TVs, if you already have the cable let us say 3.5 mm jack to rca jacks, yellow is usually for videos, white and red are for sounds or output of sounds from your mobile to your tv. connect the cables to your tv and the phone will ask you automatically whether for headset or for video. select video, but first configure your settings for tv output under settings, phone settings, tv out.
to connect your phone to a home theater, with your cable, insert the 3.5 mm jack to your phone, connect the red and white to input speakers for your home theater.
if you are asking on how to conver 3.5mm to rca, you need an adapter most probably, there are lots of customized cables now in the market now adays, you need a 3.5mm jack to rca male connectors. or you may use a female 3.5mm jack to 3 rca cables.
if you are planning to do this on your own, check the links.
for s- video http://www.tkk.fi/Misc/Electronics/circuits/segawire.gif
for customized cables: http://www.hometech.com/hts_images/gc/gc-csm2r_1.jpg
planning to do it your own: http://www.connecthowto.com/wp-content/uploads/2009/03/stereo-adapter-1-4-to-rca.png
for connections, added info http://media.photobucket.com/image/schematic%20diagram%20for%203.5mm%20jack%20to%20rca/vkung/TU882Rconnection-1.jpg
Mar 20, 2010 | Samsung Jet S8000 Cell Phone
TASCAM US-122 OUTPUT, WHAT SPEAKERS TO USE?
You simply need a cable that converts this rca output to a Jack output.
Here's a link I think is right, though to make sure we would need more info about your model of soundcard:
http://www.kabeltje.com/audio-jack-tulp-c-54.html
I hope this helps,
Yannick
Feb 17, 2009 | Tascam US-122 Sound Card
How to connect Panasonic TV, DVD Recorder & Home Theater together
missing one connection connect stereo rca jacks behind tv labelled audio out then connect to any available input in home theater receiver i dont think you need the optic cable connected to anything
Jan 27, 2009 | Panasonic Home Theater System System
CONNECTING TAPE RECORDER
I assume you want to record from a tape recorder/player. If not, leave a message, but it will be a similar cable and connection.
If your tape recorder has a headphone jack, you can connect it to your sound card with a special cable. The headphone connectors are sometimes different sizes. It could be either a 1/8 inch, 2.5 mm or 3.5 mm plug. Your local electronics supply store (Radio Shack?) should have the cable you need. (I'd take your tape recorder with you, if possible.)
Jan 02, 2009 | Soltek SL-KT600-RL Motherboard
Bose 3-2-1 to a computer?
If I understand the question right are you trying to hear sound from your computer through your bose system? If you are then you need to hook a 1/8 mm headphone jack style cable on one end to the headphone jack on computer and on the other end of the cable you need a standard red and white rca type connection that hooks to back of bose system for sound. This cable is called a mini to rca stereo cable the pin connection for the computer has 2 little black bands around the plug there are 2 bands for 2 channel stereo sound.
Nov 27, 2008 | Bose 3·2·1 II System
Sound is not recorded
The problem would appear to be your audio settings.
You have the audio input set to Realtek HD Audio Input. That is the audio input on your soundcard, not the video capture card. You will need to change this so that you have the capture card selected. (I am not familiar with this exact model of card so I can't tell you exactly what it will be called.)
Alternatively, if you are trying to capture the audio via your soundcard (not recommended as it can cause sync problems) you will need to make sure that the 'line in' channel in enabled in the Windows mixer:
Start>Control Panel>Sounds & Audio Devices>Audio Tab>Click Volume in sound recording section>Tick Line In
Hope this helps,
Matt
Mar 06, 2008 | KWorld V-Stream Xpert VS-L883D...
RCA INPUT JACKS
did it work well before?is it new? try moving the rca's and se if you hear any thing?
Jun 30, 2007 | MA Audio HK802SX Car Audio Amplifier
Fujitsu Siemens AMILO Pro V2000 Notebook Logo
177 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
