Question about Dell E172FP 17" LCD Flat Panel Monitor
My dell E172FP monitor starts up but only stays on for a second or two. Tower works. Can this be fixed and approximately how much or should I buy a new monitor.
Double check your VGA cables, make sure they're in all the way/it's not a faulty cord. I made that mistake one time.
Posted on Dec 10, 2009
Testimonial: "Thanks so much. I just bought a new monitor and problem solved!"
Test pattern should be present without comp cables connected
Posted on Dec 17, 2009
My dell monitor usb ports don't work anyone how to fix it?
Please check if the monitor's usb port is connected to the tower, the monitor only acts like a USB hub / junction. If it is connected then disconnect it from the existing USB port and connect it to a different USB port. Please refer to the monitor manual link given below
http://support.dell.com/support/edocs/monitors/e172fp/QSE172FP.pdf
Thank you for contacting Fixya.
Jan 03, 2011 | Dell E172FP 17" LCD Flat Panel Monitor
My monitor is blank it just keeps saying self check its a dell flat screen
If it shows "Self test feature check" the cable (VGA / DVi ) is unlplugged on the computer/ tower. Check the cables it may be loose. If not, try replacing the VGA/DVi cables. The LCD is good since it was able to display the self test feature check.
Hope this helps.
Mar 24, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
My DELL monitor is not working I got a second
More likely to have problem in the inverter circuits, check for short between Emitter and Collector pin of the four transistors as shown in the pictures.
http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
Feb 24, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
At start up screen goes black and get message can
Native/max resolution for this Dell is 1280x1024, try this setting.
Feb 19, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
Monitors comes on for a few seconds then goes black. the only way is to turn it on and off but still only stays on for a couple for seconds
I think the power board might be going bad in there. Hook up a different good working monitor to the computer and see what happenss.
If the monitor still turns off after a few seconds then you know its the video card acting up. If the monitor stays on then you know its the original monitor that is bad for sure.
Jul 03, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Dell e172fp flat screen
check the power if 110 volt or 220 volt
Jun 05, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Blank Monitor on my DELL
Your display is having problems with the Inverter that generates high voltage to lit the lamp.
This issue is explained (including how to fix it) here:
http://josepino.com/?howto-repair-dell
Good luck
May 07, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
My E172fp has a blank screen...when i unplug and plug it back in,the "dell dimension" or whatever that logo is comes on for a second, then the screen goes blank and stays that way.another monitor works...
i have the same issue before with my DELL 2001FP, I replace the 3 capacitor on the board that look like defective because the top is look like swolen, it should be flat. I replace it with the same value and now the it works better.
i hope this might help .
Feb 25, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Dell E172FP shows image for one second
There is a loosing on the Display portion of its circuit, there could be a problem in the Power Supply too. Will need to get it fixed from some repair shop, or if you are ready to get the list of tools, then I can guide where exactly you should try to solder it, or check the desolded items by the DMM (Digital Multi Meter)
Jan 27, 2009 | Computers & Internet
Dell E172FP 17" LCD Flat Panel Monitor Logo
290 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
