Question about PNY Computers & Internet
How to install PNY OPTIMA 2GB DDR2 667 MHz memory card in lap top
How to install PNY OPTIMA 2GB DDR2 667 MHz PC2-5300 Notebook / Laptop SODIMM Memory Module MN2048SD2-667 by PN. I have 10'' HP laptop with 1 GB RAM
    Brigadier General:
  • 10,406 Answers
Turn the computer off.
Remove the battery.
Unplug the AC adapter.
Turn the computer bottom-up.
Look for a few screws that secure a small panel.
Unscrew those screws, and remove the panel.
If you've selected the right panel, you should see your current RAM.
On the LEFT and RIGHT edges, there are small "fingers" that are holding the RAM.
Gently pull those fingers away from the RAM, and it should pop-up slightly, and you should be able to remove the RAM.
Notice that the "notch" in the middle of the RAM is slightly off-centre.
Insert the new RAM into the socket, and gently press down, until those two fingers "click" to grab the new RAM.
Depending on your "old" RAM, you may have:
* one "occupied" RAM slot (1GB), and one "empty" RAM slot;
* two "occupied" RAM slots (512MB/stick).
So, you may have to remove one RAM stick, to expose an "empty" RAM-slot "hidden" under the RAM.
Or, the "empty" RAM-slot may be visible without removing the RAM.
Or, you may have to remove one of the 512MB RAM-sticks, in order to free-up a slot for the "new" RAM.
Replace the cover-panel, and screw it in.
Reconnect the battery.
Reconnect the power-supply.
Start the computer.
Click Start
Point at My Computer
Right-mouse click on My Computer
Choose Properties
It should display your CPU-speed and the "new" amount of installed RAM.
Posted on Dec 10, 2009
SOURCE:
How to delete photos from sd through desk top computer
You will need to connect your PNY Optima to your computer Click start click on my computer to open from there you should see your PNY Optima then right click to select open you should see
the data / photo's in there select what you want to delete right click select delete or you can right Click select format this will delete all data on hard disk Hope this helps.
Dec 08, 2012 | PNY Optima Pro 2GB Secure Digital Memory...
I have a x58c series alptop and was wondering if this memory is ok to add to my latop which has 1024 mb of memory. ...
Any notebook DDR2 ram will be fine. Your laptop has a max of 2gb per slot and a total of 2 slots. have a look here for more info :
http://www.crucial.com/store/listparts.aspx?model=X58C
//halfs
Sep 01, 2010 | ASUS Computers & Internet
I have Acer laptop Aspire 5570z module Zr1 with memory 1GB I want to increase memory 2GB or 3GB Is it possible or not What will be the expenditure?
Your laptop's RAM is upgradeable to up to 4 GB using two DDR2 533/667 MHz SODIMM modules.
So your upgrade options here are:
1. Buy a 1 GB DDR2 533/667 MHz SODIMM module & install it to get a total RAM of 2 GB (Price around US$ 25).
2. Buy a 2 GB DDR2 533/667 MHz SODIMM module & install it to get a total RAM of 3 GB (Price around US$ 45).
Aug 14, 2010 | Acer Aspire 5500 5570-2609 Laptop
I have a PNY optima sd 2gb memory card and it tells me on my samsung camera card error. What does this mean?
My Sanyo camera says my sd card it full when it absolutely is not. Ive even tried uploading pictures to my computer and it tells me there is an issue. It just suddenly did this one day and I think I've lost about 150 photos from Easter and other things that I can't get back and worse I can't take any pictures with my camera now.
Mar 09, 2010 | PNY Optima Pro 2GB Secure Digital Memory...
Want to know how to upgrade my lap top memory thank you
To upgrade you will need a SoDimm 2gb DDR II SDRAM, 667 MHz module, on the bottom of the notebook you will need to remove the panel usually secured by 4 screws to gain access to the memory slots, you probably have a 1 and 2 gb modules already so it'll mean removing the 1gb chip and discarding it as you only have 2 memory slots so you can fit the new 2gb module.
Jun 10, 2009 | Acer Aspire 7520-5185 Laptop
PNY Optima SD HC 8GB isnt working on laptop
Youll have to get updates for your laptop card reader or get a new one which may have to be installed. Another method you may want to try would be to put the card back into the device you used it in and then hook the device up to the computer, most likely through the USB slot....good luck
Jun 05, 2009 | PNY Optima Pro 2GB Secure Digital Memory...
Zlatko
Your laptop can have up to 1 GB of memory. You should have two slots and you can install 512 MB per slot. Your laptop is using 200 Pin DDR PC2100 266 MHz CL 2.5 SODIMM. You can also install PC3200, but your laptop will clock it down to 266 MHz.
Regards,
Feb 27, 2008 | ASUS A2H (A2HOB) Barebone
Computers & Internet Logo
508 people viewed this question
Top PNY Computers & Internet Experts
Thomas F. Schneider
pankaj rautela
pankaj rautela
Are you a PNY Computer and Internet Expert? Answer questions, earn points and help others
