Question about Whirlpool Calypso GVW9959K Top Load Washer
What is error code C1? Also what causes the
What is error code C1? Also what causes the washer to stop with 6 minutees left in the cycle?
  • 15,935 Answers
The C1 error is displayed when the motor tries to pull more than 26 amps to run.
This indicates a problem with the motor or motor controller.
Overloading or excessive suds can also cause this error.
If you like to make a few more checks then the image below contains the instructions for entering the diagnostic test mode.
Its a short cycle that runs all of the components so the operation of each can be checked.
I hope this helps but an intermittent C1 error can be hard to pin down.
http://media.fotki.com/1_p,wbrrkqqwkwbqsdgxgtqsskgwtqkq,vi/kdkftbfkwxkfsqdgqsg/1/1303472/5961857/image5668img-or.jpg
From the service manual....
"C1 = Average current limit Or Instantaneous current limit.
If a status signal comes back from the motor controller that a current
limit has been breached, the unit will return to standby mode and
display either CA for average current limit trip or Cl for
instantaneous current limit trip.
Average current trip occurs if there is a 2 second average of current
draw greater than 5.55 amps
at the motor windings.
Instantaneous current trip occurs if there is a spike of 26 amps
instantly at the motor windings.
This may signify problems with the drive motor, thermal protector, or
motor controller. Over-loading the unit may cause this problem."
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 23, 2010
Washer stops cycleing
First are you sure the error code is 'LE' and not 'tE' which looks very similar. The LE is usually the motor position sensor. Common on older washers. Easy fix. Under $20 part. The tE error is usually the thermistor. Inexpensive part about $6, but can be more complicated to get to. Ad a comment to your question and my answer with error code and I'll reply with more info if needed.
Jun 24, 2017 | LG WT4870CW 4.5 Cu. Ft. Top Load White...
Calypso GVW9959K Top Load Washer: when washing a C1 code appears...
May 18, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
What is causing the drain pump to continue running
C1 - Partially Blocked Drain - This error will occur when dishwasher was unable to pump out water in less than 95 seconds. Check drain line for debris and blockage. If clear, check for a restricted drain valve in the pump. Check the pressure sensor for correct operation as it sounds like it may be defective and thinks that the machine is still full of water after it has emptied.
Oct 30, 2009 | Dishwashers
Error code c1 of ca
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%
Jun 03, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
C1 code what does it mean on a clypso washer
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#$^^
Mar 31, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
I keep getting a C1 error code. What does it mean?
"C1 = Average current limit Or Instantaneous current limit."
draw greater than 5.55 amps at the motor windings.
Thank you for contacting us.Please do keep posting and do rate fixya if we could help you out with your problem.
Dec 10, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Getting error code c1
Hi
Error code C1 indicates problem with drive motor-thermal protector-or motor controller
Overloading may also cause the problem.
Press( stop/cancel) to clear the display.
Hope this helps
Nov 24, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Washing Machine shows error code C1
Nov 22, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
C1 code
Jun 23, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
F01 Error code
most likely suspect main control bd
Apr 11, 2008 | Kenmore 46462 Front Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
394 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
