Question about OKI C9300 Led Printer
The printer will not print black, the copies are very "fuzzy" and appears to have a white out line going vertically down the left side of page. End user says that she had paper jams but that has stopped.
  • 3,741 Answers
you will have to clean the drum properly to fix this fuzzy printing problem.use the dry side of the cotton ball to wipe the drum clean. as you said-- If you get some streaks on prints, then wipe the "lenses" in the machine cover. its a very common problem with this type of printer.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Posted on Dec 10, 2009
Line down the left side of the photocopies
If this only occurs with copies (not with printed jobs), then your problem is most likely dust/dirt on the scanner (not necessarily the glass), or on the optics that feed the image to the scanner. If it's on print jobs also, it could be a simple image drum problem (they wear out over time, and frequently manifest their impending failure with vertical lines appearing down printed/copied pages.
Aug 13, 2009 | Brother MFC-7440N Laser Printer
Black vertical line (1 inch wide) appears while scanning/copying
For this kind of problem you need to call the tech support because the printer is already messed up and it is in need of replacement
Hope this help
Byron
Jun 15, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
HP Laserjet 3330 printed dark page especially around the middle
Does this happen both when copying and printing?
For printing solution, try another toner cartridge.
If lines continue to appear when copying (primarily through the automatic feeder) then lift the auto feeder, and clean the glass -mainly the narrow piece on the left side.
please rate solution :)
Apr 07, 2009 | HP LaserJet 3330 All-In-One Printer
A series (10) vertical lines on print outs
See Charge roller my be dirty or Catriges PCU Units
Jan 22, 2009 | Ricoh CL3000E Laser Printer
Black vertical lines on printed pages
check the "photoconductor unit" (pg 37 in the Maintance manual)
ours was doing it with the magenta and saw a faint 'scratch' on the roller. will attempt to replace and report back if this fixes it.
Apr 09, 2008 | Ricoh CL4000DN Laser Printer
HP 3050 Black Line
I was getting a verticle black line and I had to clean the glass, the long white bar above the glass, and the white and black rollers before my problem was solved.
Mar 12, 2008 | HP LaserJet 3050 All-In-One Printer
White line appearing vertically down the left side of the page
I had a line for months! Then I got a line going down the middle of the page. So cleaned and poked around inside put back together and another line! 3 vertical lines! Came on here and went back with a hairdryer on cold setting blowing around the inside of the printer and now its perfect!
Cheers all!
Jan 23, 2008 | Epson Aculaser C1100 Printer
Print Problem - vertical lines
If the problem only occurs when using the document feeder, the problem is not usually caused by the drum. When using the document feeder, try to notice where the scanner (the light assembly under your scan glass)stops just before the paper is being fed. Some multifunction machines have a small piece of glass that is separate from the large scan glass and the scanner assembly stays parked underneith it as the original is being fed over it. Most likely there is something on the glass where the scanner parks as originals are being fed thru the feeder. When putting your original on the large scan glass to copy, the mark on the glass will only show as a spot, but will show as a vertical line thru the whole copy when using the feeder.
Feb 23, 2007 | Brother MFC-7820N Laser Printer
OKI C9300 Led Printer Logo
37 people viewed this question
Top OKI Office Equipment & Supplies Experts
Steve Allison
Steve Allison
mukhtar21 shaikh
mukhtar21 shaikh
Timothy Van Der...
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
