Question about LG Shine CU720 Cellular Phone
Everytime i go to put a song as my ringtone it says file too large,what can i do?
I have a samsung impression and i have a memory card and everything with my phone i love the phone but i hate that i cant put a song i like as my call ringtone. its not even highlighted on the set as...
Try this my friend go to the user profiles of your phone it is located in the settings menu if not included in the actual phone menu then on the user profile you are using press options then press edit profile..then in the user profile just edit what message tone do you want if you ask an option between use my effect tone and use my alert tone chose my alert tone so you can chose from the songs in the file that you have to make it your ringtone..Hope it will help you
Jul 14, 2011 | Samsung SGH-A877 Impression Cell Phone
How do I put my own ringtone on my galaxyI9000?
Hello,please do you mean putting your own kind of songs.you can collect songs via computers or through bluetooth transfer.if the songs are being transfered you can then follow the steps below to select your own ringtone.
1.visit the files or media section of your phone,you then scroll to the particular song you want to use as your ringtone then you click on option and click on set as ringtone and that will make your phone the way you want.
Good luck,
Take care.
May 21, 2011 | Samsung Galaxy S GTI9000 Smartphone
Cant assign ringtone on rumor touch
Well, after you decide to make a song a ringtone, simply press set as and you'll see options such as ringtone,individual ringtone..etc.If you don't see the set as button, try press options,set as..etc.
I hope this helps your problem!
May 31, 2010 | LG Cell Phones
I'm trying to place songs as ringtones.My phone is saying file is to large
Ringtones are very small files - designed specifically for the function of being a ring tone. Anything else will be too big.
Dec 21, 2009 | Samsung SGH-A877 Impression Cell Phone
How to put songs as ringtones on a samsung gravity
Hi friend,
Don't worry.
Could you tell me if there are any songs in your cell phone.If there are songs in it,you can set it.Find the songs you want to set as ringtones,then choose the option"transmit",and find the option"To the user profile".Just doing these,the setting is finished.
But if there aren't any songs in your cell phone,you may need download some.Then you can set it as the above.
And if you don't like the songs you have put them as ringtones,you can ...to get more information,you may visit our website:www.1010store.com
Sep 07, 2009 | Samsung Gravity SGH-T459 Cell Phone
How do i put ringtones on my lg shine?
Requirements:
  • Latest BitPim software from www.bitpim.org (tested with 1.0.2)
  • USB cable
  • Ringtone/Song (No larger than 300kg)
Instructions:
  1. Install software listed above
  2. Hook up phone (Make sure phone connection is on Data Service, not Mass Storage)
  3. Launch BitPim
  4. BitPim should show "Other CDMA phone on COMx" (where x is the COM port being used [if it doesn't try a different port, and click "Find Phone"])
  5. Choose Edit, Settings
  6. Change Phone Type to "LG-VX8700" (this is the CDMA version Shine)
  7. Click OK to close
  8. Choose View, View Filesystem
  9. Click the Filesystem icon
  10. Click the expand button beside "/"
  11. It will say "Retrieving" for a minute or two
  12. Expand to the following directory: /LGAPP/Media/Midis/RingTone
  13. Add whatever MP3 ringtones you want by right-clicking on RingTone folder and selecting "New File ..."
Nov 21, 2008 | LG Shine CU720 Cellular Phone
Memory crd
ring settings select memory card data an select the song
dont forget to rate me
Aug 16, 2008 | Palm Treo 650 Handheld
O2 XDA11 wont let me put songs on it or new ringtones
copy wav sound to storage..
then
1. start>settings>system>add a ringtone>check mark your file>ok
2. start >settings>personal>sounds$notific>notificationsevent : phone- incoming call>choose your file>ok
hope it helps
Jan 17, 2008 | O2 Xda II Smartphone
How do you save music received via messaging to a ringtone?
well fiiiiirst you go to your inbox and pull up the message with the song in it. and then save it in your audio. and nowww you go to menu>settings>profiles>options>edit>down>options>change>find that dern ringtone :)
Jan 16, 2008 | Samsung SYNC SGH-A707 Cellular Phone
SOLUTION!!! (for those with a memory card but no usb cable!)
I’ve been having the same problem in trying to find a way to set my music as ringtones. Here’s what you can do:
-Make sure the file is appropriate.. 30 seconds or less, mp3 format
-When you add your music to the memory card, it shows up as a song but not as a ringtone right?
The solution is to create a different folder rather than using the “Music” folder the phone automatically creates for you. Transfer your music to this new folder you’ve created. The ringtones should show up as long as it fits the requirements! :] Hope this helps!
Dec 07, 2007 | LG Shine KE970 Cellular Phone
LG Shine CU720 Cellular Phone Logo
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
