Question about Refrigerators
My refrigerator & freezer no longer cooling
My refrigerator & freezer temps are set to 5, but both suddenly stopped cooling yesterday. All the ice in the freezer melted and the food defrosted. The refrigerator temp changed overnight and now neither have any cold air. Sounds like a motor is running, but the sound stops whenever either door is opened.
  • 1 more comment
  • celeste_nels Dec 10, 2009
    GE Model# GSS25RGMB BB
  • celeste_nels Dec 14, 2009
    Thank you for the information. The control board was the culprit and thankfully it's all fixed. The part didn't cost quite so much, but it was definitely less than a new refrigerator.
  • magillago174 May 11, 2010
    the noise you hear sounds like a fan moter can verify with door open by locating light switch and pressing light will shut off and fan will start but it sounds like compresser is not running several items can cause this bad temp control bad defrost timer and bad compresser any one of these will cause no cooling refrigerator side temp control can turn up and down listen for click can also be checked with tester defrost control can be manually turned to verify if it has stopped in defrost mode will take some diagnostic ability to find out the exact problem not sure age of refrigerater normal lfe expectancy is 10 to 15 years with minor repairs hope this helps good luck ron
  • Refrigerators Master
  • 4,655 Answers
I will need to help you first by telling you I can help. But is it possible that you could find a model number and brand name.I see everything is going to be lost so if you want me to help you repair let me know soon, I will show you the places to look for these numbers in one moment. Sea Breeze
Posted on Dec 10, 2009
  • 1 more comment
  • John Tripp
    John Tripp Dec 10, 2009
    Here are the places to search for the model numbers below. You can reach me here or=> HERE or visit one of my websites=> Sea Breeze Appliance Parts and Technical Services if a Sears model the numbers will look like this for example 231.65489
    Thanks Sea Breeze
  • John Tripp
    John Tripp Dec 12, 2009
    Thank you for the model number that tells everything we needed to know. aasc is also correct and the board may have been compromised. These models are very sensitive to surge, fan failure or simple board failure. Other that that they are a good refrigerators. Would you like the service manual and assistance? Let us know, be happy to assist you. Sea Breeze
  • John Tripp
    Here is your service manual=> PROFILE ARTICA SERVICE MANUAL CLICK HERE
  • 1,606 Answers
The main control board , located behind the refrig , behind an 8 " X 10 " panel , is bad . The part number for the board is WR55X10942 . It runs about $ 150.00 .
First , remove the board , and look on the soldered side , behind the little black boxes . Look for a " bullseye " , where the solder has melted away , from the center pin , and use a soldering iron , to resolder the connection . If you do not see the " bullseye " , then replace the control board , as this would indicate , the module for the compressor , is shorted internally .
Posted on Dec 11, 2009
Fridge section not cooling enough but freezer OK
Is the fan blowing in the freezer section? Also, check to see if you have airflow thru the damper (vent) in the frig section.
Mar 31, 2012 | GE GSL25JFPBS Side by Side Refrigerator
Maytag refrigerator mtb2154drq suddenly the refrig stopped cooling but freezer still working. Even with high setting of 9, temp doesn't go below 60degF, while freezer ar 4-5setting is at 25degF. Up until...
The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. If you would like to be a part of the petition for a recall on this appliance contact me at jboooor@hotmail.com
Jun 10, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
Fridge is no longer cooling. ER where the
Sounds like the FF(Freezer Fan) is wearing out or is worn out. This assembly supplies the circulation for the freezer as well as the refrigerator. When is slows down or stops the circulation of cold air to the refrigerator is the first thing that is effected. The minimum cost to replace this assembly is around $300.00
Jul 10, 2009 | LG LRBC22544 Bottom Freezer Refrigerator
Freezer is not cooling
you may have defrost problem chech and see if you have ice build up back wall of freezer
Apr 06, 2009 | GE Profile PFS22SBSS Bottom Freezer French...
Frige and freezer are not cooling!!! Help
chances are the fan motor has quit have a tech replace it if this is not the problem it could be a sealed system issue or a defrost problem
Dec 14, 2008 | Maytag MFD2560HES Bottom Freezer French...
Error Code ER FF
FF is your freezer fan. You may need to defrost the unit.
Feb 28, 2017 | LG French Door Cabinet Depth Refrigerator...
Fridge stopped working suddenly
Sounds like the relay (start device) on the compressor has failed.  This is a very common problem especially for models that are 3-5 yrs old.  I would replace that first.
Oct 22, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
146 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
