Question about Delta Saws
I need to get a replacement saw blade guard for an old Rockwell Delta Radial arm saw. 12'' Blade Serial # MX3 2843 I don't know what model number this saw is to get the right part.
  • 2,176 Answers
You can try going to Dewaltservicenet.com and locating it that way but with only the serial number it would be impossible. Is there any numbers on it to indicate the model or partial model and you can pull up breakdowns that way.
Posted on Dec 13, 2009
I need a rockwell 10" radial arm saw manual model # 33-216
http://vintagemachinery.org/pubs/1141/2347.pdf
Feb 09, 2012 | Delta Machinery Saws
Delta 33-890 making loud harmonic squeal
talked to Delta tech and he said that it is a common sound that is particular to this tool. Using a blade with more teeth (80 and up) splits the air better. anti vibration cuts laser ut into the blade also a must. i also changed to a lighter blade. i found that the heavier one wants to hold on to the sound better.......if that makes sense..
Jan 16, 2012 | Delta 33 891 12" Radial Arm Saw
Can't see how to remove blade guard on older craftsman 10" radial arm saw to change blades also right or left thread??
The saw I own has a thumbscrew-like shaft protruding from the area where the blade guard rests over arbor of the saw, and you simply turn that thumbscrew to loosen the clamp that holds guard on the end of the motor housing, then lift the guard up and over the blade. (After unplugging, of course.)
I don't remember which way it's threaded, but it should be pretty apparant after you take the guard off, as you can see the threads sticking out about 3/4" beyond the lock nut. This allows for the use of dado sets, etc. on the radial arm saw.
By the way, you might be able to find a manual for your saw, if you can find the model number stamped on the plate, by looking at this site.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 02, 2011 | Craftsman Saws
Looking for owners manuals for 2 saws
Your Delta radial arm saw (RS830) manual is here. Exploded diagram for parts, etc is here.
I'm not sure on the Rockwell, but here's a link to a manual for a Rockwell-Delta 10" Tilting Arbor Unisaw, circa 1969 which seems about right for a 34-466.
If that's not quite right, there a couple other manuals for old Rockwell saws here.
If this answer helped, please vote. Thanks!
May 19, 2010 | Delta Saws
Where can I find a blade cover for a Rockwell Radial Arm Saw that is over 20 years old.Serial # 85Fo8158 I cannot find a model # but there is a parts# 438-02-314-0911 and there is a Cat. # 33-890
Any porter cable dealer/ repair shop. Will be able to tell you if its still available or obsolete by the cat# 33-890. This is the catalog # they did not use a model # per say.
Dec 22, 2009 | Saws
Wood like to clean & update my rockwell model 14 band saw need a download of this saw
try there web sight, if I'm not mistaken, Delta bought out rockwell and they should be able to help. I had an old rockwell table saw and the man shaft that the blade attached to was missing.I contacted delta with the model number of the saw and they faxed me a blue print of the shaft and we machined a new one and the saw still works great.
Jan 18, 2009 | Delta 28-060 14'' Band Saw Blade 93-1/2''...
Saws Logo
182 people viewed this question
Top Delta Saws Experts
Jim London
Jim London
Craig Butler
Craig Butler
Are you a Delta Saw Expert? Answer questions, earn points and help others
