When power applied tv just pulses as if trying to switch on but not completing its power on
  • Andy Wrigley Jan 22, 2008
    Its a Vision Plus / Nikkia (10.4inch from Maplins) DVB/ATV/VGA etc ... Model No.JV-TV104A several of the boards inside have 104---- as a reference.
    I have now progressed to a white screen no sound or menu etc just bright white screen, no standby light during its "off" setting either.
  • Andy Wrigley Jan 23, 2008
    Thanks.... I'll do that hopefully later today.
  • 8,617 Answers
What make and model set do you have?
Posted on Jan 20, 2008
  • Sonny Berry
    Sonny Berry Jan 22, 2008
    let me see what info I can pullup on this sets chassis. I will et back to you as soon as I get some info on it. Probaly a hour or so.
  • Sonny Berry
    I am sorry. I cannot find any information on your TV whatsoever, other than its a digital TV. It sounds like a video transistor or a solder joint. Look inside and try to find some numbers stamped on a 4 or 6 legged IC mounted to a heat sink and I will cross reference them to see which ones are video ICs. thats about the only option left due to not having any service info for that model hope this helps.
My old tv has its own power switch on the set can I buy a new set with this type of function?
all tv's have their own power switch, but most are electronic in that it relies on a pulse from that switch to the microprocessor to turn set on or off.
Sep 08, 2014 | Televison & Video
Power up problems
It sounds like the power is pulsing - that would explain your speakers. Speakers wouldn't make that sound if they were getting power at a steady rate. Look for a bad capacitor. It's possible you have one or more capacitors that have gone bad. They charge to a certain point, then somehow complete a circut momentarily and discharge, giving a pulsing flow of electricity. You can look for visible signs (leaking capacitors, or capacitors that are leaning over), or you can just start testing them with a voltmeter. If you find a bad one, you'll have to get a replacement and solder it in place.
Aug 06, 2007 | LG RZ-20LA70 20 in. LCD Television
LG 17LX1R flashing red LED - TV won't power up
Try changing the input device to something you are sure, works such as a DVD player.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Aug 02, 2012 | LG 17LX1R 17 in. HD-Ready LCD Television
The panic alarm sounds
it sounds like one of your door switches is setting off the alarm. Or you hood or trunk switches.
Anti-Theft -Perimeter The perimeter anti-theft system consists of the following:
  • door lock cylinder disarm switches
  • liftgate lock cylinder disarm switch
  • generic electronic module (GEM)
  • door open warning lamp switch
  • pulse stretcher module (wagon only, is located between the rear license plate housing and bracket)
  • keyless entry remote transmitter
  • hood switch/bracket assembly
Principles of Operation
Perimeter Anti-theft
The perimeter anti-theft feature provides an audible and visual alarm when unauthorized access to the vehicle is detected. When an intrusion is detected by any door or liftgate ajar switches, or the hood and trunk tamper switches it sends a ground signal to the GEM. When the GEM receives a signal indicating intrusion into the vehicle, the GEM supplies a ground signal to the horn control relay and the park lamps relay. The relay closes, supplying the power which activates the horn and the park lamps. The pulse stretcher module applies to wagons only. Due to the distance between the liftgate disarm switch and the GEM, the disarm switch signal is not present long enough for the GEM to recognize. The pulse stretcher module receives pulse input when switch is turned to unlock. The pulse stretcher module holds the pulse active for about 60ms so the GEM can recognize the signal and disarm the system. The perimeter anti-theft feature does not arm until 20 seconds elapses after locking the vehicle. The perimeter anti-theft device will disarm only when
  • unlock is pressed on the keyless entry remote transmitter.
  • keyless entry keypad code is entered.
  • door, luggage compartment lid or liftgate lock cylinder is turned to unlock.
  • ignition switch position changes to run or start.
Inspection and Verification
  1. Verify the customer concern by operating the system.
  1. Visually inspect for obvious signs of mechanical and electrical damage.
Visual Inspection Chart Mechanical Electrical
  • Lock cylinder disarm switches
  • Hood switch
  • Luggage compartment lid switch
  • Loose or corroded connections
  • Generic electronic module (GEM)
  • Circuitry
Door Disarm Switch Removal and Installation
  1. Disconnect the battery ground cable. Refer to Section 414-01 .
  1. Remove the door trim panel. For additional information, refer to Section 501-05 .
  1. Remove the watershield.
  1. Disconnect the latch lever from the door lock cylinder.
    1. Remove the E-clip.
    1. Disconnect the latch lever.
  1. NOTE: The door disarm switch can be installed in more than one position. Before removing the switch from the cylinder it may be necessary to mark the position of the switch in relation to the lock cylinder.
    Remove the door disarm switch.
    • Disconnect disarm switch electrical connector.
  1. NOTE: The door disarm switch can be installed in more than one position. Use the reference marks applied in the removal procedure to index the new door disarm switch to the lock cylinder.
Jan 24, 2011 | 2005 Mercury Sable
Picture pulsing, tv turns off and on
Sounds like a power supply problem, If you are competent with electronics, you may find some blown capacitors or resistors on the power supply board. Equally you can probably buy a new power supply board.
WARNING: the power supply board contains lethal voltages even when switched off and unplugged. If you are unsure what you are doing take it to a repair shop.
Apr 05, 2010 | Philips Televison & Video
No power to fuel pump no hum when key on and inj not pulsing
Fuel Pump Relay Circuit...
There is an Oil pressure switch in this circuit that disallows the relay to complete the power supply to the fuel pump. It is for safety purposes , it senses engine oil pressure upon cranking of the engine and then completes the ground circuit to close the relay sending voltage to the fuel pump at start up, and also functions as an engine kill if you loose oil pressure opening the ground circuit which in turn opens the contacts in the relay shutting off the power to the fuel pump.... Invest in a vehicle specific repair manual with wire diagrams... hope this helps..
Aug 16, 2009 | 1989 Chevrolet Suburban
RCA P52937SG
Time to replace.
Mar 10, 2017 | Televison & Video
drive the car apply slowly the emergency brake you gonna brake with the rear only if you fell the pulse its our rear drum that warp be carefull when applying the emergency try to hold the release handle at the same time if no pulse change our front rotor there nothing else that can pulse when you brake hope it help fixya our post thanks pierre
Jul 13, 2008 | 2000 Buick LeSabre
On/Off switch
change power on-off switch. first try to apply contact cleaner from nearest(radio shack).if it is solved it is fine -if not you must change power switch.
Feb 04, 2008 | Akai CF2791 27" TV
VTech 5.8 mhz won't work
I found a solution that fixed this problem (at least for me). On the vtech site they said to unplug the base unit for at least 5 minutes. Previously, I had only unplugged the base unit for a few seconds. This time, I left it unplugged for about 10 minutes or so and when I plugged it back in, everything was working fine. Apparently there is some sort of capacitor that must discharge long enough to completely remove power from the circuitry.
Good luck and I hope this works for you!
Jan 18, 2008 | Vtech 9009111 Cordless Phone
Televison & Video Logo
98 people viewed this question
Top Televison & Video Experts
