I am wanting to reconnect my san disk card reader to my dell desk top computer. I forgot where to plug it in, and don't see any slots on the back of my computer . the product I am trying to connect is a San Disk 12-in-1 SDDR-89 card reader.
  • 557 Answers
Any USB port will do.
Posted on Dec 13, 2009
SOURCE:
16 gig san disk is in slot on my samsung desk top how do Iget it to work?
start>{msconfig}> tools tab> computer management [launch] >storage> disk management
Jul 04, 2014 | Audio Players & Recorders
I can't get my desk top to connect to internet it tells me my ip address is not right but my lap top goes through my desk top and i don't have any problems getting on line.
your dell needs a network adapter card or wireless card installed is that the case(look in b ack)
if no wireless, then it needs an ethernet cable plugged into modem/router from cin bell and then in back of dell
please advise your network configuration
May 28, 2012 | Dell Dimension E310 PC Desktop
GT-S3670 trying to download photos onto my computer using san disk
Hello there,
If the scan disk already have the photo on it, then it is easy to download pictures from it to your computer, all you need to do so is a scan disk trans flash adapter also known as the memory card reader. You will insert your memory card into the scan disk if it is the small memory card. then you connect the scan disk into the computer through the SD slot on the computer and then the computer will read its drivers and then you can open file to view folders on the memory card. from there you will be able to transfer your pictures to the computer.
If your computer does not have the SD slot, then you can use the USB type of memory card reader to carry out the operation.
Thank you for using fixya.
Caseytech
Jun 27, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
My San Disk micro SDHC Memory Cards 8GB wont format and when put in a device it heats up. What is wrong with it?
technically, some card readers dont have any regulators to minimize the voltage to read a microSD.. some direct card reader can destroy/ damage your memory card.. try to use an all-in-one card reader, or a microSD adaptor then put it in your card reader slot..
Card reader slot in laptops made for memory cards only.. =))
Feb 15, 2011 | SanDisk 8GB microSDHC Memory Card with...
How do ~I download photos that are on my lap top to a blank Sans Disk memory card?
put the card in a card reader plug the card reader into the usb port of the laptop, then drag and drop or copy/ paste the files to the laptop hard drive
Dec 29, 2010 | Dell Inspiron 6000 Notebook
Where can you use a sd card on a dell inspiron 530
The 530 doesn't have a built in port for the card but you could find one at www.surpluscomputers.com that will read multiple types of cards. Have you tried plugging a USB cable from the camera to the computer and downloaded the info that way?
Dec 05, 2010 | Dell Inspiron 530 Desktop Computer
How do I load pictures from San Disk SD Card onto
do you have a card reader on your laptop? if so slide it in, wait for windows to recognize, then veiw all files, after that highlight and copy to wherever you want them to be stored
Jul 03, 2010 | HP VM114UA notebook
My card reader on my computer has stopped working!? ok i took my computer in to my computer teacher to get it fixed, well she put in a second hard drive in and said it should fine. well it does but...
Ah, My Bad, big_dude2010, perfectly understandable about the budget thing. The world is in an economic crisis right now.
As for reattaching the Card Reader cable, can't help you.
OH, I'm just PLAYIN'!
Before we go ANY further:
1) Computer off, and unplugged from power.
Unplug the power cable FROM the surge protector, and NOT plugged into the surge protector, and take it out of the back of the Power Supply.
With the power cable plugged into the surge protector, and unplugging it out of the Power Supply, you could create a voltage spike.
Result can burn out the Power Supply, and may go on to burn out the Processor, Motherboard, Ram Memory, and a graphics card. (IF used)
Many have stated, that they do this all the time. Eventually, they come back to state they fried out their power supply, and/or motherboard, and so on.
2) Computer unplugged from power, computer case open, TOUCH the metal frame of the computer case to relieve your body of Static electricity.
Static can fry out, (Short Circuit), the delicate hardware components inside your computer.
(For this reason also work on a table. If you have a carpet floor, refrain from swinging your feet back, and forth.
If you get up, walk away, then return, TOUCH the metal frame again)
If you already know the above, please disregard.
The Card Reader cable has a white sheath, and is approximately as thick as a No.2 pencil.
It should have 8 wires in it.
Orange, Yellow, Blue, Brown, Red, White, Green, and Black.
It will have a white rectangular connector on one end, that has 10 socket holes. 2 rows of 5 holes.
Only 8 socket holes are used.
The other end of the cable should have a Black connector. It also has 10 socket holes. 2 rows of 5 holes. This connector plugs into the circuit board of the Card Reader.
The White connector end plugs into the motherboard. It plugs into the Front USB 1 header on the motherboard.
(Connector on a motherboard is referred to as a Header)
Orienting the motherboard, so we are both looking at it in the same direction.
Processor to the top. Ram Memory slots to the right.
There are 3 white PCI slots down towards the bottom.
The white PCI slot that is closest to the edge of the motherboard, is PCI3. (PCI 3)
Down below the PCI 3 slot is a blue header. NOT the one you want.
That's for the audio ports in the front of the computer. (Front Panel)
To the right of the blue header, is a white header. This is the one you want. Front USB1. (The Front USB1 header, is below the Right/Bottom corner of the PCI 3 slot)
Note that there are 5 pins going along the top of the Front USB 1 header, and 4 pins going along the bottom.
The missing pin, or blank spot, helps you to orient the white connector of the card reader cable.
The card reader cable's white connector also has a missing socket hole, or blank spot.
There is No slot on the header for the motherboard, and No locating lug on the Card Reader cable's, white connector.
Line the card reader cable connector's blank spot, up with the blank spot on the Front USB1 header.
This is HP Support, and the Motherboard Specifications page, for the Compaq Presario SR1303WM Desktop PC,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00069442&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=447312
Scroll down the page about halfway, and you'll see an illustration of your motherboard.
(To enlarge it for better viewing, you can right-click right on it, then in the drop down menu, left-click on - Save As
Put this in your My Pictures folder.
Then go to My Pictures, and double-click on the illustration of the motherboard.
Now go below in the window, and click on the + sign to Zoom In.
Use the bottom, and side bar, to move it around to the view you want)
Below the illustration is an actual photograph of the motherboard, with no hardware components installed.
The Black connector that goes to the circuit board of the Card Reader, plugs in like this.
There are four wires across the top. There are five wires across the bottom.
Looking INSIDE your computer, TOWARDS the Card Reader circuit board, the four wires go on top, when plugged in. (Not shouting)
Again, looking at the back of the Card Reader, the color code of the wires on the top, going from Left to Right, are:
Thin Black wire, Green, White, and Red.
Wires going along the bottom, starting from Left going Right,
Thick Black wire, Brown, Blue, Yellow, and Orange
Feb 05, 2010 | HP Compaq Presario SR1303wm PC Desktop
I have a canon 2.1 Mega pixeks but they didn't give the software of the machine .i don,t know how to use it to put the photos into my comper,can you help me?
Hi, first you will need a card reader. Depending on the camera you can get a 12 in 1 card reader by San Disk for about $30. It is very fast and reliable. It uses a USB connection that you just plug into your computer, then take the memory card from your camera and insert it into the proper location on the card reader. A window will pop up asking you what you want to do, just follow the directions.
Jul 13, 2009 | Sanyo Vpc-s1070w Digital Camera
Reg mmc card reading
Normally you'd just be able to open My Computer, and plug the card in to the built in slot, and it would pop up as the next available drive letter. If the internal slot is missing or inoperative, you could buy a cheap MMC to USB adapter, plug the card into the adapter, and the adapter into a USB slot.
Mar 04, 2008 | Toshiba Satellite M35X-S311 Notebook
Computers & Internet Logo
Alun Cox
k24674
