Question about Sony VAIO Digital Studio PCV-RX560 PC Desktop
320 GB drive for PCXV RX560
I upgraded the bios for PCVRX560 but still cannot see the capacity of a 320 WD drive. It only shows 80 GB and will not boot. Any ideas?
I cloned the 80 GB with GHOST, which boots but has problems and needs to be replaced.
It does not appear that 80 is the limit of this machine. I am perplexed. I have done this many times before with many different systems
    Sniper:
  • 65 Answers
I've personally ran into this once before with a gateway system and a WD drive. Have you tried another high capacity drive from a different manufacturer? Sometimes there are simply compatibility issues with some drives and boards. Also (even though i'm certain this isn't the case) sometimes when you do a direct clone you clone over information that is located on a bad sector from the original drive. you may want to consider running a hdd regeneration tool before doing a clone. This software can be found on Hiren's boot cd which is a free resource that i use daily. Not related to this particular issue i'm fairly certain but a good tip for the future.
hope this helps.
Posted on Dec 10, 2009
Acer Aspire 5002WLMi Laptop won't recognize full 320 Gigabytes of new PATA hard drive. It's always been running a 80 Gigabyte 4200 RPM but that drive is old...a 2005 HD. New WD320 only reads 137...
The BIOS in the ACER determines the maximum size of the hard drive it can support.
Check the laptop's specification to see the max size you can install in this model laptop.
It appears that the max size your laptop can support is 140 Gb (unformatted). 137Gb formatted.
I suggest you install a hard drive up to 140 Gb capacity in your laptop and place the 320 Gb hard drive in an USB hard drive adapter case and when you attach this hard drive to the USB port in your ACER laptop then you will be able to get the full 320 Gb capacity after you delete the partition and create a 320 Gb partition and format the hard drive.
Nov 02, 2011 | Acer Aspire 5002WLMi Notebook
Hi there , i have an acer travelmate 6592 laptop , the original 80 gig hard drive crashed , and i dont have the recovery disc , the hidden partition wont re install either , i have bought a new 320 gig...
You cannot get the full 320Gb capacity because the BIOS can only support a maximum of 127Gb.
You only hope is a BIOS firmware upgrade that can support 320Gb. Check out the Acer WEB site to see if a BIOS upgrade will solve your problem.
OTHERWISE
Install a 127Gb hard drive in your Acer and put the 320Gb hard drive in an USB hard drive adapter case and use it as an external USB hard drive because it is not affected by the BIOS limitation.
Jun 13, 2011 | Computers & Internet
INSTALL DISK 320 GB IN THE DELL BIOS does not show ISPIRON 6400
The biggest drive that was offered with that was a 120gb. So you should be ok as far as the 320 size. I did a 80 to a 320 and it worked. There shouldn;t be any jumpers to set on the drive. So I would check the power connector if it is seperate. You should hear or feel the drive spin up even if it isn't detected. The next thing is to check the bios and see if it is detected. That might be all it takes is to open the bios and force it to detect the drive instead of auto.
You may need to do a bios update.
Aug 13, 2010 | Dell Inspiron 6400 Notebook
IS IT POSSIBLE TO INCREASE MEMEORY? BOTH RAM AND
Yes, it's possible to increase both RAM & HARD DRIVE Capacity.Your Pc comes with RAM: 512 MB in size and Storage (hard drive)Capacity: 80 GB.
You can put One more 512 MB of RAM or you can replacethe ealier RAm with 1GB RAM or Put two 1 GB RAM Instead.
For Hard Drive,use your 80 GB Hard drive as external storage device, and Put a 320 Gb new Hard drive.
Dec 26, 2009 | HP Pavilion dv1000 Notebook
Can you let me know what is the maximum installable HDD capacity 0f Lenovo laptop 3000 C100.Can i upgrade present capcity of 40GB to 320GB ?
If you have windows xp with service pack 3, there is no limit. There is no limit if you run Vistaor Windows 7. If you don't have service pack 3, you are limited to 137 gb.
Dec 20, 2009 | Lenovo 3000 C100 Notebook
Upgrading My hp530 laptop
It is working.
Tested first with one new module with 2GB RAM, then with 2 modules, 2GB (new) + 1GB (original). Post and Windows are showing 3GB.
The HP 530 notebook is working OK.
Sep 12, 2009 | HP Compaq 6720s Notebook
WD 320 GB shows only 300 GB of usable space
There is no additional 20gb. This is because the manufacturer (WD and the others) express drive size in the decimal (base 10) system. Windows formats the drive in hexadecimal (base 16), which is really ramped up from binary (base 2), which is what computers actually use.
So, 320gb decimal actually equals 300gb, as far as the computer is concerned.
Cheers
Nick
Dec 20, 2008 | Western Digital (WD3200JS) 320 GB Hard...
How much big HDD can i connect to my ASUS-CUBX-L motherboard?
The size of the drive that will be detected can vary on a number of things: bios version, and OS.
They will both "physically" work, but the full capacity may not be "seen".
The 160 should work fine, but the 320 may only "show" as a 250 or 300.
My best advice is to flash the bios to the latest, and start with the 160. Install your OS, and connect the 320 as a slave after the OS install, and check its properties.
Jan 08, 2008 | ASUS Intel 440BX Chipset CUBX-L...
Format 320 GB HDD problem
Have tou tried the mangement in windows, My computer> right click>manage, then disk management and then right click on your hard drive and then one of the options is to format. Although only 127gb will show and the rest should show as a seperate partition, do the same with this to implement it. If no other partition shows you may have to upgrade your motherboard bios to suport large capacity disks.
Apr 23, 2007 | ASUS P4PE/L (ASU49J) Motherboard
Sony VAIO Digital Studio PCV-RX560 PC Desktop Logo
115 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
