Question about Canon PIXMA MP160 All-In-One InkJet Printer
Flashing msg 2 E , hazard light on, saying it doesnt have paper though it is loaded with new paper correctly
  • meganbot Dec 10, 2009
    i´ve tried both, neither is working
  • larry_d44ca May 11, 2010
    After loading paper correctly, did you press the "Black" or "Color" button?
    President:
  • Canon Master
  • 1,447 Answers
When show E2 then press Black or Color key.
Posted on Dec 12, 2009
  • Sazeed Computer
    Sazeed Computer Dec 22, 2009
    Please check paper switch and clean surface or when you show E2 press resume button.
My Star TSP600 Thermal Printer is displaying a flashing Error light. Power light on, new roll of paper loaded correctly, self-test was ineffective - nothing printed. What's my next step?
i know you stated you put the paper in correctlyin the printer but if the thermal reactive side of the paper is not facing the print head the thermal paper won't print on the wrong side of the paper. it will load into the printer and seem ok but the heat on the wrong side of the paper will not react and show any writing. Can you try turning the paper over in the printer feed holder so the other side of the paper faces the print head and give it another test .
Jun 21, 2016 | Star Micronics TSP600 Thermal Printer
No "blink" in my blinkers.
as indicator light systems work through resistance of the bulbs and LED lights have next to no resistance you may have to resistance in the power wire to the leds or fit the correct electronic blinker can
when on hazards there may be enough to make the can work
May 23, 2015 | Cars & Trucks
Red light flashes, screen says "load correct paper: A4." The paper is alreay loaded. I cannot print.
When <LOAD CORRECT PAPER> appears on the display, the size of the paper in the paper cassette or multipurpose tray is different from that of the paper specified in <PAPER SIZE> for <CASSETTE> or <MP TRAY>. You need to load the correct size paper or change the paper size in <PAPER SIZE> for <CASSETTE> or <MP TRAY>.
Check if the size of paper loaded in the paper cassette or multi-purpose tray meets the paper setting specified in the machine.
check the following:
1. The paper size specified on the printer driver screen
2. Paper loaded in the machine
3. The paper size set in <PAPER SIZE> for <CASSETTE> or <MP TRAY>
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Jan 16, 2013 | Canon ImageCLASS D1120 All-In-One Laser...
Hi, my lexmark e260dn "load paper" light stays on even though paper is loaded. please help
Please check if the paper guides on the paper tray are correctly positioned. For example, if you are using a letter sized paper, make sure the guides are set to 8"x11".
Dec 20, 2012 | Lexmark E260dn Laser Printer
Rear turn signal and hazard light don't flash (left side only)
The rear left turn signal bulb must be replaced immediatly before it melts the light socket, if it has'nt yet. Also please verify that the correct light bulb is being installed. because even though many bulbs look the same they are not identical. Installing the wrong bulb can be the begining of many, many problems in the particular circuit
Mar 26, 2010 | 2000 Ford Focus
The hazard lights start flashing and I can't turn
there must be alarm fitted that either has the siren disconnected or turned off. Basically sensing an intrusion alert or voltage drop. Flip out the hazard switch, there will be a wire which runs seperate from the body loom into this light, just cut it, the correct one though. if needs be trace it back.....probably end up behind the glove box
Oct 03, 2009 | 1995 BMW 5 Series
CANNON MP210 e3 SHOWING BUT NO PAPER JAM, C LIGHT FLASHING,B AND LIGHT ABOVE ON,PAPER GOES IN FIST INCH, MACHINE SOUNDS AS THOUGH PRINTING
I think it is not loading paper correctly. May be something struck in the way of roller. Or may be due to insufficient paper.
Another reason may be cover not closed completely.
Let me know if you need further assistance.
Regards
ELLIN
Sep 20, 2008 | Canon Office Equipment & Supplies
Flashing light
Here is what HP has on the subject of the triangle light flashing:
c00028322.gif 1 - Attention Light 2 - Ready Light 3 - Go Light Figure 2: Printer light key c00028323.gif 1 - Symbol for light off 2 - Symbol for light on 3 - Symbol for light blinking
c00028328.gif Door open, media out, no print cartridge, or media jam
The printer is in an error state that requires operator intervention or help. Check the following:
  • The print cartridge door is completely closed.
  • Media is loaded.
  • The print cartridge is correctly installed in the printer.
  • There is no media jam.
Figure 8: Paper jam c00028328.gif 13.JJ.NT JAM IN TRAY 1
13.JJ.NT JAM IN TRAY X
The Attention LED is blinking. Check paper loading then open and close top cover.
When there is a jam in tray 1, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored.
When there is a jam in tray X, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored. These are the error explanations for just the flashing triangle light, there are many more, but none for just the flashing triangle.
If the light pattern is different let me know (other lights on as well)
-Hope this helps.
May 28, 2008 | HP LaserJet 1012 Printer
HP4 and PC LOAD LETTER MSG (and there is paper)
Hi, I assume you can run paper thru the manual feed without any problems? If so the paper sensor that detects the paper in the tray has either broken or fallen off! If you take the paper tray out and tilt the printer a little bit on it's back you should see a sensor that will swing back and forth its' solid black/plastic . The sensor is very cheap and I'm pretty sure this is the problem> Good Luck!!
Nov 29, 2007 | HP : HP4 Laserjet Printer
Red Paper light keeps flashing
Try to find thge combination of buttons that reset the printer. there are many possiblities due to the modles - but try pressing any 2 and whilst holding them down switch off and then on again. Also this utility could proce use full. When it is loaded -right click the task bar icon. www.ssclg.com
Oct 02, 2007 | Epson Stylus C86 InkJet Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
91 people viewed this question
old marine
old marine
