Question about Vehicle Parts & Accessories
Need a wiring schematic for 1995 chev. k 1500 suburban 4x4[ Power door locks], want to change to remote control, I have installed a vehical secutiry system that is wired for automatic door lock/unlock but there wiring diagram [ wire color in there book ] is not the same as my push button door locks in the door on my suv. [What color on my suv is lock & what color is unlock/
  • Anonymous Mar 20, 2014
    bought a new remote for locking and unlocking doors
  • 41 Answers
Light blue = lock white = unlock in drivers kick panel
Posted on Feb 03, 2010
I have a 2005 Chevy extended cab 1500 and the controls on my driver side door aren't working. The door is saying it ajar when it's closed. I can't roll the windows up or down. Is it the master switch?
How to fix the Chev power window door lock switch - YouTube
? 5:04
https://www.youtube.com/watch?v=XDKaDURD8Sc
Jul 13, 2013 - Uploaded by spelunkerd
How to fix the Chev power window door lock switch ..... Some time later my drivers side window stopped working in the down position. ... These intermittent electrical problems are frustrating,aren't they? .... How To Install Replace Door Locks Chevy GMC Truck Silverado Sierra Yukon Tahoe Suburban ...
Diagnose Power Door Locks Dont Work Properly - Auto ...
www.auto-repair-help.com/.../diagnose_power_door_locks_dont_work_...
An inoperative power door lock can be caused by the switch, solenoid, wiring problem or ... Hi, I have a 2005 Nissan Sentra and the power locks aren't working. .... Hi, mypassenger door locks/unlocks both doors but my driver side door works independently and .... I have a 1986 Chevy Silverado K10 with auto door locks.
SilveradoSierra.com • 2003 silverado no power in right door ...
www.silveradosierra.com/.../2003-silverado-no-power-in-right-door-t30...
Dec 26, 2015 | Cars & Trucks
Chevrolet suburban LT 1500 LT won't disengage from four-wheel-drive
Chevrolet Suburban Questions - 4 wheel drive does not ...
www.cargurus.com > Questions > Chevrolet > Suburban
CarGurus4 wheel drive does not work - When I put the Sub in 4 wheel drive, low of high, ...Asked by Robert_Holland_073 Dec 17, 2009 at 04:06 AM about the 1994 Chevrolet Suburban K1500 4WD ... it can seize up and then the trans case may ingage but the hubs won't be locked in so it ... 1999 Chevrolet Suburban K2500 LT 4WD.
Chevrolet Tahoe Suburban 4 Wheel Drive Indicator Lights - Car ...
forums.edmunds.com > Chevrolet > Chevrolet Suburban
Oct 2, 2007 - 31 posts - ‎19 authors
My 1999 Tahoe (odo reading 137,400 miles) won't go into 4 wheel drive. .... I have a 98 suburban 1500 4x4 LT 5.7 L with 165,000 miles ... I recall once forgetting todisengage 4WD and I could feel a terrific binding when I ...
Step by Step Troubleshooting 4wd 4x4 88-98 Chevy GMC ...? 21:32https://www.youtube.com/watch?v=Su9Dkrfd_ZgJan 20, 2014 - Uploaded by rwdellingStep by Step Troubleshooting 4wd 4x4 88-98 Chevy GMC Truck. rwdelling .... Mine is acting like it is NOT pulling with the fronts,won't engage. ... Have you ever adjusted or the shift cable on your 1500 Chevy ... GM 246 transfer case, 2000 Chev Suburban- Duration: 20:09. by spelunkerd 286,045 views.GM Troubleshooting Part 13 - 4WD vacuum actuator & cable ...? 5:11https://www.youtube.com/watch?v=CbEF6PyJdU0Feb 3, 2011 - Uploaded by mr diyguy123I tacked on this video about the 4wd sys. ... I have a 1994 ChevyS10 ... My S10 won't let you go to 4 LO when your in gear. ... the front end to keep them disengaged. when you put it in 4wd, the vacuum actuator pushes a gear ...
Dec 25, 2015 | Chevrolet Cars & Trucks
What controls the delayed power retention system on a 2005 Chevy Silverado truck? Radio, windows, etc., are still powered after the door is opened. Will now only shut off after lock is pressed on remote.
You will need to check the driver door trigger as this wire shuts down that system. Also verify the circuit shuts down if you open the passenger door. The main circuit is powered from the ACC wire located in the steering column. It is a thick BROWN wire.
Aug 11, 2010 | 1995-1997 Chevy 1500 Truck Ignition...
1995 GMC Suburban. The interior power door lock switches not work
Take The Driverside Control panel Off The Door,And Check Conection On The Main Switches,These Vehicles Have Locks On Them, And If They get loose The Stop Working,Also Check The Little Switch Towards The Front of Panel,It Also May Be Loose,Use Caution,The Clips Are Fragile..
Nov 05, 2009 | 1995 GMC Suburban
Trying to remove door latch on 1995 thunderbird. Car has power locks.
inside or outside latch? please rate
Section 01-14A: Handles, Locks, Latches and Mechanisms 1995 Thunderbird, Cougar Workshop Manual
REMOVAL AND INSTALLATION Latch, Door Removal and Installation
  1. Remove front door trim panel (23942) and watershield from front door (20124). Refer to Section 01-05 .
  1. Mark the location of the bolt retaining front door glass run front retainer (21572). Remove the bolt.
  1. Check all rod connections against the appropriate illustration. Correct any disconnected or loose connections and check operation before replacing parts.
  1. Remove power door lock actuator (218A42).
  1. Disconnect the rods from the front door latch (21812) . The front door latch remote control link (21940) and the latch-to-lock cylinder rod cannot be removed because of the rod's end configuration. Remove wiring from clip on front door latch shield.
  1. Remove front door latch control cylinder rod (22134) from the door lock cylinder (21985).
  1. Remove front door latch remote control and link (21818).
  1. Remove the front door latch retaining screws. Disconnect the door open warning lamp switch (14018) , if so equipped. Remove the front door latch from the front door .
  1. NOTE: Do not damage anti-theft shield.
    Remove anti-theft shield from the front door latch .
  1. Remove front door latch remote control link , front door latch control cylinder rods , and door open warning lamp switches from front door latch , where applicable.
  1. To install, reverse Removal procedure. Tighten front door latch retaining screws 4-8 Nm (36-70 lb-in).
Item Part Number Description 1 21852 Front Door Latch Push Button Rod 2 21940 Front Door Latch Remote Control Link 3 386656-S Bushing 4 21978 Door Latch Shield 5 218A42 Power Door Lock Actuator 6 22134 Front Door Latch Control Cylinder Rod 7 21812 Front Door Latch
Remote Control Assembly Door Latch
  1. Remove front door trim panel (23942) and watershield. Refer to Section 01-05 .
  1. Remove screw and washer assembly retaining front door latch remote control and link (21818) to front door (20124) .
  1. Rotate front door latch remote control and link to remove from front door latch remote control link (21940) .
Sep 27, 2009 | 1995 Ford Thunderbird
Powere locks continuously lock and unlock with lights flashing,etc even when car is turned off.
Doors locking and unlocking, lights flashing. You have a possessed Suburban get a priest immediately! Or you have a short circuit. Try and remember if any work was done to your SUV and in what area. Then look for peeled, scraped or touching wires.
May 06, 2009 | Chevrolet Suburban 1500 Cars & Trucks
1995 GMC Suburban 4x4 1500
Check the wires on starter solenoid to make sure they are in the right spot. Sounds like the ignition wire terminal on the solenoid is getting constant power. I hope this helps!
Jan 30, 2009 | 1995 GMC Suburban
Code for automatic door locks on 1999 Chevy silverado
you have to take it into the dealership for a 1999. the dealer needs to change the settings in the BCM (body control module). in 2000, the BCM came preprogrammed to allow the owner to change the door lock settings at home. unfortunately for a 1999, it has to be done at the dealership.
Jan 01, 2009 | 1999 Chevrolet Silverado 1500
Vehicle Parts & Accessories Logo
238 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
