Question about Sony GDM-400PS 19" CRT Monitor
Screen always bleu
My screen, (Sony multiscan 400ps trinitron) is always bleu.
i tried to connect it on ather computers but the problem persists.
help me pleas.
  • Anonymous Feb 13, 2008
    My screen is bleu also.the red flickers in occasionally for a second or two then its gone.the color adjusters for red do not seem to work
  • 48 Answers
Ok.. most probably the data cable of your monitor is damaged.. try to check it if the pins are still in tact.. if not, then you should replace it with new one..
Posted on Jan 21, 2008
Chanel numbers and video stay on screen. example the number 3 always on in corner of TV screen or video number always on the screen.
hello, you should press the display button
at the remote control that marked with the i letter or with the ? sign . good luck!
Feb 09, 2011 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Sony Trinitron KD-28DL10U switched off suddenly to standby mid programme and won't come back on.When trying the remote on I can hear it click on and immedietly off again.Switched off at set and socket and...
In time as the Sony Trinitron ages it begins to have power issues. While this can be true of most tube televisions it's the rate and severity at which this happens to Trinitrons that makes it particularly of note. Many Trinitron owners have complained of the Trinitron set turning itself off randomly and frequently. Some sets have failed to stay on for longer than a few minutes at a time. Eventually some sets will not turn on at all. These problems grow more severe with age.
Check the power cable running from the Sony Trinitron 32. Make sure the cable is completely inserted into the power connection on the rear of the TV as well as the local power outlet.
Disconnect the power cable from the electrical outlet, then plug it into a different connection. It is possible to electrical outlet has died, forcing you to obtain a power current from a different source.
Check the cable connection running from the cable/satellite receiver or VCR. If the TV is on but no picture is on the screen, the problem is most likely due to a connection issue.
Power off the cable/satellite receiver, then press the "Video" button on the remote control to switch the Trinitron 32 to the video input signal. Turn on the cable/satellite receiver and the programming now loads onto the television screen.
Nov 21, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Screen image on GPS 400 PS jiggles
Make sure that the driver is updated. Then if it is, contact apple.
Feb 08, 2009 | Sony GDM-400PS 19" CRT Monitor
Interex Serial Monitor adaptor
I have the same problem. Did you get an answer?
I need the code too.
Mar 25, 2008 | Interex Serial adapter
Flashing Screen
ok, the problem you may be having is bad solder connections on the vertical deflection IC. resolder them or have a tech do it. also check for bad solder on the 9 volt regulater IC as well. these problems are common to older sony sets.
Feb 29, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony Multiscan E400
back light or inverter problem Dont know about repairs though.
May 20, 2007 | Sony CPD E400 19" CRT Monitor
Image center drifts, bad keystone, jiggles
Hello, the repair seems possibble to me. One of common reasons for the above mentioned error can be bad soldering (contact). Ask a pro to do the job for you. If you need more info please advice. Arpi
Mar 22, 2007 | Sony CPD 400PS (White) 19 in.CRT...
Monitor wont turn on
Check with another monitor, you will know where the fault is then.
Apr 02, 2017 | Sony GDM-400PS 19" CRT Monitor
Sony GDM-400PS 19" CRT Monitor Logo
85 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
